Old 04-26-2012, 07:19 PM
visionthedj visionthedj is offline
Mein Auto: 09 750i M Sport
Red face Left turn signal malfunction
Hi all,
Just received a left turn signal malfunction on the iDrive on my 09 750i. Has anyone come across this? I did a quick search and couldn't find anything. Thanks!
Old 04-27-2012, 08:31 AM
oneofew oneofew is offline
Mein Auto: 2011 B7 Alpina
I have not, but first thing I would do check if all my blinkers are working
Old 04-27-2012, 10:28 AM
Leslierc's Avatar
Leslierc Leslierc is offline
Sejanus
Mein Auto: From BMWs to Porsches
I had the same thought. I remember when I owned Audis there would be a similiar type of warning when a bulb was blown.
Currently: 2015 Porsche 911 GTS and 2016 Cayenne S eHybrid
Past BMWs: `05 645CiC; `07 650i; `08 M6 convertible; '08 135i; `11 750ix MSport; `15 M235i convertible
Others: '11 Panamera 4S; '13 Boxster S; '13 911 C4
"You think that's air you're breathing now?"
-Morpheus
Old 04-27-2012, 10:35 AM
snowboardjoe snowboardjoe is offline
Mein Auto: 2013 X3 28i
Originally Posted by visionthedj View Post
Hi all,
Even a slight variance in voltage can cause an alert. The LCM checks the circuits constantly, even when a light is not on (cold check). If all of the blinkers are working (front, rear and side repeater), try reseating the bulbs--could be just a bad connection or not seated perfectly.
Joe Morris
2013 X3 28i (prem, tech, cold1&2, conv, hud)
