E36 (1991 - 1999)
Old 02-14-2012, 04:00 AM
godfrey mush godfrey mush is offline
Mein Auto: bmw e36 316i
my trunk wont open
i pushed the trunk releas non to open but it went inside it wont come out , the key wont open, the doors can open usin the remote button but this trunk will not open, plsease any ideas of how to open
Old 02-14-2012, 09:05 PM
custm42435 custm42435 is offline
Mein Auto: 1999 328ic
is it a convertible? if so push down on the top storage lid (hold it down) and youll hear the trunk unlock.
1999 328ic M-TECH
"only 2 cars in my life have every survived my prolonged lead foot.. a Nissan Maxima and my BMW.."
BEHOLD THE POWER OF 3!!
Old 02-15-2012, 11:10 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
^This.
There's a microswitch under the tonneau cover on the passenger side. If the switch doesn't trip, the car thinks the cover is open and will not let the trunk open. Put some weight (a lot of weight if necessary) on that part of the cover and you may hear a click from the trunk, then you can open it. You may need 2 people for this.
If it isn't a convertible, then I have no idea.
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-03-2012, 06:56 PM
Caplestone Caplestone is offline
Mein Auto: 2005 X3, 1997 328ci
I had same problem on my 1997 328 convertible, and ended up using a hole saw to put an access hole behind the rear license plate where I then found the latch that I was able to open with my finger. Probably was a bad switch somewhere, but this access hole got me out of a bind.
Old 04-04-2012, 10:15 AM
petriej's Avatar
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-04-2012, 10:19 AM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
Old 04-04-2012, 10:28 AM
Greg19 Greg19 is offline
Mein Auto: 3 Series 1995 (E36) Coupe
If it's not a convertable you can gain access to the boot (trunk) via the back seats. I had the same problem but after dismantleing the boot solenoid & giving it a good soaking in WD40 all was well. Let me know if you need more detail...
Old 04-04-2012, 12:55 PM
EnserioJose's Avatar
EnserioJose EnserioJose is offline
Back in the game
Mein Auto: 1997 m3
Not all saloons (sedans) came with folding rear seats.
The shot heard 'round the world.
Originally Posted by E36 Phantom View Post
That presenter is getting waaay too worked up over a tarted up VW Golf.
C:\>Sent from my 386 using MS-DOS__
Old 04-04-2012, 02:21 PM
petriej's Avatar
You can always remove the rear seats, though.
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-10-2012, 01:41 PM
msol msol is offline
Mein Auto: 2002 525i
Check out this video. It might help u out with Ur problem
