is this the plug? - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 04-25-2012, 11:28 AM
dcnaser dcnaser is offline
Mein Auto: BMW 2001 325CI
is this the plug?
2000 x5 4.4.
I want to check the fluid level in the rear differential. I only see one square plug. Is this the fill in and drain plug?
Old 04-25-2012, 11:36 AM
Also which fluid do i use? Also is the front transfer case have the same fluid?
Old 04-28-2012, 11:55 AM
gotrice415 gotrice415 is offline
Mein Auto: M3, 335Ci, X5d, 750i
There should be two plugs on the differential. There is a plug on the pass. side of the diff. The plug at the lowest point is to drain. The fill plug should be "mid diff" for checking.
