Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > F10 M5 (2012 - 2016)
The 5th generation M5 has the V8 S63 TU engine with twin turbos under the hood producing 550hp. The engine and DCT gear box pusses the M5 0-60 in just 4.2 seconds.
Old 06-15-2011, 07:16 AM
tim330i's Avatar
tim330i tim330i is online now
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
The New BMW F10 M5 Smiles for the Camera -- Official Press Release and Photos
The New BMW M5 - Official Photos and Informaiton
For TONS more pictures check out the Official BMW F10 M5 Gallery
The New BMW M5 at a Glance
Fifth generation of the world's most successful high-performance saloon in the premium segment of the executive class; new BMW M5 is an exceptionally dynamic high-performance sports car with four doors and five seats; consistent further development of the vehicle concept initiated in 1984 with the first-generation BMW M5; compelling track potential combines with the comprehensive practicality of a luxurious business saloon; groundbreaking character headlined by significantly improved efficiency, supreme long-distance comfort, and innovative driver assistance systems and infotainment functions.
  • World premiere of a newly developed BMW M high-performance engine: high-revving 4.4-litre V8 engine with M TwinPower Turbo package consisting of Twin Scroll Twin Turbo technology, cross-bank exhaust manifold, High Precision Injection petrol direct injection and VALVETRONIC fully variable valve control; 412 kW/560 hp at 6,000 7,000 rpm, maximum torque: 680 Newton meters (502 lb-ft) from 1,500 rpm; lag-free power delivery, typical M car thrust.
  • Significantly improved balance between performance and fuel consumption: acceleration 0100 km/h (62 mph) in 4.4 seconds, 0200 km/h (124 mph) in 13.0 seconds, top speed: 250 km/h / 155 mph (305 km/h / 190 mph with M Driver's Package); average fuel consumption in EU test cycle: 9.9 liters/100 km (28.5 mpg imp); engine output 10 per cent up on predecessor model, maximum torque increased by 30 per cent, fuel consumption cut by more than 30 per cent; extensive Efficient Dynamics technology, including Auto Start-Stop function and Brake Energy Regeneration.
  • Power transfer to the rear wheels via the seven-speed M Double Clutch Transmission Drivelogic; traction-optimized automatic gear selection; Launch Control; Low Speed Assistance; automatically activated parking mode; M-specific gear selector; M leather steering wheel with shift paddles.
  • Hallmark M conceptual harmony produces superior performance characteristics with precise interplay of drive and chassis technology, aerodynamics and weight balance; power-to-weight ratio: 3.3 kg (approx. 7 lb)/hp; M-specific suspension (front and rear axle kinematics), M Servotronic steering, Dynamic Damper Control, DSC stability control system including M Dynamic Mode; bodyshell mounting using special panels; lightweight compound high-performance braking system.
  • Outstandingly agile handling thanks to innovative rear axle differential with Active M Differential; electronically controlled multi-plate limited-slip differential enables fully variable distribution of drive between the rear wheels to optimize traction and stability in dynamic lane change maneuvers and acceleration out of corners; degree of lock can be varied between 0 and 100 per cent according to the situation; fast, precise and preemptive responses thanks to constant data cross-checking between the Active M Differential and DSC stability control system, and monitoring of the accelerator pedal position, wheel speed and yaw rate.
  • Two individually configured set-ups for the car can be called up using the new M Drive buttons on the steering wheel; range of programmable parameters unique in the segment: accelerator responses, M Servotronic responses, Drivelogic shift program, DSC mode, Dynamic Damper Control and information in the Head-Up Display.
  • Characteristic body design with familiar M aesthetics reflecting the car's extremely dynamic yet precisely controllable nature; specific design features contributing to performance characteristics; front apron with extremely large air intakes for the engine and brakes; athletically flared wheel arches to emphasize wide track; hallmark M "gills" with integrated indicator bars; aerodynamically optimized rear apron with diffuser between the right and left-hand pair of twin exhaust tailpipes; gurney-style rear spoiler on the boot lid; 19-inch M light-alloy wheels in exclusive double-spoke design.
  • Unique combination of sports car cockpit and luxurious ambiance for the interior; M-specific instrument cluster in black-panel technology; newly designed, leather-covered center console; M sports seats; standard specification also includes: Merino leather upholstery with extended features, exclusive Aluminum Trace interior trim strips, BMW Individual roof liner in Anthracite, electrically operated steering column adjustment, four-zone automatic climate control and ambient light.
  • Extensive range of driver assistance systems and mobility services from BMW ConnectedDrive unmatched by competitors in this segment and beyond: M-specific Head-Up Display (standard), Adaptive Headlights for standard xenon light, High-Beam Assistant, BMW Night Vision with pedestrian recognition, Lane Change Warning System, Lane Departure Warning System, Surround View, Speed Limit Info, internet usage, extended integration of smartphones and music players, real-time traffic information and apps for receiving Web Radio and using Facebook and Twitter.
  • Almost all BMW 5 Series Saloon equipment options available, including Comfort Access, M multifunction seats, active seats, doors with Soft Close Automatic function, hands-free tailgate opening, electric glass roof, trailer coupling.
Specifications and performance:
BMW M5: V8 petrol engine, M TwinPower Turbo technology with Twin Scroll Twin Turbo, cross-bank exhaust manifold, High Precision Injection direct injection and VALVETRONIC variable valve control.
  • Displacement: 4,395 cc,
  • Output: 412 kW/560 hp at 6,000 7,000 rpm,
  • Max. torque: 680 Nm (502 lb-ft) at 1,500 5,750 rpm.
  • Acceleration 0 100 km/h (62 mph): 4.4 seconds,
  • Acceleration 0 200 km/h (124 mph): 13.0 seconds,
  • Top speed: 250 km/h / 155 mph (305 km/h / 190 mph with M Driver's Package).
  • Average fuel consumption: 9.9 litres/100 kilometres (28.5 mpg imp),
  • CO2 emissions: 232 g/km, exhaust standard: EU5.
For complete details about the new BMW M5 see the full BMW Press Release - http://Bimmerfest.com/pdf/The_new_BMW_M5.pdf
ID:	281770   Click image for larger version
ID:	281771   Click image for larger version
ID:	281772   Click image for larger version
ID:	281773   Click image for larger version
ID:	281775   Click image for larger version
ID:	281776   Click image for larger version
ID:	281777   Click image for larger version
ID:	281778   Click image for larger version
ID:	281780   Click image for larger version
ID:	281781   Click image for larger version
ID:	281782   Click image for larger version
ID:	281783   Click image for larger version
ID:	281785   Click image for larger version
ID:	281786   Click image for larger version
ID:	281787   Click image for larger version
ID:	281788   Click image for larger version
More about The New BMW F10 M5 Smiles for the Camera -- Official Press Release and Photos
BMW-F10-M5 1BMW-F10-M5 2BMW-F10-M5 3BMW-F10-M5 4BMW-F10-M5 5BMW-F10-M5 6BMW-F10-M5 7BMW-F10-M5 8BMW-F10-M5 9BMW-F10-M5 10
Old 06-15-2011, 07:27 AM
pix335i's Avatar
pix335i pix335i is offline
Enthusiast
Mein Auto: E92 335i Coupe
I really like the color they chose for the photos on the M5.
Overall I think it is a pretty good looking car but it does lack a bit of *wow* factor.
Is it just me or did they simply take the bumper from the current ///M3 and slap it on there? If its not the exact same, it certainly looks very similar.
2007 Montego Blue 335i Coupe | 2014 X1 xDrive28i
Old 06-15-2011, 07:56 AM
iflyry iflyry is offline
Mein Auto: Infiniti
Looks confused.
It looks like a pregnant and bloated M3 Sedan. I've never been a fan of 5 series cars, but this looks, in one word, terrible.
Old 06-15-2011, 07:57 AM
BravoMikeWiskey BravoMikeWiskey is offline
Mein Auto: MB SL550
Yawn....
Old 06-15-2011, 08:11 AM
Jon Shafer's Avatar
Bimmerfest Founder
Mein Auto: E92 M3 Cp
I wouldn't kick it out of my garage... E39 is my personal favorite, and this comes close. Every time I see it I like it more...
Old 06-15-2011, 09:00 AM
cruise_bone's Avatar
cruise_bone cruise_bone is offline
Mein Auto: 328i M-sport Coupe
That car is stunning. Over time it will become one of if not the greatest M5 ever.
2016 M3
Individual Ventian Violet|Silvertone|Manual|Exec Pack|18"|Adaptive M suspension
Euro Delivery - July 20, 2016
PCD - October 18, 2016
2010 328i M-Sport Coupe
TitanSilber|Jade|Manual|Premium|Sat|Auto high-beams|iPod|Heated Seats
Euro Delivery - October 20, 2009
PCD - December 16, 2009
Old 06-15-2011, 11:59 AM
BruinGM BruinGM is offline
The 12th Bruin!
Mein Auto: 2001 BMW 330i Topaz Blue
I like the color too.
The specs are drool worthy.
I was expecting a bit more aggressive styling and I do agree that it lacks a bit of "wow" factor.
I don't like the current trend in hood lines...too many creases in it and I was hoping they did something different with the M5 hood.
But, I'd still buy it if I could I'm sure driving it would put the styling aside.
Old 06-15-2011, 12:34 PM
necromancer necromancer is offline
Mein Auto: 2011.5 M3 Sedan
I have always been an ass man. With that said, I don't care for the front by like the ass, man. They also forgot the clutch pedal. What gives?
2011 M3 Sedan ED 3/24/2011
2003 330i Sport Package...still working like a champ. ED 2/14/2003
Old 06-15-2011, 05:25 PM
neurom neurom is offline
Mein Auto: 2013 911 C2S
The most impressive fact about this car is that it averaged 28.5MPG imp. If my math is correct, this is an average of 23.7? I must be wrong. If not, it does not even get a gas guzzler tax.
Other than this, it sort of looks like the E63 AMG.
Old 06-15-2011, 06:16 PM
Spartan Eagle Spartan Eagle is offline
Mein Auto: 2008 335xi Sapphire Black
WOW! Looks so much better than I thought it would!
Art is science made clear
335xi 08'
Old 06-16-2011, 03:55 AM
johnbmw6's Avatar
johnbmw6 johnbmw6 is offline
Mein Auto: 2016 LCI M3/2015 M6 GC CP
Exclamation
Looks just like my 550i M Sport sorry BMW you cocked up.
Old 06-17-2011, 11:28 AM
Killjoy's Avatar
Killjoy Killjoy is offline
OEM Hoe....
Send a message via AIM to Killjoy
Mein Auto: 1999 M3, 2002 tii
I think the car itself looks great, but it could use a little more flare to it's design. Also, as mentioned before, where is the clutch pedal? Are they really not going to include a manual option this time around? Ugh....
Originally Posted by Cmy_bimmer View Post
Oh your talking about THAT hole.. yeah thats an inspection hole
Old 06-17-2011, 04:50 PM
hulk7280 hulk7280 is offline
Mein Auto: 535i
why no v10?? why did they go with a v8!
Old 06-18-2011, 12:06 PM
Groznyy_Volk Groznyy_Volk is offline
Mein Auto: 1999 323i (E36)
Personally I like the way it looks. It doesn't stand out too much or look more gaudy than the regular F10 5-series, which is a good thing. I'm glad that they decided to go back to the V8 and throw in twin turbos. V10 engines have never been very stable and reliable. Over all I am very pleased with the result.
"Horsepower is how fast you hit the wall. Torque is how far you take the wall with you."
E38 99' 740iL (02/07 - 06/12)
E36 99' 323i (07/12 - 06/14)
E46 01' 330i (04/14 - Present)
Old 06-18-2011, 12:09 PM
Also, I'm sure that It will be available in a standard manual transmission. I notice that BMW keeps trying to push the dual clutch. But many true petrolheads still aren't sold on it, me being one of them. for this car to only be available in DCT would be a severe disappointment to Bimmer enthusiasts everywhere.
Old 06-18-2011, 11:29 PM
Sloan165 Sloan165 is offline
Mein Auto: 2006 530i
Looks like a damn nice ride to me! I wouldn't kick it out of the garage either!
2006 530i TitanGrau, Premium Pkg, Sport Pkg, Logic 7, Sport Seats, Heated Front Seats, Rear Power Shade, Steptronic
Old 06-19-2011, 08:34 PM
Gravik Gravik is offline
Mein Auto: '91 535i/5
Was hoping for a little more power and a little faster in the 0-60. I mean it should be able to beat a ford mustang which costs a good 60k less!
1995 525iT. 178k miles. Magnaflow exhaust. SOLD
1991 535i/5. 154k miles. |DT Performance Catback|CAI|Miller MAF/WAR Chip|NEX coilovers|Beyern Rapp Staggered wheels| SOLD
FOR SALE
Old 06-21-2011, 09:37 AM
kunal_D's Avatar
kunal_D kunal_D is offline
Mein Auto: 2008 335i Sport 6MT
Beautiful
08' E90 335i, Sport, Premium, Logic 7, 6-spd
01' 330i TiAG, ZSP, ZPP, ZCW, 5spd - R.I.P 04/12- gone but not forgotten.
Old 06-24-2011, 07:33 AM
Burrogs's Avatar
Burrogs Burrogs is offline
Mein Auto: '04 330i ZHP 6-sp AW
Looks like a Pontiac from the side view
2004 330i ZHP 6-spd, Alpine White/Black Cube/Alcantara, Koni FSDs w/ Eibach Prokit, no CDV, M3 RTAB with Vorschlag limiters, ULO-OEM Clears, Lightwerkz TFX upgrade, Blackout Kidneys, OEM M3 Strut Brace, OEM Bluetooth retrofit, DIY Clutch Stop, Sirius, Dr. VANOS kit, iPod integration
Old 06-28-2011, 08:18 AM
mason's Avatar
mason mason is offline
Travel Fever
Mein Auto: 535dx
I'm just drooling.
MJ14 535dx - Imperial Blue
MJ10 550 GT - Imperial Blue (retired)
MJ07 530i - Silver Grey (Sold)
Old 05-06-2012, 08:01 PM
mwagner1's Avatar
mwagner1 mwagner1 is offline
ICH LIEBE BMW!!!!
Mein Auto: it has four wheels
Looks just fine to me....I cannot wait to see a new M5 in something other than Blue, which I will despise until the day I die...
Cheers,
Old 05-07-2012, 08:31 AM
MI55LE MI55LE is offline
Mein Auto: '08 M5
Originally Posted by mwagner1 View Post
..a new M5 in something other than Blue..
agree
why, oh why does BMW insist on putting out this horrible shade of blue for their promos ? there are a couple of good looking "blue" colors "out there" but they use this !!)
looks like they chose it from the flag of a sissy nation (it's the french racing color, isn't it ?)
Old 05-12-2012, 06:47 PM
dalekressin's Avatar
dalekressin dalekressin is offline
Mein Auto: 2010 M3
I wonder what is projected for sales for F10 M5.
94 530i sold (That was difficult for me)
01 530i >144,500+ miles SOLD
06 330XI winter's especially fun drive (SOLD)
10 M3 Sedan (sweet)
13 Nissan GT-R Black Edition
14 Porsche Cayenne Platinum Diesel
15 Porsche GT3
16 Porsche GT4
BMWCCA 4215
2012 m5, bmw f10 m5, bmw m5, bmw m5 turbo, f10 m5, m twinpower turbo, m5, m5 twinpower, twin scroll twin turbo
