Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 04-09-2012, 10:30 PM
Blaque47x Blaque47x is offline
Blaque47X
Mein Auto: 2007 BMW 650i
Cool xenon headlamp replacement
Had driver side headlamp go out on my 650I, found out it can be a bear, so added a few pictures to
help the next person out..
Pictures will detail sequence of removal and replacement of bulb, which will require removal
of front tire,depending on which bulb you are replacing.
Good Luck!!!
ID:	320421   Click image for larger version
ID:	320422   Click image for larger version
ID:	320423   Click image for larger version
ID:	320424   Click image for larger version
ID:	320426   Click image for larger version
ID:	320427   Click image for larger version
ID:	320428   Click image for larger version
ID:	320429   Click image for larger version
ID:	320431   Click image for larger version
Old 04-10-2012, 10:52 AM
stevelee203 stevelee203 is offline
Mein Auto: 2006 BMW 650I CONV. Sold
awesome nice thanks for photos
[/SIGPIC][/SIGPIC]2006 BMW 650I Convertible Black Saphire Metallic / Black
SMG
Premium Sound
Sport / Cold / Comfort Access
19" OEM
Logic 7 Premium
Sound HD Radio
Heads Up Display
Park Distance Control
K&N air filter
Aluminum Racing Pedals
6000k headlight upgrade
fog light upgarde
2010 MV AGUSTA F4 titanium/RED frame
2010 Audi Q5 S Line
Old 04-11-2012, 03:25 AM
Yorgi's Avatar
Yorgi Yorgi is offline
Great pics. Thanks.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 04-15-2012, 02:57 AM
Blaque47X
Talking Xenon headlamp replacement
Hi There,
I appreciate the response and am very happy it was found to be helpful..Luv the site and
contribute every chance I get..
Enjoy!!!!!
Old 04-26-2012, 04:57 AM
DASHZNIT DASHZNIT is offline
Mein Auto: 2005 645ci
Thank you!! Just what I was looking for.
Sent from my PC36100 using Bimmer App
Old 04-27-2012, 08:00 PM
Bigrob52 Bigrob52 is offline
Mein Auto: 05 645CI
Thanks for the heads up!!!!!!!!!!
Old 05-04-2012, 07:34 AM
Blaque47X
No problem,glad it could help!!
Old 09-11-2012, 01:47 PM
j_luisito j_luisito is offline
Mein Auto: 2007 650i Convertible
Blanque47x,
Great pics, thanks. Which bulb did you end up buying (type and brand)?
I need to know which type is the closest one to the one the car came with from manufacturer.
Thanks.
Jose Luis
Old 09-15-2012, 11:58 PM
Blaque47X
HI THERE,
PICKED IT UP FROM EBAY..
BMW Xenon headlight HID D2S BULB LIGHT LAMP
SELLER WAS :
factory_oem_xenon
HOPE THAT HELPS..
Old 10-13-2012, 11:33 AM
theghoul theghoul is offline
Mein Auto: 650i
Hey, just want to say thanks for this. Almost got raped at the dealer for $750 for R&I for 2 bulbs.
Old 10-15-2012, 12:31 AM
Blaque47X
No problem....had same dealer issue..
Good luck!!
Old 12-03-2012, 07:49 AM
CJ645Bern's Avatar
CJ645Bern CJ645Bern is offline
youtube.com/lidlgangsta
Mein Auto: 05' 645ci & 01' z3
i thought you had to remove the bumper? or is that for certain years?
live fast, drive faster
2010 Acura TL (daily driver)
2005 BMW 645ci Coupe (traded for TL)
2001 BMW z3 3.0i vert' (TOTALED RIP)
1991 NISSAN 300zx 2+2 (gave to brother)
2007 BMW z4 (traded for 6er)
Old 12-03-2012, 11:22 AM
Blaque47X
Hi..
I don't know about that,however I would not think that would be necessary for any year!
Old 12-06-2012, 01:28 PM
AB's Avatar
AB AB is offline
Don't worry, be happy
Mein Auto: '11 Porsche Carrera S
Great thread, thanks! I am unfortunately in the need to replace my driver side xenon as it is turning pink.
What I don't understand is what you are saying about the removal of the front wheel, depending on which bulb you are replacing. Can you clarify this a little bit please? Also, approximately how long did it take you to do this?
Thanks again!
Old 12-06-2012, 10:00 PM
Blaque47X
Wink
Hi There,
If the side marker bulb needs replacement,because of its angle, you may want to remove the tire to give you more area to work in..Speaking for myself, if it happens again,
I will definitely remove tire..
Now as far as time, I would say give your self about 2 hrs, depending on how nimble
or fat your fingers are..
My hand is big, so I had rough go at it...
Blaque47x
Old 11-22-2013, 10:41 AM
Cricket Cricket is offline
Mein Auto: 650i
Nice photos. Thanks. Are there some written instructions to go along with the photos? For example, I have removed the flap, the sealed cover, and the ballast, but it is unclear how to removed the plastic locking ring and hence the bulb? More detailed guidance would be appreciated.
thanks
Tim
2007 650i convertible.
Old 11-30-2013, 03:01 PM
Vlad Dracul Vlad Dracul is offline
The prince
Nm
Old 11-30-2013, 03:18 PM
Mein Auto: 650i
I am not sure if this applies the 645 but it worked like a charm for my 2007 650i. I did not need to take out the wheel as there was sufficient space for my little hands. There was a little trial and error in terms of which way to turn the parts but everything went back together just fine. Total cost $65 for the bulb from Amazon. Total time: About 20 minutes. This made the $440 estimate from the BMW dealership all the more ridiculous.
Tim
2007 650i
Old 11-30-2013, 06:49 PM
Mein Auto: 05 645CI
It also worked on my 05 645CI just took a little longer but did not have to take off the wheel or anything it works great now.
Old 04-01-2014, 06:23 AM
shan904 shan904 is offline
Thanks for the pics they were very helpful! I changed out my driver's side headlight last night but it still isn't working and in the process my halos went out on the driver's side (they were working fine before). Any idea what could be wrong?
Old 06-12-2014, 05:16 PM
The prince
You get this figured out?
Old 06-13-2014, 06:50 AM
oRIDDLERo oRIDDLERo is offline
Mein Auto: 2006 BMW 650i
Thanks =]
Old 06-16-2014, 12:36 PM
karlanttila karlanttila is offline
Niemals Zu Schnell
Mein Auto: 2008 BMW 650i Sport
Autozone sold me Sylvania HID OEM that turned out to be exactly the Osram OEM bulb that came with the car. $99/bulb. Made in Germany, the exact part #, the whole deal!
Old 06-23-2014, 10:27 PM
Eval6series Eval6series is offline
www.AutoBadges.com
This makes me want to try to do my own headlight swap.
The dealer I got the car from got me replacement bulb but I don't know the brand or temperate of them
2007 650i Convertible - 20" True Forged 3 Piece Custom Rims
MagnaFlow cat back exhaust system
  #25
Old 06-23-2014, 10:30 PM
www.AutoBadges.com
Any ideas?
