E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
active steering warring plz help
hey i just got this 05 545i from an auction it has 89k miles on it when i had my brother go pick it up for me they had to jump start it then it died after he drove about 500 yards off the lot i think they might have shocked the computor? i had my friend work on it he did the breaks replaced collent hose,flushed radiatior and toped off the hydraulic powersteering fluid, put new belts in it and a new battery in it. but when ever i start it it has a kinda rough idle to it and a active steering waring comes on and the passeger airbag warning aswell other than that it runs good and turns fine other than the steering being a little stiff this is my first bmw ive been told that all their steering is a little stiff. anyways i took the car to a bmw shop in my area and they said they couldnt completely get in to the computer due to sensor problem and they said it would be 1200$ for the sensor in the steering wheel ive been researching it and ive been coming up with a steering angle sensor does this sound right? or has anyone encountered this problem?
Your spelling is dreadful.
2008 550i M Sport Carbon Black on Black 6AT SAT When in doubt, find row zed. |
I'm not lookin for a spell check.... I'm just lookin for some advice
it has DIY for sensor replace here or 5series. Search
BMW CCA Member, Capital Chapter |
Start with the below link: http://www.bimmerfest.com/forums/sho....php?p=6709271
----------------------------------- Nube1Kenobi 2008 535i Monaco Blue/Dakota Black/Dark Poplar | Sports Package | Premium Package | Cold WX Package | Navigation, Voice | RTTI | PDC | L7 | HD | I-Pod/USB | PWR rear shade | Sports Auto - paddles | Active Steering | Comfort Access | Fold Down R/seats | Rear DMS Airbags | Adaptive Xenons | Now with recalled and replaced -446 HPFP Do not argue with an idiot else he lowers you to his level and beat you down with experience.. |
And The blinkers dont want to shut off after turning
Think about it...
Blinkers won't extinguish because the computer has no idea where the steering wheel is. Thus, it cannot utilize the auto-extinguish function through the steering wheel position alone. The computer has no idea where the steering wheel is because the _________ (3 words) is malfunctioning. There are many other items in the stability control system that can cause the warning also, but the ___________ (3 words) is one of the most common causes. After fixing this problem, the active steering warning will most likely go away, but there is a chance there are other problems too.
2004 BMW 530i (his) -Titanium Silver -Grey Dakota -Dark Poplar -Premium -Sport -Cold Weather -Xenons -Heated Rear Seats -Active Steering -Logic 7 -Sirius 2010 Lexus RX350 AWD (hers) -Smokey Granite Mica -Black -Premium -Comfort -Nav -Tow Prep -Premium Sound -Wood Steering Wheel/Shifter |
Thanks for the replies i really appreciate so i need to find a streering angle sensor is ther a good sight I coul find it on I can't find them anywhere on google or eBay
Try www.realoem.com for parts and part numbers, and http://tis.spaghetticoder.org/e60/ for DIY's.
You will find that one error may effect other systems as well so it may be necessary for one problem to be fixed in order for programming to work on something else. I hope you did your homework before jumping into an auctioned e60. Since you are new to this forum, the other seasoned members should have just filled you in on forum etiquette such as coherent sentences and searching thoroughly prior to posting... but evidently someone didn't feed the animals...
Deceased - 2004 BMW 545i Black/Auburn -Sports Suspension, Premium and Cold Weather Package, Logic 7 Professional Audio, Rear Sunblinds, Adaptive Xenon Headlights, Active Steering, staggered setup on 124's, Aux Input Mods MTEC V3.0 AE's, Black and white roundels, Clear LED Side-markers, New Conti ExtremeContact DWS's, Charcoal Filter Delete, 35% Tint, 20%rear. http://s705.photobucket.com/albums/w...%20BMW%20545i/ GARY BETTMAN IS A TOOL! |
Here are the OEM part numbers. The MT one is $50ish, the AT one is mid $200s.
For MT you need: 32306765857 For AT you need: 32306765858
As ChelseaFC stated, learn how to post- you're asking for free advice, and doing so quite rudely. Let me guess- You're trying to get this thing half presentable so you can sell it, right?
Ok I'm sry for any inconveniences I have caused any one. Thanks for all the input i really appreciate it!
http://bmwpartssource.com/parts/inde...&siteid=216042 You can use the spaghetticoder link instruction to remove the necessary parts to get to it and then follow the attached SIB. No programming required.
How bad would it be to drive it with that sensor being bad I have to go back home it's a 1300 miles away every thing seems to be fine other than the active steering and rough idle I plan on fixing it as soon as I get home..
If its only the steering angle sensor that's triggering the A/S warning, the only functionality you are losing (aside of the turn signal auto shut-off) is the increased steering ratio at lower speeds.
Don't know what causing the rough idle, but from a handling perspective you should be fine to drive it.
cheers vern
[QUOTE=Jaycal3;6810479]Try www.realoem.com for parts and part numbers, and http://tis.spaghetticoder.org/e60/ for DIY's.
QUOTE] It's forum tips like these that enabled me to maintain two previous BMW's and will definately enable me to maintain this one as well )in order to find the really useful information that you are looking for at the moment and for later occassions. Many thanks to members like you who provide useful and valuable information that will serve us all.
2006 550i Titanium Gray, Sports Package, Premium Package, Heated Seats, Navigation, Logic 7, Sirius, M-Tech Kit, PDC |
Would a used one work? the guy at the shop said i need a brand new one, and it needs to be registered to the cpu
nube gvae yuo all teh inof yuo knead. did yuo reed teh hole linc?
BMW 545i-Sold BMW 650i-Sold BMW 335i-Current BMW 550i-Current |
Has anyone been able to make this repair using that kit? Any help in me finding one would be appreciated. |
Anyone?
| Tags |
| problem solving |
