E36 (1991 - 1999)
Old 03-12-2012, 07:03 PM
chillwill13555's Avatar
chillwill13555 chillwill13555 is offline
chillwill
Mein Auto: bmw e46
Talking helppppp needed
when i back up i hear a grinding sound on my front driver side only when i turn the stearing wheel so i figured it was the brakes grinding and i changed the brakes all around . and i still hear the grinding everytime i put it in reverse and turn the wheel .can any body tell me what it could be much help needed thanks
Old 03-12-2012, 07:17 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Did you check your wheel wells to see where your tires are rubbing? Because that's what is going on. Sounds like you blew a ton of money on brakes you didn't need.
1998 BMW 328is
1966 Pontiac GTO
Old 03-12-2012, 07:42 PM
chillwill
Mein Auto: bmw e46
brakes were nothing i got a hook up on parts and stuff so i dont pay much brakes cost me 40 bucks for front and back lol yea i checked the wheel wells tires dont rub it sounds more like grinding metal when i back up but if im driving foward and turn you don't hear anything its only when im backing up . its crazy
Old 03-12-2012, 07:47 PM
veteran011's Avatar
veteran011 veteran011 is offline
WARNING: Has Dumb Ideas
Mein Auto: 97 328is
wheel bearings?
dab of oppo anyone?
Project List:
Replace coolant temp sensor
Replace starter
Brake and Power Steering Fluid Flush
Front Control Arms, Bushings, and Tie Rods
Replace Passenger Lock Actuator
Reglue Peeling Hedliner
Swirl removal
Old 03-12-2012, 10:33 PM
JoshuaG's Avatar
JoshuaG JoshuaG is offline
Natasha 95M3
Mein Auto: 95' E36 M3
^ my thoughts.
Originally Posted by kaos_325i View Post
Maybe I haven't been here long enough to realize the knowledge you have to share. But, from all I can tell you are just an over opinionated, rude, prick.
My .02
Old 03-13-2012, 08:24 AM
chillwill
Mein Auto: bmw e46
wheel bearings ill look in to that thanks but i will have to change both of them just in case the other one goes lol
Old 03-13-2012, 08:44 AM
veteran011's Avatar
Mein Auto: 97 328is
definitely need to replace both at the same time. im assuming you know how to check for play in the bearing?
dab of oppo anyone?
Project List:
Replace starter
Swirl removal
Old 03-13-2012, 08:50 AM
ZeGerman's Avatar
Warm Leatherette
Unlike brake pads, springs, shocks, etc., you do NOT need to replace the wheel bearings on both sides of the car at the same time. Nobody ever does that.
I have serious doubts that it's related to a wheel bearing. When wheel bearings fail, the noises they make typically cannot be heard at low speeds. Often times they can't even be heard under 30mph, so the fact that the OP can only hear the grinding noise when turning while reversing suggests (to me, at least) that there is rubbing of some sort happening.
1998 BMW 328is
1966 Pontiac GTO
Old 03-13-2012, 08:52 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Agreed with Karl. Wheel bearings are a 'replace as needed' part.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 03-13-2012, 06:24 PM
chillwill
Mein Auto: bmw e46
Cool
ill check the bearings out but like i said it sounds like metal grinding only when i put it in reverse and turn the wheel . other wise i dont hear anything when im driveing and turning corners lol its wild lol and i just had the car forabout 4mths lol
Old 03-13-2012, 06:46 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
that, and i haz plenty of butter....
df
Old 04-10-2012, 06:33 PM
chillwill
Mein Auto: bmw e46
my bimmer is pozest now i got 18 on it and i dont hear any grinding when i back up lol
Old 04-10-2012, 06:50 PM
Joe__Sterling's Avatar
Joe__Sterling Joe__Sterling is offline
Fast Cars Suck!
Send a message via AIM to Joe__Sterling
Mein Auto: '13 FIAT 500 '68 BMW 1602
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
@Joe__Sterling on twitter & instagram (two underscores)
