F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11) |
#101
My wife had my car last weekend on a road trip and she filled up with regular gas. Haven't noticed any decrease in performance--if anything, the car runs smoother. But there is a noticable drop in MPGs. I'm back to premium at my next fill up.
#102
Jungle juice.
2013 ///M5 Individual Monte Carlo Blue, Platinum Full Individual Merino, Platinum Alcantara, Piano Black, Exec Pkg, Drivers assistance pkg, Bang and Olufsen, 20" wheels, Eisenmann Sport, STIR+, LI Quad HP |
#103
Recent customers at the Marathon gas station at 2275 Buford Highway near Atlanta were treated to a fill of diesel from the premium pumps
Laser ___________________________ 2011 535i Black Sapphire Metallic, Sport, Euro Del (ret) 2009 328i Black Sapphire Metallic 2007 Honda S2000 Berlina Black |
#104
That's one expensive insurance claim for that distributor.
2011 535i Sophisto Grau / Oyster - Black Nappa, Anthracite Wood ZAV, ZCV, ZCW, ZDA, ZDH, ZPP, ZP2, ZSP Mods - M5 Grilles, BMWPedals Black Anodized Heaven is where the police are British, the cooks are French, the cars are German, the lovers are Italian and it is all organised by the Swiss. Hell is where the police are German, the cooks are English, the cars are French, the lovers are Swiss, and it is all organised by the Italians |
#105
That's why I don't use marathon or Thorntons
![]() Shell for me all the way!
Current: 2012 528xi. Delivery date 03/13/2012. Dark Graphite Metallic / Oyster-Black interior. Cold Weather / Premium / Technology pkg. BMW Apps. Rear fold down seats. Prior: 2005 530i. Cold weather/Premium Pkg |
#106
Hmm may be its just me... for some reason Shell is a big no no for me... BP get the best out of my cars!...
I tested them again in my F10 same thing... may be its just a placebo effect i dont know but with BP it runs very smooth and responsive ... too much jerky feeling with shell
#107
Thanks for the feedback. I ll try BP and see how it works
#108
You guys do realize that all the gas is the same, it's just got different detergents in it, right?
#109
#110
I always put Shell V-Power (91). I notice the fuel door actually says minimum 89. My previous X5 said minimum 91 on the fuel door.
I used to put Sunoco 93 (now Petro Canada) in my X5, but turns out that the extra octane rating is derived from adding ethanol. Shell V-Power has zero ethanol. I find that the BMW engines run better with fuels that have no ethanol.
2012 535 ix - Imperial Blue, Black Leather, Anthracite Wood |
#111
BMW fuel requirement from F10 manual
I just thought it would be interesting to see what BMW says about it in the manual and I was surprised.
Take a look at the attachment.
#112
Hmm thats interesting! So its not just my placebo effect?
#113
That is very interesting. No BP in Canada so do not know their fuel makeup. I wonder how much if any ethanol BP has in their fuels and if that is why BMW recommends BP. Shell in Canada says zero ethanol for V-Power right on the pump.
I will check the Canadian car manual and see if there is a similar recommendation.
#114
I've been using Costco 91 gas in my 335i since August and felt the engine getting progressively worse over time. Switched over to Chevron 91 a few days ago... and I'm convinced that it's much superior to Costco 91. The engine is quieter when idling, and the engine's much smoother on the freeway. The reason I switched is because the car would shake quite a bit at startup. Read on here that gas could be the problem. The shaking has gone now too.
#115
Joe Morris 2013 X3 28i (prem, tech, cold1&2, conv, hud) |
#116
Of course. But detergents won't make a difference in momentary running.
#117
#118
my real world test results, just did full tank with 87 recently and I get exact same mileage as with 89 and 91... I also don't notice any difference in power, nothing is knocking, everything runs as smooth as it can be... draw your on conclusions
#119
BMWCCA Member #458528 www.bmwcca.org "If Things Seem Under Control, You're Not Going Fast Enough" Mario Andretti |
#120
If you have a N52 528i, I can believe you. The 328 loaners are the dealer always are filled with 87 and they seem to run fine. The high compression, turbo 2.0T though? Runs like **** on 87
2011 BMW X5 xDrive 35d Vermillion Red Metallic/Black Nevada Leather Options: ZCW, ZPP, ZRC, ZTP, 300, 386, 496, 4AB, 6FL, Combox, LED Coronas. 04/11 Production |
#121
You can feed it 91 and above and be perfectly fine.
There are knock sensors that will retard your timing and do some other things when they sense pre-ignition ( knock) when you use lower octane gas. But don't use 87 ! In a naturally aspirated motor you can feed it almost anything and with knock sensors it will be fine . However when you do this you lose power and have to push the motor harder negating much of your savings by using the lower grade 87-89 octane gas. HOWEVER in a TURBO - I would not use anything below 91. Your power production will suffer dramatically and you just don't want today's high compression turbo motors struggling with less octane than they need. Back in the day before computers et al a turbo motor would have a low compression ratio 7 or 8 to 1 on average. Today the compression ration is pretty high- which is why we are seeing such high power being wrung from these relatively small turbo motors. Bottom line -no less than 91 for a turbo motor. If you chose to drive a turbo BMW- feed it what it needs to get what you paid for from the car. Cheers
Roy528 2013 528iX 2013 Porsche Boxster S 2011 Lexus GX460 Premium |
#122
turbo 4
#123
If you lease your BMW, then who cares, let the next owner worry about it. If you plan to keep it for a long time, use the factory recommanded octane.
#124
I use either Mobil, Sunoco, BP or Gulf 93 octane here in NY. I had to put one tank of 87 in the car (actually half) as a result of the Sandy nonsense, but now we're fully back on a 93 octane diet. I notice very little difference in performance.
Merry Christmas all.
2011 535xi Cold, Prem 1&2, Convenience, Driver Assist, folding rear seat |
#125
Hype
I ran a 2000 Jetta for 140,000 miles and tried different grade fuels with no perceptable change - a dealer mechanic said it was a great idea because he would get paid to clean my injectors - never happened. My Harley calls for 93 - it burns 87 fine. The BMW doesn't seem to know the difference - we put 70K on it. If a modern vehicle with electronic systems can't adapt to different fuels (winter grade, summer grade, etc), fix it, jumk it or trade it.
