E36 (1991 - 1999)
Stuck and stripped o2 sensor bolt/nut. What should I do?
It appairs that these o2 sensor may even be the originals from 1998, the guy I bought it from had NEVER done any manteinance to this car. So I'm stuck with all the homework.
I already sprayed PB blaster LOTS of it. Left it alone for a while. Ran the car so they would warm up. Blow torched the **** out of it. And after all this the nut ended up getting all stripped. What should I do at this point? Thanks for your help in advance. This is how both o2 Sensors look like...
What part did you heat up? You're supposed to heat the pipe it's in, not the nut/sensor. Expand the outside part, not the piece that's in it. Heat the pipe and the fitting the O2 sensor screws into RED hot, but try to keep the heat off the sensor itself as much as possible, then go after the sensor with Vice-Grips as tight as you can apply them. This will probably be best done with the pipes OUT OF THE CAR.
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
You could probably have an exhaust shop cut it out and weld a new bung in place. It should cost like $20 for labor and a new o2 sensor can be had for ~ $50-100 depending on how mechanically inclined you are.
Mine were on pretty good, too. I had to use a bar to get enough torque on my wrench. It looks like yours are boogered up, though. Vice grips might be your only option sans cutting it out.
GGC BMW CCA #443004 Join the BMW CCA! 2005 X5 4.8is Le Mans/Black/6spd Steptragic ![]() 1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual ------------------------------------------------------------------- 1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012 2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011 |
Didn't you use the o2 sensor wrench from auto zone?? It's impossible to strip it with that wrench, what exactly did you use to get it so fakked up?
There is still enough there to bite if you use the right tool. Might try using a hammer and chisel or punch, whack the thing a few good times, and see if the shock will break it free. If you have a friend with an air compressor and an air chisel the sensor would be out in seconds.
Cars are much more compact if you don't take them apart. There is a theory which states that if anyone ever figures out how and why the universe came to exist it would instantly dissapear, and a less rational, more complicated one would replace it. There is another theory which states that this has already happend... |
fuuuuuu
this is what i forgot to buy at the parts store today. Ughh
nothing.
as ken suggeted, heat the pipe up red hot and then apply torque to the sensor. worst case scenario, cut the wires and slip a box end wrench on it. btw, i like the 1st sample, not the 2nd... df
this is gonna be good!
dab of oppo anyone? Project List: Replace coolant temp sensor Replace starter Brake and Power Steering Fluid Flush Front Control Arms, Bushings, and Tie Rods Replace Passenger Lock Actuator Reglue Peeling Hedliner Swirl removal |
Hornhospital: I did burn the pipe but there were no redhot metals. These o2 sensors are old and are getting replaced so it doesnt matter if they get extra hot.
KaptinKP: I got the replacement Bosch o2 sensors for 75 bucks. All I'm trying to do is take the old ones off. And I would have no clue on how to remove the pipe. So I will leave that as my last resort. petriej: I did use a bar to get better torque and it just kept slippin RhymeGrime: I did and it fited perfectly but as I pulled it just ****ed it up. Then I tried the grips and that just made them worse. jaguarx7: I do have an air compressor but not the tool, so Ill just go oldshool with the hammer and chisel. drivinfaster what sup, thanks again for the help. I saw those sockets at autozone but didn't think either would help with such little room to use them. But I can defenatelly buy one and try it out . veteran011: Lul Everyone thanks for the help. Sorry I took a while to reply I spent the weekend at Dells, WI. I'll try all these tomorrow and report back with my findings. |
The purpose of heating a stuck threaded joint is to expand the piece holding the part that's stuck in it. That will loosen the fit enough that hopefully the piece will unscrew, but you have to get the outside piece at minimum RED hot.. Keeping the heat on the outside part and off the sensor as much as possible keeps the sensor from expanding as much as the outer pipe.
By heating both pieces you were defeating the whole purpose of using heat. You just as well have not used the torch at all. I know you can't help getting the sensor hot to some extent, but concentrate the heat on the pipe.
I'm replacing the pre-cat o2 sensors this weekend. I'm gonna take this thread as a list of things to avoid. haha. good luck dude. KP may be on the right track though. dropping the mid-pipe will give you more clearance (and leverage) and hopefully let you get a better grip.
| Tags |
| :3, oxygen, rusty, sensor, stripped, stuck |
