E34 (1989 - 1995)
Old 04-10-2012, 09:17 AM
nwilson44 nwilson44 is offline
Mein Auto: 2002 BMW 540i/6
540i Fuel Filters
How difficult is it to change the fuel filters on a 95 540i? How do you approach it?
Old 04-10-2012, 11:23 AM
CarDriver's Avatar
CarDriver CarDriver is offline
Mein Auto: 1992 525it /2004 ML350
Approach it slowly, with a smile so not to scare or P!ss it off
http://forums.bimmerforums.com/forum....php?t=1241177
Old 04-10-2012, 12:13 PM
1995i540's Avatar
1995i540 1995i540 is offline
Founder @ Maintenr
Mein Auto: 1995 540I/6
Just a footnote, the DYI is for a single filter system if you have two filters you will have quad t-shaped connectors which might break if you have not changed it in a while.. it's also a bitch to get hoses off on a corroded system without clearance so jack it as high as you can.
///////////////////////////////////////////// E34 Addicts
Founder @ Maintenr. Take control of your vehicle maintenance.
Old 04-10-2012, 02:47 PM
ThoreauHD ThoreauHD is offline
Mein Auto: 02/1994 530i 8cylinder
I wish I could do that, but I dont have a lift and crawling on the ground gives me gravel burn.
But if you can lift the thing up, then its fairly easy. They are flush against the center of the car. Sticking right out in the open. For using a lift, Bmw cca has monthly free self service days that are useful for this kind of undercarriage work.
Old 04-10-2012, 04:20 PM
Ya I have dual filters
Old 04-10-2012, 07:23 PM
goosefoot33's Avatar
goosefoot33 goosefoot33 is offline
Manualaholic
Mein Auto: 01 330Ci/02 525iT
Another footnote- instead of clamping the hoses and risking cracking them, relieve the pressure in the system by running the car and pulling the fuel pump fuse until the car stalls out.
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - PARTING OUT! (PM for details)
(Grocery Getter) 2002 525iT
Old 04-10-2012, 08:31 PM
1995i540's Avatar
Founder @ Maintenr
It will still shoot out, running with no fuse works much better for front end hoses :P If your hoses crack from clamping.. time to replace them IMHO
Old 04-10-2012, 10:08 PM
So I gotta hurry up and swap the filters so fuel does leak everywhere? Sounds like it. BMW shop said I will notice a difference when I change these. Any validation on that?
Old 04-11-2012, 09:15 AM
1995i540's Avatar
Founder @ Maintenr
If you changed them 100,000+ miles ago or have dirty fuel due to rusting tank yes... otherwise I doubt it.
No shop should tell you you will notice difference like it's a fact because it's simply not true.
Old 04-12-2012, 09:34 PM
I honestly think they are original. Unless it was part of the maintenance plan when the car was new. It has 126,xxx on it now so it should be a difference?
Sent from my PH44100 using Bimmer App
