How many orings per injector - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 04-30-2012, 08:09 AM
Bugsie Bugsie is offline
Mein Auto: BMW E34 M50 2.5
Hi all. I want to change all the orings on my m50b25 injectors.
I found on realoem the reference but theres no indication on number to order.
I want to replace them all, the little black fat orings. Are there more orings to replace and again the quantity?
Best regards
Old 04-30-2012, 08:17 AM
nwilson44 nwilson44 is offline
Mein Auto: 2002 BMW 540i/6
I had to do that on mine before i got rid of it. I bought them from an auto part store and then i got the urge to go compare them to the ones at the dealer. The ones from the dealer are significantly harder to squeeze if you try to. They are kind of expensive but they are noticeably higher quality. So i bought those and took the ones from the autopart store back. Just my observations. Good luck. Just go to your local BMW part store at the Dealership.
Old 04-30-2012, 08:30 AM
Monsignor's Avatar
BMW CCA Memeber #445389
Mein Auto: Sig
I believe it's one per.
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 04-30-2012, 10:00 AM
1995i540's Avatar
1995i540 1995i540 is offline
Founder @ Maintenr
Mein Auto: 1995 540I/6
I think there is very small one on bottom of injector and a bigger one on top.
///////////////////////////////////////////// E34 Addicts
Founder @ Maintenr. Take control of your vehicle maintenance.
Old 04-30-2012, 10:22 AM
Monsignor's Avatar
Mein Auto: Sig
^ yeah, I was thinking. That, inlet out outlet of the inject, from the rail to the injector, injector to the head
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 05-01-2012, 01:40 PM
Hi all. I'll get mine from local agent. Those little are not that expensive and I decided to get all those tiny parts from the local agent.
The reference that I found on RealOem are from those fat ones that are between the fuel rail and the injector. I couldn't find any other references.
The truth is that they are screwed to the head so I believe there's some oring or no oring but that must be together with the injector.
Best regards
Old 05-05-2012, 11:54 PM
Banned
Mein Auto: car
Bugsie, i can't quite figure out what you mean by the fat o rings (as opposed to thinner ones presumably) that you're referring to in your post here. To my mind, there is only one O ring per injector. Would you mind posting the part number of the O ring you are referring to, extracted from realoem.com?
Old 05-06-2012, 12:07 PM
Hi all. Of course I can. When I state "fat", visually it's thicker than most orings.
Anyway, the reference: 13641730767
Old 05-10-2012, 07:35 AM
TemporarySanity's Avatar
TemporarySanity TemporarySanity is offline
Mein Auto: 02 530, 02 540, 07 525
My e39 has two per injector but can't say for sure on the e34.
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot.
Old 05-15-2012, 07:36 AM
1995i540's Avatar
Founder @ Maintenr
Today, 12:55 AM
Originally Posted by 82nd Anbn View Post
My god man it's two!!!! I am under the wrong impression about this place. I came here for help and nobody can give this man a definitive answer and I have only had a car for two weeks. Two per injector. I just ordered 16 to replace mine. Does anyone no anything aside from driving and buying upgrades for there cars on this forum? I can't even get an answer as to where an alternator cable bracket goes after 100 members looked at my thread. You would think someone might help by opening there hood and looking for me. I am in the wrong place. Sorry for the rant fellas but I call it like I see it. I figured out how to put together and install an M60 engine in two weeks. All you need to do is lull an injector out and look. Might take a half an hour tops.
04-30-2012, 09:00 AM
You are cool.
Old 05-22-2012, 01:10 PM
Hi all.
Thanks for all the help, especially 82nd.
Two per injector that was my guess. Thanks again for the help
