Old 04-11-2012, 12:12 AM
XUMERX XUMERX is offline
JK3R
Mein Auto: 1999 BMW 528i
Hey guys a little late. I tried all the suggestions and something I notice is lets suppose I drive the car normally every stop the squealing would happen but if I make hard stop then all the stops following then it doesnt make anymore noise untill I think the pads cool down.. Any idea!!??
1999 BMW 528I
2006 BMW 530i
Old 04-11-2012, 09:16 PM
kossack47 kossack47 is offline
Mein Auto: 1999 528i
could be bad bearings. or hub.
I asked God for a bike, but I know God doesn't work that way. So I stole a bike and asked for forgiveness.
Old 04-11-2012, 09:19 PM
but you said its only squealing while braking.. um i dont think its the wheels. something with the rotors. you said they are brand new right?
Old 04-12-2012, 08:08 AM
JK3R
Yea the rotors are brand new. There Zimmermans and the pads are pagid. The guy at advanced auto parts said I should have pads that are completly ceramic??
1999 BMW 528I
2006 BMW 530i
Old 04-12-2012, 09:11 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
An old trick to get rid of brake squeal is to drill 2 holes the size of pencil leads. Then insert the pencil leads in those 2 holes. The squeal will go away.
BUT: going from style 5 to those M3 reps, is actually downgrading the car.
0.02
Looking for a DIY? Parts? Check this out, it might be your ticket
TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint
Stable: e39 M54, e53 N62 & Tribby
Old 04-12-2012, 09:29 AM
JK3R
0.02
Drill two holes whereee??... idk about this lol and about the wheels? thats an opinion dear sir.
1999 BMW 528I
2006 BMW 530i
Old 04-12-2012, 09:52 AM
doru's Avatar
Drill the holes in the brake pads. Small drill bit right through the pad and stop at the backing. One hole at one end of the 1/2 pad, the other at the other end of the 1/2 pad. Insert the lead, and snap it where it's flush with the pad. Braking performance will not suffer a bit.
But the squeal of the pads will go away.
Old 04-12-2012, 11:18 AM
Fast Bob's Avatar
Keeping it surreal
Or, you could try putting a dab of anti-squeal compound on the backs of the brake pads....cheap and simple, it just might cure your problem.
The road goes ever onward....
(R.I.P. Jever)
Old 04-13-2012, 09:22 AM
JK3R
I tried that.. I even sprayed this film of anti squeal thing on the backing of each pad but no luck. Idk about the holes guys. There is something I noticed, latley it hasnt been making as much noise as in the begining. I think im just going to rebuild my clipers put new seals and change the break fluid that is 12 years old!!
1999 BMW 528I
2006 BMW 530i
Old 04-13-2012, 10:14 AM
CoreyMNK's Avatar
CoreyMNK CoreyMNK is offline
Corey
Mein Auto: 2000 528i Step 215K Miles
Did you try bedding the breaks in? Or sanding the surfaces of the pads just a bit. This always seemed to stop my sequels.
2000 BMW 528iA Step- 223K Miles- Aspen Silver
  • Dinan Engine Software
  • Smoked Sidemarkers
  • Smoked Turnsignals
  • Shadowline Trim (Plasti-Dip)
  • Fittipaldi Wheels
  • Muffler Delete
  • Beisan Vanos Seals
  • Umnitza MTech Rear Bumper
2004 Volvo V70R
2005 Nissan Armada SE OFF ROAD
Old 04-13-2012, 10:53 AM
AnotherGeezer's Avatar
Hofmeister Kink
Mein Auto: 2003 530i/5
...or wearing of plaid pants...
Well there goes my recommendation.
BMWCCA # 430911
Old 04-13-2012, 06:28 PM
JK3R
I tried bedding them in but then after a few hours the squeal comes back....
1999 BMW 528I
2006 BMW 530i
Old 04-14-2012, 07:03 AM
Solo12 Solo12 is offline
Mein Auto: e39 530i e28 535is(Sold)
Perhaps more information will help get an answer. Perhaps it will make no difference, but maybe someone will recognize an issue once they know all the variables. What was the order of events? Did you install new rotors and pads and then you started to hear the squealing? Or you install new pads with your existing rotors and then you started to hear the squealing?
You said you have Zimmerman rotors and Pagid pads on there now correct? Are the rotors plain, slotted, drilled and what type/model of Pagid pads do you have? Also you said you tried 3 diff pads were they all the same type of pagids or did you try different brands? If so what type of pads were they and in what order did you try them? Are these all brand new pads were are talking about here?
I did not mention anything about the wheels because based on your comments it sounds like you have a brake issue versus a wheel issue. If you are getting a brake squealing sound when you apply the brakes I think the wheel stuff might just be distracting us from the real problem. Was the only change going from your style 5s to your 19s and then squealing started? Or had you made any changes to the brakes prior to of after the wheel install and that is when the squealing started?
E39 2003 530i: SP, CWP, PP, Manual, Sunshades, Split folding rear seats, 17" Style 42s
E28 1987 535is: Manual, Bilstein HDs, 16" Style 5v2 (from e38)[Sold]
Old 04-14-2012, 12:22 PM
JK3R
Well this is what happened... I had 50 % pad left and rotors.. when I had my style 5s and then I decided to buy the 19 inch wheels. After I installed them. The squealing started. It doesnt always happen. So I decided to change the pads and rotors. First I tried advanced auto parts pads, didn't work, then I tried some other brand from advanced auto parts all on the old rotor and then I heard it might be the rotor. So i bought a set. 4 zimmerman rotors and all new pagid pads. I did the bedding in process but it help only temporarly. And the rotors are plain.
1999 BMW 528I
2006 BMW 530i
Old 04-14-2012, 12:57 PM
Fast Bob's Avatar
Keeping it surreal
Suggestion:
Go out and drive it HARD for a bit, like you`re doing an extended bedding session (but DON`T come to a full stop after a 70-to-near-zero run, keep rolling to prevent the brakes from overheating. Give `em a couple miles to cool off, and do it again. That`s what it took last time I did the brakes on my wife`s E36 (Balo rotors/Pagid pads). It took several runs like that before they totally quieted down.
(R.I.P. Jever)
Old 04-14-2012, 11:25 PM
JK3R
Challange accepted!! lol Ill give this a shot tomorrow
1999 BMW 528I
2006 BMW 530i
Old 04-15-2012, 12:30 AM
e39tuner e39tuner is offline
Party Hard, Drive Faster.
Send a message via Skype™ to e39tuner
Mein Auto: e39 540iA
Agree
Have you tried to find rubbing or getting tires rotated even, I'd try slamming on the break from going about 15-20 mph.
E39 98 540iA Sport
Hamaan Black Kidney Grills, Resonator Delete, Supersprint Cats, BBS staggered rims, Smoked Euro Taillights...Many More Mods to come.
Old 04-16-2012, 01:56 PM
Fast Bob's Avatar
Keeping it surreal
This is not how you bed BRAKES.....
(R.I.P. Jever)
Old 04-16-2012, 10:41 PM
Silver540i6 Silver540i6 is offline
Mein Auto: BMW 540i/6
What are you going to do with those style 5s?
1998 BMW 540i/6 Sport...18" Staggered M Pars, Angel Eye Upgrade, Muffler/Resonator delete, iPod integration kit
1970 Dodge Challenger R/T SE...440 six pack, slap shift...blows away all e39s
Old 04-16-2012, 10:44 PM
JK3R
I sold them for $1200
1999 BMW 528I
2006 BMW 530i
Old 04-16-2012, 10:58 PM
Whorse Whorse is offline
Mein Auto: e30, e39
Are you sure there is no contact between the wheel and calipers? or contact between wheel weights and calipers?
Andreas
Queens NY
BMWCCA# 186796
86 325es (wrecked by careless driver)
87 325 300k (project for life) aka 1BADETA/Christine
00 540is 6spd 202k (daily driver)
Old 04-16-2012, 11:08 PM
JK3R
Im sure. Look the thing that surprises me is when I get the pads hot then they dont sqeal anymore for the day or half a day
1999 BMW 528I
2006 BMW 530i
Old 04-16-2012, 11:12 PM
Mein Auto: e30, e39
And you used brake grease on all the pads contact points?
edit, you made sure to to apply the grease on ALL the contact points not just the back plate of the pad?
Andreas
Queens NY
BMWCCA# 186796
Old 04-17-2012, 05:46 AM
Topaz540i's Avatar
Topaz540i Topaz540i is online now
Is it Safe to Dance?
Mein Auto: 2001 540i/6
Maybe u have bad wheel bearings. The rotor is attached to one side and the caliper the other. So if the bearing is loose and the wheel wobbles because os it the rotor will therefore slap around inside the caliper. The larger wheel my have increased this as there is less rubber to mush to road variations.
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 04-17-2012, 08:12 AM
doru's Avatar
Told you to try out the pencil led thingy. It's old school, did it in the 60's and 70's.
19s, brakes, squeal, wheels
