#101
Wow, a lot of Wiper tech data on this listing. I replace mine yesterday, as I do every year or my wife will complain of wiper noise. In California we have so much heat the wipers dry out over the summer and squeak in the winter.
I will share that I keep it simple. I buy replacement inserts made by ANCO. The Anco catalog says they don't offer any that work but they are wrong if you are willing to make one small change. I buy the Wiper Refill ANCO W-28R, this comes with two inserts. The shape is perfect to fit in the OEM wiper arm. The only modification is to cut to length, you are buying 28 inch inserts so the passenger side needs to be cut down to length as does the drivers side. 26 inch would work but they don't offer a 26 inch blade, only 28 inch. I cut it with my dremel tool and then cleaned up the ends with the same dremel to make the ends match the stock look. The first time you install these you have to open up the one clip where the OEM inserts are locked in. This one clip is slightly tighter than the others on the wiper arm to lock the clip in place. I just slid a medium size flat blade screwdriver in and massaged it a little wider so it matched the other 6 or so supports in size. Just took a minute for the drivers side and again on the passenger side. A simple press on cap locks the insert into the wiper arm. I like the ANCO W-28R because they are cheap, fast to change and available everywhere for the most part. Some of the big chains no longer carry inserts. Once you use these the first time the second time install is 2 minutes max for both sides. Just thought I would share, it has worked on my 2002 E39 530i for several years and we are hitting the rainy season now. My OEM Wiper blade support on the passenger side broke last year, the plastic had aged in the clip that holds the wiper to the arm on so I bought a new OEM wiper blade to fix that last year. Given that history I would consider buying new OEM wipers with the arm every 6 years or so to avoid this. When mine broke it was being used and did scratch the glass a little before they were shut off. |
#102
I get my wiper inserts from Amazon. $3.95 with Prime 2nd day shipping.
These have the metal strips on them. Last edited by Blight67; 12-04-2011 at 09:44 PM. |
#103
The advanced auto near me has the trico inserts for the same price as the dealer here, 7 for the pair.
Sent from my PC36100 using Bimmer |
#104
That's the whole point. Makes for a longer more confusing thread. How did we manage to buy wiper blades (all of us) before this thread?! Why would one ask how long the wiper blade should be? Go out and measure. The inserts come long. You cut to fit. 5 pages and three years later... If you are paying more that $5 a set wherever you buy them, you are paying too much. KISS
#105
Tried to buy wiper blades at the parts store and was surprised by how much.
Didn't even know you could buy them this way. This thread will help me for next time. |
#106
For the crosslinked record, this thread today has useful information on buying the right wiper blades & refills:
- E39 (1997 - 2003) > Wiper Blade Guide?
#107
For the record, there is a good discussion on what causes wiper blade chatter over here today:
- E39 (1997 - 2003) > Noisy Skipping Windshield wipers Quote:
#108
I see the majority confirm going to the Stealer for blade inserts for under $10 per side (more so like 6-$7). So onward and inward I went to listen to them say $10 per side for a cost around $23. Since that price didn't jive w/my pre detailed research of "under $10" I left empty handed. Now back home and re-researching, I see AutohausAZ has the Bosch refill and blade set for $34 while it's only $32 on amazon - w/somewhat mixed reviews. So I'm feeling like I'm going to have to tuck my tail between my legs and go back(to Stealer) to hear "shut up and bend over"!!!! And pay over $20 as many have rightly described as just a piece of rubber and also stated no way they can't gouge you on that!! As a matter of principle, I'd be willing to pay a little extra somewhere else if I could get similar quality. I feel the same arrogance when going to the Apple Store...
#109
A user at bimmerforums wrote a website with a great search engine for finding bmw parts at the cheapest price.
The website is furiousmethod.com What happens is you punch in your part number and it searches about 15 different bmw part website (amazon, pelican,eac,autohausaz,etc) The only thing is each site pops up in its own window so you will have 15 windows to compare for the cheapest price. But other than having to compare the results yourself instead of just getting a list of prices it works well most of the time
ESS Tuning m60 version software m60 intake manifold a.f.e. c.a.i. 3" obx catback full powerflex urethane setup 545 ssk cdv delete m5 rear sway bar M5 chassis rods M5 3.15 lsd Bc-r coilovers w/ swift springs Akebono=suck ss braided brake lines coming soon: Jb lwfw
#110
Amazon has cheap replacement for whole wipers and I have amazon prime so free 2 day shipping
#111
I did try it and even tried unclicking many of the sources I'd probably never order from (try to limit online CC exposure) and they all pretty much show (and prove/confirm) my local Stealer is in fact telling me to "shut up and bend over!!" $2-$3 rubber that they're charging over $10!! Since my passenger side metal tip was off the strip and the strip cracked when I tried snapping it back on, I went for the entire Bosch assembly from Amazon (Bosch 3397001539 Wiper Blades - Set of 2), $42 and a few days wait. I'm sure this is about $60-$75 from them!
#112
has anybody thought about running the rain x latitudes wipes...i want to try them the ones i have now from bmw are garbage, its like the wipers are running right over the rain and not taking the rain off the window
#113
Otherwise, the BMW inserts work rather well for most people |
#114
My Bosch replacements came (faster than I thought) from Amazon and snapped into place after a few mins of figuring out which way was up! : - ) I did hold on to my OEM kit for the next replacement if I'm able to get "RUBBER" w/metal at a decent price - online from somewhere else obviously. For the passenger side (shorter) as I previously noted, I cracked the plastic trim that holds the rubber - it does not have metal all the way through like the driver side..just the tip that clicks and had come loose and that is what I was trying to snap back onto the plastic when it cracked.
#115
That happened to me also. I never did replace the broken piece.
BTW, for the record, the what-wiper-refill question came up again today with the latest information here: -> E39 (1997 - 2003) > Best wipers?
#116
Recently went with Bmw blades, now I have two sets,Ill be changing inserts from now on,as Ill always have a set of fresh blades.
O2 530i Slate Green metallic/Grey interior. |
#117
Thanks in advance.
2003 525i | Sterling Gray Metallic Last edited by ndncdntxn; 09-28-2012 at 11:35 AM. |
#118
You don't cut the tabs off anything! Cutting any metal part will render your wiper arms useless. When I buy a blade replacement, all I get is the rubber blade. I reuse the metal strips and the wiper arm.
You do not need to cut anything (unless you have too long of a blade) to replace a wiper blade. At one end of the rubber wiper blade, the two metal strips embedded on either side of the rubber blade are restrained by the attachment clips of the metal wiper blade arm. This keeps the blade from sliding out. Simply take a pair of pliers and squeeze the two metal strips together at the tip that restrains them in the wiper blade arm. This will allow them to pass through the little tabs on the wiper blade arm. Simultaneously pull the other end of the blade and the rubber blade slides out with the metal strips. Reassemble the new blade with the old strips and reverse the disassembly procedure. |
#119
Fudman's explanation is perfect.
See also the first few posts of this thread.
#120
For cross reference, there is a nice thread by Airos today showing why the dealer is not always the best place to buy wiper blades:
- > E39 (1997 - 2003) > $48.12 for two pairs of wiper blade INSERTS Quote:
As usual, Qsilver7 posted some nice information: Quote:
#121
Is the driver side wiper rubber really thicker than the passenger side rubber strip?
Even after all this, I learned something new today, if it's true.
As we already know, everywhere but in the Silicon Valley, the place to get wiper refills is at the dealer. Even so, I called all three dealers in the area, asking for price & availability - and - guess what? One dealer (Fremont) added a new part number to the mix for my E39, saying the driver's side wiper rubber is actually THICKER than the passenger side. This part number (61.61.0.154.440) had not shown up before (in this thread anyway, except as a replacement for the rear window on the touring). Here are the relevant quotes:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 12-04-2012 at 06:28 PM. Reason: added detail |
#122
Hmmm, the replacement inserts I get at the dealer are the same width.
Steve 2001 530i/5 S+P CDV delete/Akebono ceramic pads M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD OSRAM CBI BMWCCA Member #337964 |
#123
I just did mine last week. I went to the parts desk and asked for "wiper blade inserts, part number ending in 441". $3.30 each, an even $7.00 for the pair including tax from Devon Hill BMW, Devon, PA.
They fit just fine. The only issue was that the end guide on the Bosch "skeleton" was crimped to hold the old insert in place. I just had to take a pair of needle nose pliers to open up the guide a little bit wider. I only worry that too much bending out and recrimping will end up in a broken guide eventually. If you are worried that your blade inserts are of different width, no problem. Just slide the lock tabs, drop the blades out, and do a close side-by-side visual inspection. Your eye will be able to pick up any size differences. If you are really worried, just take the blades into the parts desk at the dealership and ask if 441 will fit both. or alternatively.... take out your micrometer and measure the backbone of the insert currently on each blade, but I think this is overkill. |
#124
This method also eliminates the chance of introducing a twist into the blade guide tabs as you bend them back. Such a twist can result in the wipers chattering on the glass.
Regards RDL |
#125
Just called the dealership in Dulles, VA and they want $16.50 for a pair. What a scam.
EDIT: Just placed an order with thebmwpartstore.com and total was around $9 shipped. Last edited by BentValve; 12-05-2012 at 12:51 PM. |
