E36 (1991 - 1999)
Old 04-30-2012, 03:54 PM
bimmer claus's Avatar
bimmer claus bimmer claus is offline
Santa
Mein Auto: 95 M3
Bad bad and more bad
Well at 145k miles on my 98 323is the hg failed this morning was having intermittent coolant loss slight white smoke nothing major. However this morning it was blowing off steam like a freight train i am going to replace the hg regardless of high miles this car is my baby. To the point what i want to ask to all of you old time knowledgeable gentlemen is do i sell her off once its fixed and get a different one for fear of spinning a bearing due to the coolant in the oil for a month or two or do i just continue to run it and pray a whole lot ive always run full syn Valvoline and have stayed consistent on changes. Just hoping someone can shed some light on this topic THANKSSS
Old 04-30-2012, 03:58 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
I have two M52 motors in PA if you want one
Turbo Build Here
Old 04-30-2012, 06:25 PM
rooster1986's Avatar
rooster1986 rooster1986 is offline
Mein Auto: 92 325i
Keep it. If it would make you feel better do a good flush with sea foam. I recently did a hg with oil contamination and knock on wood it has ran perfectly for me.
Sent from my thumb to your eyes
Primered Black 92' 325i. Ireland Engineering Header, Ireland Engineering Catback, TMS Underdrive pulleys, TMS chip, Bav auto fpr, Power Flow cai, Bav auto coil packs, Cool Carbon pads, Eiback springs, Bilstien Sport HD shocks/struts, 3.23 LSD, Understeer short shifter, 16'' Spal Fan, Goodridge Steel Brakelines, M3 Bumper, Black out grill, clear tails, M3 mirrors.
Old 04-30-2012, 06:34 PM
Santa
Mein Auto: 95 M3
through the brake booster line or straight into the crank? aka oil.
Old 04-30-2012, 06:38 PM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: big turbo hellrot sedan
You might want to look into an s50 or s52 swap
you can usually find them for a good price if you look around and you will be more happy with your baby when she pulls you to the seat every time you go near the throttle
Turbo lag is just a headstart because the chase is more exciting than the win - Abraham Lincoln
Old 04-30-2012, 06:40 PM
Santa
Mein Auto: 95 M3
how much is an s52 or s50 swap though i mean this cars solid no rust perfect body so it might be worth it but im not sure if im up to tearing the whole bay apart but ill have to look into it
Old 04-30-2012, 06:44 PM
Mr Gusta's Avatar
Fireballs inc.
where in ny are you located?
sometimes you can get lucky and find the engine for 1000 to 1200 and trans around 300
I know someone with an s50 if you want me to look into it for you
Old 04-30-2012, 06:49 PM
Santa
Mein Auto: 95 M3
cars an automatic id love to swap to a manual prob would be a p i a though would have to change knuckles axles = a probable no so id probally have to do a swap for just the engine pull motor and tranny then swap over im not sure though i mean if this thing will keep running ima just run her
Old 04-30-2012, 06:50 PM
Mr Gusta's Avatar
Fireballs inc.
you can swap to a manual its easy
I have the pedals you need, the only thing you have to swap out it the front half of the driveshaft and everything else is bolt in and light wiring
Old 04-30-2012, 06:52 PM
Santa
Mein Auto: 95 M3
hmmmm man this might turn into my summer project haha might just buy a beater to run around in and tear this sucker apart then esp if its only a grand or two for the swap
Old 04-30-2012, 06:54 PM
Mr Gusta's Avatar
Fireballs inc.
try not to set a budget because things always pop up but if you think you can do it yourself all the information is out there I suggest you get to researching and knowing your car in and out before trying it.
Old 05-01-2012, 09:01 AM
Santa
Mein Auto: 95 M3
Shes almost back together heads off tonight then just the re-assembly ill keep everyone posted on if she runs fine thinking about swtiching from Valvoline full syn to Castrol seems to have a better rep.
Old 05-01-2012, 09:24 AM
hornhospital's Avatar
D'oh, You Kids!
Oil type (dino or synth) and a weight that's appropriate for you climate and type of useage are more important than brand. I used Valvoline for 40 years and never had an oil related engine failure, but when I got into BMWs I started using full synthetics, sometimes Valvoline, sometimes Mobil 1, sometimes Royal Purple., depending on what's available at the time in the grade I need.
Quotes to live by:
Old 05-01-2012, 10:25 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
You took the head off in one day?
GGC BMW CCA #443004
Join the BMW CCA!
Old 05-01-2012, 06:30 PM
Santa
Mein Auto: 95 M3
took the head off ina day and and a half ima just stick with valvoline i think ran my 318 to almost 230k before it nickel and dimed me to death so i think ima stay that route. head has no warping or cracks so thats a plus going to be another couple getting her cleaned and put back together ill keep posting
Old 05-03-2012, 07:52 AM
Santa
Mein Auto: 95 M3
Well this may be the end of my baby heads cracked and realllyyy bad cant find one anywhere for under a grand so im not sure.. sucks.
Old 05-03-2012, 08:10 AM
DEATH2000's Avatar
DEATH2000 DEATH2000 is offline
Mein Auto: 1998 BMW E36 328i,
You cant find a head for under $1,000? Thats not right. I have heard of machined ones for $200-300.
ProjectTechnik.com - Alberta based BMW Community
See My car on Project Technik HERE!
| OE M3 Bumper | M3 Mirrors | Jim Conforti CF CAI | UUC Motorwerks Underdrive Pulleys | 18x8 ASA AR1's | Koni Sport Springs & Shocks |
Founding Member of the Canyonrot Club! #343!
Old 05-03-2012, 08:17 AM
Santa
Mein Auto: 95 M3
im still trying to find one cant find one anywhere at the moment ill have to keep calling around
Old 05-03-2012, 09:12 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
http://tinyurl.com/cpeatln
http://tinyurl.com/bv5a8cp
Here's a few dozen. (Yes confirm they fit an M52 engine before buying.)
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 05-03-2012, 09:16 AM
petriej's Avatar
As long as the block isn't cracked (hell, even if it were, S50 swap time!) you should be fine replacing the head.
GGC BMW CCA #443004
Join the BMW CCA!
Old 05-03-2012, 09:23 AM
Santa
Mein Auto: 95 M3
Seriously thinking about just buying a e39 5 series and saving this bad boy for an engine/tranny swap and a supercharger i deffinitley wanna fix her right but dont have the means at the moment hell if the block is pulled it might be supercharger time too :c
Old 05-03-2012, 01:39 PM
Needs Boost
Mein Auto: Red Sled
Umm, yello?
I can sell you an entire M52 for $900.
Turbo Build Here
Old 05-03-2012, 07:30 PM
Santa
Mein Auto: 95 M3
UPDATE! found a whole m52 head for 450 shipped out today getting it fridayyy cant wait to get her back on the road! thanks fender but id go m50 swap if i was going to do a whole engine huge fan of ur turbo nubz write up thats one sweet e36
Old 05-03-2012, 07:38 PM
jonesin's Avatar
The Canadian Prick.
Did you not bother to click on either of the links I'd posted?
I gave you several dozen for under that price...
Old 05-03-2012, 07:41 PM
D'oh, You Kids!
He probably was afriad to click the links, fearing he'd get Rickrolled.
Seriously, beamer claus, that's WAY too much for a head.
Quotes to live by:
headgasket failure advice
