5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with! |
Installing an E39 M5 trunk lip spoiler
Aha, you say, this needs a DIY? You'd think not, but more than one person in the E39 forum has done it only to report later that it somehow came off. So, since I did mine recently, and it's still there, I figured I'd post a how-to.
First, you need a trunk: ![]() It needs to be clean but not sterile. Typical quick detailing spray should be enough, unless you've waxed recently, in which case you should use a spray cleaner like Windex that will remove the wax. DON'T GET CARRIED AWAY WITH THIS. The use of petroleum distillates like acetone or turpentine is not a good idea, as they are notorious for leaving a residue that will attack the adhesive on the tape, and your spoiler will likely fly off at some point while you're barreling down the freeway. Next, using some packing tape, position the spoiler on your trunk. Tape it down on the front only (you'll see why in a moment). ![]() Be as anal as you possibly can with this to be sure you've got it the way you want it. Run your fingers along the edges to be sure it's not sticking out anywhere it shouldn't be. Check it out from several angles to make sure it all looks straight. Then go get someone else to see what they think. When you're satisfied, lift up one end and peel off the very end of the tape covering. Some of these spoilers have two strips of tape. If you've got one of those, as I did, peel off only one at a time, and start with the front one (if you start with the rear one, you won't be able to get at the tape in the front without pulling up all the packing tape). ![]() Then, keeping the spoiler down on the deck, slowly pull it back (not up) from under the spoiler. ![]() The tape will adhere instantly, so do it slowly and make sure it's not getting out of position. If there is a second strip of tape, lift up the end again and peel that one off too. Press down firmly across the whole length of the spoiler to be sure you've got a good seal. You're done. Enjoy!
2002 530i | Black/sand | Rondell Style 81s: 18x8.5 Front 18x10 Rear | Koni FSD | Eibach Pro-Kit | Zimmerman X-Drilled Rotors | Axxis Deluxe+ Brake Pads | StopTech SS Brake Lines | 50w 6000k Xenon Lows/LED Fogs/Phillips Luxeon LED DRLs | Angel i Brights v3.0 | Solaris Invisibulbs | Shadowline Trim | ///M5 Trunk Lip Spoiler | 35% Madico Tint | Dynavin D99+ ///M3Evolution | Backup camera | Intake Muffler, Front Plate, Badge & Cup/Coinholder Delete | Klasse AIO+SG |
Nice
I would also add that you should only try this in temperatures above 60 degrees and make sure your car is parked in the sun to heat up the trunk before you start. Also, after I installed mine, I taped the corners down for a few hours to make sure there was good adhesion. |
Is there a spolier like this for the E92 coupe yet? Like the look.
I'd check eBay. Xenonspecialist was the vendor I got it from.
bump
2001 530i/5 (E39), Topaz Blue/Stone Green/Black (97k miles) 2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease transferred...no longer have) |
Thanks for the DIY. Made it much easier to install. Looks great. Got the spoiler from http://www.ebay.com/itm/170822526379...84.m1497.l2649, painted to specified color code of my car. Total cost $43.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Trunk Spoiler | jtsao | E34 (1989 - 1995) | 12 | 01-24-2008 03:10 PM |
| FS: E39 Hamann roof spoiler & OEM trunk lip spoiler | shardul | Exterior | 2 | 05-07-2007 05:25 PM |
| On the 3rd day of Christmas my e39 gave to me: Paint, M5 spoiler, and cup holders! | matteni | E39 (1997 - 2003) | 13 | 12-28-2006 06:11 AM |
| FS: E39 M5, or trade for E36 | trackstar | Cars - Private Party | 13 | 08-09-2006 12:43 PM |
| AC Schnitzer adjustable suspension | Alex Baumann | General BMW | 1 | 04-05-2002 09:33 AM |
