Old 03-01-2008, 01:14 PM
dwcondon dwcondon is offline
Mein Auto: 330ci
ABS light reset
Hi out there,
Anyone know how to "reset" the ABS light? I accidently disconnected the speed sensor doing a brake job. I have everything connected back up now but the ABS (and ASC) is still on.
Thanks,
Mein Auto: 330ci
OOPS. This is on a 2002 330CI
Old 03-01-2008, 01:20 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP & 04 Honda VFR
It should go out by itself after driving for awhile.
Old 03-01-2008, 01:37 PM
Mein Auto: 330ci
Smile Thanks
Thanks KrisL, a quick trip around the block turned the light out.
DC
Old 09-07-2011, 02:29 AM
BImmerDOM BImmerDOM is offline
Mein Auto: owner 2001 X5 4.4 200km
how long is a while ??? hope over night and a ride into work does the trick
2001 X5 4.4
Old 09-07-2011, 02:39 AM
TerraPhantm TerraPhantm is offline
Mein Auto: 2005 M3 Coupe
2001 X5 4.4
If the X5 is similar to the E46 in this regard, then it's not long at all. Maybe a minute or two
Old 09-07-2011, 02:54 AM
tried that =( is there a tool i can use to reset this? like an OBD scanner??
Old 09-07-2011, 09:42 AM
stuzor stuzor is offline
Mein Auto: E46
You could use a diagnostics tool to reset it, however if you have not rectified the problem then the light will just turn back on.
It seems a bit concerning that your car is telling you that your ABS is not working, however you are looking to try and turn the warning light off and ignore the problem? If you fix the issue properly then the light will go off after a minute or so of driving, and will stay off. ABS really can be a life-saver, I wouldnt ignore it!
Have a look to ensure that the sensor is connected properly, if this isnt solving the problem then it might be wise to do a diagnostic check to find out exactly what is causing the problem. You can get diagnostic code readers for dirt cheap on eBay.
Old 09-07-2011, 01:05 PM
Thanks Stuzor, but it all happen when I disconnected a few control module plugs under the hood.... =(
Old 04-24-2012, 10:49 PM
Cool
all woworked out drive, drive, drive, and drive some more maybe 1,000 miles or so but it should go off, if not maybe you should get a check.. but this happen to me and now the X% is running really well
