E36 (1991 - 1999)
Old 04-09-2012, 07:40 AM
veteran011's Avatar
veteran011 veteran011 is offline
WARNING: Has Dumb Ideas
Mein Auto: 97 328is
changing your oil will not help with an overheating problem. you will need to look at your cooling system.
dab of oppo anyone?
Project List:
Replace coolant temp sensor
Replace starter
Brake and Power Steering Fluid Flush
Front Control Arms, Bushings, and Tie Rods
Replace Passenger Lock Actuator
Reglue Peeling Hedliner
Swirl removal
Old 05-04-2012, 05:20 PM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: big turbo hellrot sedan
I just changed my oil
165,568 miles
just a marker
Turbo lag is just a headstart because the chase is more exciting than the win - Abraham Lincoln
Old 05-05-2012, 12:40 AM
DEATH2000's Avatar
DEATH2000 DEATH2000 is offline
Mein Auto: 1998 BMW E36 328i,
Have you guys seen this yet:
Bav Auto E36 Maintenance Schedule PDF
A PDF document to help you track your oil changes and maintenance history. Great for keeping track.
Here are the ones for the other series:
Bav Auto Maintenance Schedule - All Series
ProjectTechnik.com - Alberta based BMW Community
See My car on Project Technik HERE!
| OE M3 Bumper | M3 Mirrors | Jim Conforti CF CAI | UUC Motorwerks Underdrive Pulleys | 18x8 ASA AR1's | Koni Sport Springs & Shocks |
Founding Member of the Canyonrot Club! #343!
Old 05-05-2012, 08:06 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Annual fuel filter replacement??? Um, no. I feel like they created that list by considering a ton of different cars, old and new, and then came up with average intervals for everything. The net result is a schedule that doesn't apply as well as it should.
1998 BMW 328is
1966 Pontiac GTO
Old 05-05-2012, 08:14 PM
Mr Gusta's Avatar
Fireballs inc.
im with this...
btw karl since we are in the oil thread have you tried the shell rotella yet?
Old 05-05-2012, 08:19 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
I've just been topping off with whatever dino oil I can get at the gas station. I've put two different brands of random quarts in. That's not bad right?
-CJ
Old 05-05-2012, 08:25 PM
ZeGerman's Avatar
Warm Leatherette
No, I wanted to last time, but I couldn't find any stores in my area which sold it in the individual quarts, so I threw in the towel and just used Mobil 1 again. I'd still like to try Rotella T6, however, so I'll probably try harder to find some next time around.
Also, I sent some oil to Blackstone Labs for a full analysis, so it will be interesting to see what they report back with. That was with Mobil 1 0W40 with 3,760 miles & 8.5 months on it.
Totally fine.
1998 BMW 328is
1966 Pontiac GTO
Old 05-05-2012, 08:29 PM
Mr Gusta's Avatar
Fireballs inc.
Its fine cj but my car was burning oil with dino 5w-30
synthetic 5w-40 has been much better.
usually only smokes a little on startup after I was running the car hard.
Karl you can usually find it at walmart in quarts, most other places has it in jugs (you would need two anyway)
and advance auto parts had it on sale two days ago (22 a jug and mann filter was 4 bucks)
Old 06-12-2012, 08:55 PM
Loki13 Loki13 is offline
Mein Auto: Focus
synthetics and newer oils
just a few things to remember; first extended oil changes using synthetic oil. Even though synthetic oil will not break down as soon as 'dino' oil and it will provide better lubrication over a longer period your engine will still produce acid, varnish, soot etc that will collect in the oil. No matter how good the oil is it will not rid the engine of these contaminants. By extending the oil changes to say 9000 miles instead of 5000 miles, you will have a larger build up of contaminants in your oil over time causing increased wear. Changing at 5000 mile intervals keeps the contaminant levels down. Personally I change my oil at 5000km or 3000 miles
even though I drive 200km/day with most of it being on the highway.
second: Rotella oil is made specifically for diesel engines which use a different fuel and usually run at higher temperatures. The newer diesel oils (API CJ-4 classification) are made for Tier III and IV emissionized engines which do run at higher temps than older engines. This oil is also made to be used with a low sulfur content fuel. Although I do not know what using API CJ-4 classified oil in your car will do I would worry about what it may not do since this oil is made for hotter operating temps and a different fuel.
Just something to think about.
Old 06-23-2012, 03:05 PM
thatguytruth thatguytruth is offline
Mein Auto: 1995 BMW 325iC
I didn't wanna be that butt and ask " what should I use' but I kinda have to, I haven't owned this car for even a year yet. I live in Arkansas and its hot in the summer (85+, 90s avg) so I use 20-50 and I haven't driven this car in the winter but anywho. I'm about to drive this car to Moreno Valley, California from Arkansas next month so two questions. Should I drive there using 20-50 or should I use something else? Also, What should I use in Moreno Valley, California?
Driving style: I don't go slow... ever, I heard I can't do that in cali. In Arkansas go 80+ or MOVE!!!
Yes its a daily driver and maybe one day I will track it but its going to be a while.
1995 BMW 325iC
Old 07-04-2012, 02:00 PM
s1dc9 s1dc9 is offline
E36 *****
Mein Auto: 92' - 325i E36
I've own my E36 for about a year and half. I did my oil change sometime last year and I'm due for another right now. I've used Castrol GTX 20w-50 High Mileage and Mahle filter last time. The original post said to stick to OEM filters. Is there anything bad about using FRAM or STP filters? They look the same as the Mahle's. Any thoughts?
Old 07-04-2012, 07:11 PM
ZeGerman's Avatar
Warm Leatherette
Generally speaking, they are not as high of quality as the Mahle filters, but if you change your oil and filters regularly, it shouldn't pose a problem.
With that said, you stated that the last time you changed your oil was sometime last year. Even if you don't drive your car very many miles per year, it should have the oil changed at least twice per year. How many miles and how many months are you putting on your oil before changing it?
1998 BMW 328is
1966 Pontiac GTO
Old 07-05-2012, 07:29 AM
veteran011's Avatar
Mein Auto: 97 328is
+1 to what ZeGerman said. I used Fram filters for my last 2 changes and didn't see any negative effects. I change my oil religiously every 3000mi though. And when it comes to weights I'd recommend sticking with what the owners manual says: 15W-40. I personally use Rotella but everyone has their preferences.
Sent from my DROID4 using Bimmer App
dab of oppo anyone?
Project List:
Replace starter
Swirl removal
Old 07-05-2012, 07:32 AM
veteran011's Avatar
Mein Auto: 97 328is
I stick to what the manual says. It lists temp ranges for each recommended oil weight. Brand is a personal preference but im sure you know to not get the generic "store brand".
dab of oppo anyone?
Project List:
Replace starter
Swirl removal
Old 09-03-2012, 01:42 PM
Organisedchoas Organisedchoas is offline
Darren
Mein Auto: E36 M3 evo 97
I've always used 10w 40 castrol magnetex, go into my local parts store, and by a miracle they are selling it for 17.50 per 4 litres!!!! Cheap quality oil! Thumbs up!! And she runs so sweet with new oil.
Old 10-27-2012, 08:38 AM
jarrowood jarrowood is offline
Mein Auto: 97 328 is
this may be a dumb question to you bimmer guys but i just bought my first bmw and its also my first non american vehicle, on all my other builds i have always used fram oil filters. is it a bad idea to use on my e36? or does it not matter?
Old 10-27-2012, 08:45 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
A good question but honesty Fram are not of the best quality.
I personally buy my Mann or Bosch filters from http://www.rockauto.com when they're on sale. I buy a case at a time.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 10-27-2012, 08:52 AM
thanks for the help
Old 03-26-2013, 05:32 AM
dhangjr dhangjr is offline
Mein Auto: 325ic
so I should be running 20w 50. Im in seattle area. It never gets down to zero here. Rarely does it reach 100 but I do travel to nevada and Idaho where it often goes over 100
Old 03-29-2013, 09:40 AM
Naptown Pete Naptown Pete is offline
Mein Auto: BMW 235iC
Has anyone ever added Militec-1 to their vehicle?
I have yet to try it in my M50 engine, but on nearly all my other vehicles and power equipment, and especially my guns.
http://www.militec-1.com/
Old 03-29-2013, 05:20 PM
jonesin's Avatar
The Canadian Prick.
I make it a habit to never trust the claims of people whose websites look like that. If they can't take the time to put together a site in more than what? 16 bit with a 32 color palette? Then I sure as hell don't trust them to put time and money into R & D for what they're foisting off on an unsuspecting public.
My $0.02.
Ed
Old 03-31-2013, 05:48 PM
My $0.02.
Ed
I usually don't tell many people about Militec 1.
Ask any special forces types...
Or M-1 Tank mechanics.
Or snipers.
Old 03-31-2013, 08:00 PM
jonesin's Avatar
The Canadian Prick.
Yeah, look at my avatar. This isn't my first rodeo. I've been at least affiliated with the military for 22 years now. And for my weapons, I use either CLP, or Hoppe's No. 9. Always have, never an issue. But they still aren't cars.
Old 03-31-2013, 08:12 PM
cj.surr's Avatar
some kid
Wait wut??
How old are you?
-CJ
Old 03-31-2013, 08:54 PM
jonesin's Avatar
The Canadian Prick.
I'm 34. I joined Army Cadets in 1991.
filter, oil, royal purple, viscosity, weight
