Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > F30 / F31 / F32 / F33 (2012 - current)
The sixth generation 3 series, chassis code F30. 2013 model year 328i and 335i sedans now in production. Read the F30 frequently asked question thread for all your basic question and dive into all the details in the ultimate F30 information thread.
Old 04-27-2012, 12:16 AM
loosenit2 loosenit2 is offline
Mein Auto: 2012 328i Luxury
Radio won't shut off until I lock the doors?
Curious if anyone else has this quirk. When I shut off the car the radio continues to play even when I get out and shut the doors. I could walk away for 15-20 minuites and the radio would continue to play, the only way to get it to shut off is to hit lock on the key fob. This is inconvenient as I park in my garage and like to leave the car unlocked, I have to lock and unlock the car to get the radio off but leave the car unlocked. Nothing in profiles addresses this, is there another trick or setting I could use?
Old 04-27-2012, 01:54 AM
Itinj6's Avatar
Itinj6 Itinj6 is online now
Mein Auto: 2012 650i Convertible
Try hitting the Start/Stop button a second time after you shut the engine down. Make sure your foot is off the brake or you will start the engine up again.
First press = Engine off
Second Press = Accessories Off
Many complain about this but I like it. It's no different than turning a key all the way back from Igntion to ACC and then to Off. You just push the button twice. It lets you listen to the radio still if you hear a good song after you park and don't want to continue running the engine... Or if you have some last minute cleanup to do, etc...
Old 04-27-2012, 05:23 AM
Thank you a ton!
Sent from my Kindle Fire using Bimmer App
Lance
Old 04-27-2012, 07:50 AM
energetik9 energetik9 is offline
energetik9
Mein Auto: waiting for the M4!
I wondered about this when I first got my 335. I quickly realized that if you just hold the start/stop button for a couple seconds it shuts everything off. I quick push just turns off the engine. In other words, just hold it a little bit longer. It's really a non-issue once you figure it out. Good luck.
Next - M3 or M4? (f32)
Current - 2010 128i convertible (wife's car)
Previous - 2009 M-sport 335i coupe
Previous - X5 3.0i with prem/sport
Previous - 2000 ///M roadster
Someone should invent a sarcasm font...
Old 04-27-2012, 07:59 AM
sr5959 sr5959 is offline
Mein Auto: 328i F30
Actually you should lock the car even in your garage. I've read on these forums that if you leave it unlocked various systems on the car stay 'live' which is not good for battery life or something.
Old 04-27-2012, 10:25 AM
laser's Avatar
laser laser is offline
Mein Auto: 2007 S2000
It takes two pushes. One long push won't do it.
Unless your second push is with your foot still on the brake.
Then it takes two more pushes to shut down everything
Laser
___________________________
2011 535i Black Sapphire Metallic, Sport, Euro Del (ret)
2009 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
