E36 (1991 - 1999)
Old 04-02-2012, 10:08 AM
tbateman57 tbateman57 is offline
Mein Auto: 1999 e36
Question 1999 E36 318i OVERHEATING
Hi
On Saturday while sat in traffic, my heater guage started rising from the usual half way mark to just below the red. Then it would go down a touch, then up again, then down again etc etc. Had a look at coolant level when I got home and it was very low. Filled it back up and left it. The following day I drove 2 miles, and the coolant level was low again.
Filled it up again and left it overnight.
Going to work this morning and after 7 miles the guage went up to red again, then down again to just over halfway, then back up again, down again etc and it has been carrying on like this on the drive home. My coolant level however has stayed at the full mark.
Does anybody have any ideas as to what can be causing this? i I have searched so many threads, but am unable to find anything with these symptoms.
Thanks in advance
Tina
Old 04-02-2012, 11:38 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Sounds like coolant is leaking somewhere, and causing bubbles, which cause sporadic overheating. When the car is running, do a quick visual inspection in the engine bay for leaks. Sometimes the system will have a leak somewhere the coolant doesn't sit when the engine is off, so you won't have any puddles under the car, but when it is running, it leaks.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 04-02-2012, 01:09 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
^ this, and QUIT DRIVING IT until you get the leak fixed and the coolant system 100%. You will damage the engine, if you haven't already. We see one of the overheating postings every week...sometimes several per week. We wish BMW had put a sticker on the dash stating "Driving this vehicle with the temperature gauge over the center mark will ruin the engine" but they didn't. I'm afraid you've already hurt it pretty badly. Good luck.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 04-02-2012, 01:38 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
593...
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 04-02-2012, 04:22 PM
buellxb buellxb is offline
Mein Auto: 1997 328i
This exact thing just happened to me 2 days ago....end result was blown head gasket. Check your coolant for oil, and vice versa
Old 04-03-2012, 10:15 AM
Mein Auto: 1999 e36
Thanks for the replies. I put some bars leak seal in and have not lost any coolant since. I still have the overheating problem, though it's not happening anywhere near as often. Just 3 times on a 15 mile trip where before it was up and down constantly. It never gets into the red, just below it, then would go back to the halfway mark for a good few miles. No white gunk on either dipstick or oil cap. Tried to bleed the radiator, but had no air escape at all. Could it be a sign of a dodgy thermostat? If so, where do I find this?
Tina
Old 04-03-2012, 10:24 AM
petriej's Avatar
The best and only way to really test the thermostat is to remove it and throw it in a pot of water on the stove. Stick a good thermometer in the water and when the temp hits 90C (or whatever temp thermostat you have) the thermostat should pop open. If it stays closed, it's not working.
That being said, our thermostats have a tendency to fail in the OPEN position, so it's not likely your problem. My guess is an air bubble or two.
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-03-2012, 10:29 AM
jayjaya29's Avatar
jayjaya29 jayjaya29 is offline
Come at ///M3
Send a message via AIM to jayjaya29
Mein Auto: 97 M3
Nobody states the easiest and probably the most obvious culprit...an unbled coolant system.
Do a proper bleed of the system.
Old 04-03-2012, 11:09 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
The comment directly above yours is implying that the system needs to be bled. The other reason why bleeding the system is not particularly relevant is because the system developed the overheating symptoms out of thin air, meaning something is not right. So, while it may have air trapped in the system, there is something else which is allowing the air to enter the system in the first place. OP should check for leaks, fix them, and re-bleed the system.
1998 BMW 328is
1966 Pontiac GTO
Old 04-03-2012, 11:11 AM
petriej's Avatar
Yep, bleed that system like a slaughtered goat!
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-03-2012, 11:39 AM
Mein Auto: 1999 e36
I had the engine running,heater gauge upto halfway mark, radiator cap off, bleed screw loose and heaters turned on full. I didn't have any air escape. Is there something else I should be doing?
Old 04-03-2012, 11:53 AM
jayjaya29's Avatar
Come at ///M3
Mein Auto: 97 M3
Leave the rad cap on and crack the bleeder screw, you will know its fully bled when only coolant comes out.
Old 04-10-2012, 12:07 PM
Mein Auto: 1999 e36
Thanks for all the replies. It turned out to be the water pump and thermostat.
Old 04-11-2012, 07:25 AM
Time2Fly's Avatar
Time2Fly Time2Fly is offline
Sometimes Out To Lunch!!!
Mein Auto: 1993 318i 1994 325i 1998
Get the bars leak out of the system!!!! That is the quickest way to kill the cooling system. Look down by the oil filter housing right against the block is a black pipe, right where that pipe goes into the block is where leaks develop. Around the tank on the right side of the radiator at the bottom they can leak there. If this car hasn't had any maintenance done to the cooling system in awhile that you know of then it's time........If you don't find any leaks it the areas I mentioned and you are still losing coolant pop the cap and smell the coolant if it smells like fuel or exhaust and you notice some dark build up in the expansion tank then you probably have a cracked head. Even with a cracked head it will not show oil in the coolant or coolant in the oil mine didn't. You will have a slight coolant loss along with some of the symptoms you describe. Good Luck and report back.
Old 04-11-2012, 07:27 AM
Time2Fly's Avatar
If you are losing coolant this has nothing to do the pump and Tstat
593
