Old 04-28-2012, 01:37 PM
RON7165994 RON7165994 is offline
Mein Auto: 2004 745LI
Winkfp
WHERE DO YOU GET THE FILES FOR WIN-KFP TO WORK ARE DO ANY ONE HAVE THEM I CANT FIND THEM IN THE SEARCH
Old 04-29-2012, 02:21 AM
Bump
Old 04-29-2012, 03:29 AM
PAPER's Avatar
PAPER PAPER is offline
CRISP & CLEAN
Mein Auto: Ford Pinto
Winkf files are a standard install with INPA , NCS & Everything else . If you don't have have it running properly , check your other installs also
Sent from my GT-N7000 using Bimmer App
Old 04-29-2012, 09:52 AM
When i run it has no files in it
Old 04-29-2012, 10:28 AM
Khabar Khabar is offline
Mein Auto: 745i 2005
i have the same problem SP daten folder is missing
Old 04-29-2012, 10:41 AM
that i need. paper do you have a copy from your file?
Old 04-29-2012, 12:11 PM
pkathee's Avatar
pkathee pkathee is offline
Mein Auto: 760 Li
I could be wrong but if you are missing the SP Daten folder, why not simply copy and paste the entire NCSExpert Daten folder into Winkfp?
If not compatible, then never mind.
1) 760Li- Logic7, Rear entert', Rear Climate, Comfort Access, 20" DP Wheels.
2) Lexus LX470- Mark Levinson Video/Audio, 22" Diablo Elite Wheels.
Old 04-29-2012, 12:25 PM
it does not recognize daten from NCSExpert. It copies them to winkpf,but that is all it does. Can u read assembly data when u go to choose ZUSB or is the folder empty?
Old 04-29-2012, 02:31 PM
Originally Posted by khabar View Post
it does not recognize daten from ncsexpert. It copies them to winkpf,but that is all it does. Can u read assembly data when u go to choose zusb or is the folder empty?
my folder is empty
Old 04-29-2012, 06:03 PM
mine too.
Old 04-30-2012, 08:01 PM
Bump
Old 05-04-2012, 05:13 PM
stuartjohn24 stuartjohn24 is offline
Mein Auto: BMW F01
Originally Posted by RON7165994 View Post
Bump
You need to download the 'DATA' files for the E65 that have all the software files for every module. search for E65 V40 daten files in google. its about 1.5GB of data.
Import the extracted folder using 'import assembly line data' function
Hope this helps.
Old 05-04-2012, 05:28 PM
do u have that files? i could not find in Google. thank you
