The Detail Department
Detailing tips, tricks to keep your bimmer in showroom condition. |
All:
I'm reaching out for help using my autogeek.net foam gun. Since I've had it, I've had inconsistent results producing foam, and at times alarming use of soap. I am certain I'm doing something wrong. I searched on here for some basics but found nothing. Been using Meguiar's Gold Class wash. A forum member here who's way more into detailing than I am (an who has been exceedingly patient in helping me out!) suggested it and swears by it. I'm just not getting a good foam that clings to the car like I see in some of the videos. Any pointers, tips or reading I can do? Thanks!
2011 535i Sophisto Grau / Oyster - Black Nappa, Anthracite Wood ZAV, ZCV, ZCW, ZDA, ZDH, ZPP, ZP2, ZSP Mods - M5 Grilles, BMWPedals Black Anodized Heaven is where the police are British, the cooks are French, the cars are German, the lovers are Italian and it is all organised by the Swiss. Hell is where the police are German, the cooks are English, the cars are French, the lovers are Swiss, and it is all organised by the Italians |
I would not expect you to get thick clinging foam using just a "car shampoo" product. Most of the video's you will see use a dedicated "snow foam" and probably for visual effect are heavy handed with the quantity!
My suggestion (and what I do, as I don't want another product to use) is put a cap of "APC" in with the "car shampoo" (as I always have APC for various tasks), the APC foams up and cling to the paint work, I expect any APC will do but I use Meguiar's. |
Interesting. I have P21s. I worry that would be harsh on the sealant coat (Wolfgang).
gold class is ok but a few are much better - look at ultima wash, chem guys glossworkz or max sudz II - put 2 oz in the gun and make sure the mixer switch is straight upo and down...I get plenty this way
all wax friendly...
'12 Z4 2.8 - Melbourne Red '09 Accord Coupe LX-S - Red/black RTOM..... |
I had Ultima wash but felt like I was using so much, the bottle lasted me no time at all.
2011 535i Sophisto Grau / Oyster - Black Nappa, Anthracite Wood ZAV, ZCV, ZCW, ZDA, ZDH, ZPP, ZP2, ZSP Mods - M5 Grilles, BMWPedals Black Anodized Heaven is where the police are British, the cooks are French, the cars are German, the lovers are Italian and it is all organised by the Swiss. Hell is where the police are German, the cooks are English, the cars are French, the lovers are Swiss, and it is all organised by the Italians Last edited by Needsdecaf; 05-01-2012 at 08:11 PM. |
It's all about water pressure. If your water pressure is too strong than no matter how much soap you add to the reservoir, it's not going to matter because the mixture will not come out in a consistent manner that is conducive to foam.
Solution. Shut off valve and quick disconnect. This single hose connector can be used to connect two standard hoses, or as a quick on-off switch to your hose. The swivel connector gives you maximum maneuverability with the hose by allowing the hose to turn where it connects to the spigot. This valve can also be used as an inline shut-off valve. A quick turn of the valve shuts off the water flow so you can turn the water on and off as needed for jobs that don’t require constant water flow. Constructed from brass, the shut off valve can withstand hot water and high water pressure.
Two "Must Have" Car Washing Tools - The Brass Shut-off Valve & Brass Quick Connector P.S. - I use Gold Glass Shampoo 3-5 oz in the gun resevoir then fill remainder with water. Then shake the mixture like a martini. I turn the water pressure way down with the valve and the foam is so thick that I don't bother with a 2 bucket method, I only have a rinse bucket. ![]() Also, you can buy all of this at Home Depot for like 5 bucks.
Hey man. Yeah, I've got the valve, perhaps I'm just not shutting it enough?
What setting do you use the gun on?
Yeah, I get that much foam, but it runs through FAST. It also doesn't cling like it does in most videos...
It won't cling because your car has wax on it. A lot of times you will see this done to cars that have been neglected.
you could also get a pressure washer, but if you're only washing a couple cars, it seems like kind of a waste, but I'm sure it will be fun. Does a better job at laying down a thin uniform soap pattern.
http://www.autogeek.net/autogeek-foam-cannon-hp.html
