X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here. |
#26
Only compared to BMW pricing
Same as I used, but I do not like the jug and spout so decanted 1 liter at time to open jar container and then with funnel into reservior, saves spills
#28
Current BMW's: 2011 535xi M Sport TiAg / Black, ZPP, ZP2, ZCV, ZCW, ZDA, 2TB, 6NR, 465, 5DL, and a Partridge in a Pear Tree 2011 X5 35D Deep Sea Blue / Oyster, PP, SP, PSP, CWP, Tech, 20" 214's Prior BMW's 2008 ///M3 Vert 2008 X5 3.0 2007 X5 3.0 2006 X5 3.0 2006 550iA SP 2003 540iA M-Sport |
#29
Current BMW's: 2011 535xi M Sport TiAg / Black, ZPP, ZP2, ZCV, ZCW, ZDA, 2TB, 6NR, 465, 5DL, and a Partridge in a Pear Tree 2011 X5 35D Deep Sea Blue / Oyster, PP, SP, PSP, CWP, Tech, 20" 214's Prior BMW's 2008 ///M3 Vert 2008 X5 3.0 2007 X5 3.0 2006 X5 3.0 2006 550iA SP 2003 540iA M-Sport Last edited by quackbury; 05-01-2012 at 11:17 AM. |
#30
BMW **does** cover DEF under the maintenance plan, hence by their own definition it is a covered maintenance item. (This addresses the washer fluid and diesel fuel arguments, which are NEVER covered). BMW then seeks to exclude DEF outside of a normal oil change visit by using the same legal boilerplate that they had used to exclude interstitial oil services...the problem is that this language is not applicable to the DEF warning. If you read the actual text, your probably say "Huh, that sure is weird...ard is right"..Maybe ![]() On the Oil (should they give you oil if the CBS says "Add oil"), the answer is 'yes'. And I think that BMW WILL in fact top off your oil when low. But as we both can probably agree, going to the dealer for oil OR DEF top offs is a waste of our time.
Keep it as simple as possible...but no simpler. |
#31
Def Refill
Just did mine today. Bought three 2.5 gallon jugs at Fleetfarm for $12.99 each. Filled the passive tank first, took just under five gallons. Filled active tank last, took just about 3/4 gallon. Done in 15 minutes including wiping everything down to avoid the dreaded white stains. Very simple with a basic funnel. Will have oil changed in next month to complete the cycle. Very easy to do. As simple as adding washer fluid.
