Old 01-15-2012, 05:32 PM
Swif Swif is offline
Mein Auto: 04 745Li
Car shuts off
Anyone have their 04 745LI shut off when driving. I have had this happen 4 times. Most the time when taken off for a light.
No check engine light. Car will not restart right away. Takes a few minuets before it cranks and starts.
It is almost like I shut the car off with the start/stop button.
Old 01-16-2012, 06:12 AM
Mein Auto: 04 745Li
No one here has had this happen?
Old 01-16-2012, 09:08 AM
bghubr's Avatar
bghubr bghubr is offline
BMW Driver
Mein Auto: 2011 activehybrid 7
Search for alternator or battery problems. This is a symptom of one of the two going bad.
2011 Activehybrid 7
2011 535i xDrive
Old 01-16-2012, 10:12 AM
DFEL750I's Avatar
DFEL750I DFEL750I is offline
Mein Auto: 750I
If the car is not cranking at all then I would looking into the integrated power supply module. Seach for it on here and you will find some answers.
Old 01-16-2012, 10:17 AM
Mein Auto: 04 745Li
Thanks for the leads.
Don't think the alt or battery has a problem as kl15 and kl30 are fine.
will look at the integrated power supply module.
Old 01-16-2012, 01:50 PM
M4XBMW7's Avatar
M4XBMW7 M4XBMW7 is offline
TTurboFest
Mein Auto: F02 (750Li)
How long will it take to start once dead ? Sounds almost like a crank sensor issue .
Old 01-16-2012, 02:04 PM
Mein Auto: 04 745Li
Not to long. At time is is with in seconds. A few times it take a few minutes. This has happened with in 5 minutes of starting the car and taking off from a start. Reviewing threads about the integrated power supply module It sounds like that could be the issue. I will go to my buddy's shop Friday and hooke up the GT1 to read faults if any and check operation of the crank and cam sensors.
Does anyone know what faults store due to a bad integrated power supply module?
Old 04-09-2012, 08:57 AM
Mein Auto: 04 745Li
So I have found that if I carry both keys with me and I have a no start/no crack concern I charge the key I am using car starts up. This no start takes place more often when the weather is hot. Does the integrated power supply module supply power to the ingition curcuit? I have tried to find wiring diagram on the ISM but have had not luck.
I have also found that if I disconnect the power connector at the right side next to the jumper post I can get the car to start 50% or the time. Other times I have to have it disconnected for about 3 minutes and then start the car.
When I checked for faults with buddy's GT1 we found many historyical battery faults.
Old 04-09-2012, 09:16 AM
DFEL750I's Avatar
Mein Auto: 750I
Definitely sounds like an integrator power supply module issue. Yes that module supplies power (controls) to all critical modules in the car.
Old 04-09-2012, 11:57 PM
Datrojan Datrojan is offline
Mein Auto: 750Li
I'm willing to bet it's a bad crank/cam sensor. Mine cost $1800.00 to fix out the door.
Old 04-10-2012, 12:15 AM
ikob ikob is offline
Mein Auto: bmw 745LI
+111
Old 04-10-2012, 09:23 AM
SFbay SFbay is offline
Account Under Review
Mein Auto: BMW 745i
How much????!!!???
Old 04-14-2012, 01:09 PM
Mein Auto: 04 745Li
If it was a bad crank sensor then it would not start up with the other key like it did.
So I removed the IPS and found that fuse 3 was almost popped out.
What circuit does fuse 3 power on the IPS module? Who can get me a wiring diagram to review?
Old 04-14-2012, 01:30 PM
Khabar Khabar is offline
Mein Auto: 745i 2005
servotronic #3 in glove box pass side
Old 04-15-2012, 12:50 AM
jdcraw's Avatar
jdcraw jdcraw is offline
Mein Auto: 760Li
I'm also having power related problems, can you explain 'how to' & 'where is the IPS' so that I can try troubleshooting too? Thanks
Symptom: My starts are long and slow, power decrease and surge and rare occasions it shuts off. My battery & alternator test ok.
jdcraw
Old 04-16-2012, 08:59 AM
Mein Auto: 04 745Li
jdcraw
You will need to remove the right side micor filter. Remove the clip for the micro filter housing (10mm bolt head). You will need a 5 or 4mm allen. Once you have the cover removed you will see the IPS module in fornt. to remove you will have yo pull the ECM out behind the IPS. then remove the IPS.
Old 04-16-2012, 09:19 AM
N62B44 SGM's Avatar
N62B44 SGM N62B44 SGM is offline
Mein Auto: '05 E66
Could be a bad fuel filter too and/or both.
www.fquick.com/N62B44_SGM
2005 BMW 745Li E66 Sterling Grey Metallic / 35% Tint (windows) / 20% Tint (tails) / ACS Roof Spoiler / Interior & Exterior LED's / MTEC V3's / 6000K D2S /
DDM Tuning HID 6000K Fogs / BIMMERFEST license plate cover
Old 04-16-2012, 10:50 AM
Lastcombo's Avatar
Lastcombo Lastcombo is offline
Mein Auto: BMW745I E65 ,BMW318 IS 94
Any updates on this matter
Bayerische Motoren Werke
Old 04-16-2012, 01:38 PM
What is the difference between Control unit power module (61 35 9 132 581) and Integrated supply module ( 12 52 7 510 638)?
Old 04-16-2012, 01:46 PM
pkathee's Avatar
pkathee pkathee is offline
Mein Auto: 760 Li
They have different part numbers.......
1) 760Li- Logic7, Rear entert', Rear Climate, Comfort Access, 20" DP Wheels.
2) Lexus LX470- Mark Levinson Video/Audio, 22" Diablo Elite Wheels.
Old 04-16-2012, 01:55 PM
Mein Auto: 04 745Li
Fuel filters do not stop the starter from turning. many time a bad fuel filter will cause serging before a complete shut off.
That said this will be replaced when I service the car in a few months. (Plugs, air filter, diff fluid, P/S fluid, micor filters, brake fluid flush and fuel filter. Will service trans and replace sleeve.)
Car has been driving good so far. (knock on wood)
Old 04-16-2012, 02:13 PM
what was your problem?
Old 04-16-2012, 02:19 PM
Mein Auto: 04 745Li
Also have some trans shifting concerns at times. Everything seems ok right know. Will keep the forum upto date.
Old 04-17-2012, 10:13 PM
Bryan Aceron Bryan Aceron is offline
745i on 24"
Mein Auto: 745i BMW
I'm Having the exact same problem with my 745i 2004 i changed the alternator and the battery now the ips message comes on and all my lights on my dash blinks on and off but the car still kepps running and to add to that when it is in or im and a stop and it is idleing it is fine it happens only when i give it gas .. if i resolve it i will post it and if you have any infomation that could help me it would be highly appreciated
745i on 24"
Old 04-17-2012, 10:22 PM
Mein Auto: BMW 745i
Sounds like power module glitch.
Check with inpa your power module, it's gonna tell you a lot
