E30 (1982 - 1993)
Old 04-19-2012, 05:59 PM
theo23 theo23 is offline
Mein Auto: 1987 325is
white exhaust smoke
My 1987 325is exhaust has white smoke coming out when i have the car in park & rev the engine past 2000rpms. Possible problems & fixes?
Old 04-19-2012, 07:01 PM
downhiller's Avatar
livin large
head gasket or cracked head. first thing to do, pull the head and figure what went. then figure what you want to do from there (new hg, new head, full rebuild of motor, motor swap, boost)
have fun
Old 04-20-2012, 12:02 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
Is it up to operating temperature, or immediately after starting? It could be just moisture in the exhaust system being evaporated and expelled as the engine heats up.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 & New Member Intro Forum Mod/Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426 Which is worse, ignorance or apathy? I don't know, and I don't care!
1995 318is "Bebe"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 04-28-2012, 01:28 PM
after cold starting, until it warms up
Old 04-28-2012, 02:11 PM
downhiller's Avatar
livin large
does it only happen on cooler mornings with mid to higher humidity? normal.
if it happens all the time, no matter the temp or humidity levels, and after the engine warms up, youve got yourself a problem.......a big one.
Old 05-03-2012, 04:02 PM
cooler mornings, & on the first startup of the day. after the car is warmed up, no smoke
Old 05-03-2012, 08:21 PM
downhiller's Avatar
livin large
thats normal. if you want to true answer to it, search dew points. not mountain dew, but meteorology. then its really just a matter of understanding simple physics with temperatures
Old 05-08-2012, 09:54 AM
Helmet Ludendor Helmet Ludendor is offline
Mein Auto: 89 coupe
If you believe you have a problem pull the plugs and take a look. They will tell you if you have a head leak 95% of time.
Old 06-01-2012, 08:24 PM
replaced the plugs & ignition wires about 2 months ago. everything seems better now that the morning temps are warmer.
Old 06-01-2012, 09:19 PM
woodenbmw's Avatar
woodenbmw woodenbmw is offline
Mein Auto: 1987 BMW 325
What would you see on the plugs if you have a head leak ? I am due for a change shortly and I am also having acceleration issues. No smoke, she just seems to not have that get up and go any more.
Sent from my LG-LS855 using Bimmer App
Old 06-02-2012, 01:08 PM
downhiller's Avatar
livin large
the plugs will look brand new. where under normal conditions, the spark plugs will have a orange burnt crap on the insulator.
Old 06-02-2012, 02:15 PM
woodenbmw's Avatar
Thanks for the info.
Old 06-17-2012, 08:01 PM
your plugs will be used or burnt, they should look new when you pull them, also you might want to change your ignition wires & tune the car up.
Old 06-18-2012, 07:56 PM
downhiller's Avatar
livin large
what are you referencing? the way i read this post, youre logic is near epic failure
325is, exhaust, smoke
