X5 2005 - Whining/Humming noise - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 04-16-2012, 02:35 AM
Normz Normz is offline
Mein Auto: X5
Morning all,
I've recently bought an X5 Diesel and when driving at a steady speed,you can hear a noise more humming than whining from the front wheels (I believe). I've had the front & rear discs&pads changed (which needed a change anyway) but I can't work out the noise. Thought it was the wheel bearing but when the car is jacked up and the wheel is spun,there's no noise,so don't want to open up the wheel bearing in case it's not that as I will then have to replace it. The only other thing I thought it could be is the tyres,so I asked a friend if I could swap the front wheels from his X5 to see if it makes a difference,but to my surprise his car is making the same noise. ANY IDEA WHAT THIS PROBLEM MIGHT BE?? Any advice would be appreciated.
Old 12-05-2014, 05:01 PM
waid187 waid187 is offline
Mein Auto: bmw x5
did you find out what the problem was mate?
Old 12-05-2014, 11:57 PM
Nightmaren2's Avatar
Nightmaren2 Nightmaren2 is offline
Mein Auto: 2002 BMW X5 3.0 petrol
Could be the bearing as I on e had the same problem on the from right wheel and it was soo, after I changed the brake pads
Old 12-06-2014, 03:19 PM
2stroker 2stroker is offline
Mein Auto: X5
not sure about the diesel but the air pump is on right front of gas engine X5 ?
Old 12-21-2014, 06:33 PM
Mein Auto: bmw x5
had a humming noise to really annoying changed all four tyres and that solved the problem i thought it was the barrings at first but it turned out to be the front tyres
