Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 04-12-2012, 03:23 PM
SwimNDrive SwimNDrive is offline
Mein Auto: 1997 BMW M3 Coupe
E36 M3 What is this in the spring?
Hi everyone,
I purchased a 1997 M3 few months ago. It runs well to me so far. But since I am new to M3, there is a lot for me to learn about this car. One thing I noticed last time I took off one of the rear tires, there is an metal object inserted into the spring coil. Then I found the same kind of object in the spring coil on the other side as well. It looks like they were put in the springs with a purpose. Can anyone tell me why these objects were in the spring coils and should I keep them there?
Any help is greatly appreciated. Thanks
Old 04-13-2012, 06:31 AM
X3-terrestrial's Avatar
Aficionado
Mein Auto: '05 X3, '95 M3, '89 MkI
No idea what it is or why someone would put it there. It could be compromising handling integrity, I'd take them off there...
-Mario Andretti.
___________________
River City Bimmers Chapter
1995 ///M3 Coupe, Lux, MT, Htd seats, Cosmos Black on Black.
Old 04-13-2012, 09:59 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
They probably affect the springs compression properties. I'd take them out. It doesn't look safe.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by SCJon View Post
Jared is king of ambiguous comments.
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
Old 04-13-2012, 10:08 AM
ECSTuning's Avatar
Mein Auto: e30
Looks like someone was trying to raise the car slightly by putting those blocks in between the coils. I would remove them.
800.924.5172
OEM BMW Part Number Search
Old 04-13-2012, 03:11 PM
This car has been lowered. The wheels are 18" aftermarket wheels. I have concern if I take them out, it may cause some problem. I got advice from the other forum that I should check out the spring first and see what they are then make next move. This is not my daily drive. In the meantime, I need to take care of the CV boot. Over the weekend I will raise it up and check out the spring then see what will be the next. Thanks a lot, everyone for the response.
Old 04-13-2012, 03:47 PM
fun2drive's Avatar
BMWCCA 149159
What you are seeing is called a spring spacer and you almost never see them anymore...
Designed to help weak springs that need lift...
Old 04-13-2012, 08:27 PM
Does it mean I have the weak springs? Instead of having these things in my springs, should I consider replace the springs at this time? What are my options? Thanks
