Old 05-06-2012, 11:03 PM
silentbob silentbob is offline
Mein Auto: X3
Brake Bleed Screw Size?
Hi Guys,
Stupid question, but I am feeling stupid all weekend. I was doing a brake fluid flush this weekend. Had turkey basted all of the old fluid out and put fresh fluid in. Took off rear passenger wheel, brought out the 7mm box wrench that I've used for all my other BMWs and....
it doesn't fit.
What is the size of the bleeder screw on the X3? I want to say 9mm, since 8mm didn't fit either and 11 was too big, but I figure I should be sure before I go off and buy additional tools, and more brake fluid.
Amazingly, search on forums here and on google didn't turn up obvious results, other than 7mm.
Old 05-19-2015, 11:49 AM
Dave 20T's Avatar
Dave 20T Dave 20T is offline
Moderator
Mein Auto: '13 320i, occ. use of X3
Every seems to be giving silentbob the silent treatment! Answers?
Old 05-19-2015, 12:30 PM
Mein Auto: 2004 X3 2.5i
It is a 9mm. for sure - just done a routine brake service on mine.
(Not sure it is necessary to suck all the fluid out of the reservoir. Why not just bleed off at each corner until fresh fluid appears?
Total system capacity is about 0.7L at a guess, so 2 of the 355ml (12Fl. Oz.) bottles of BMW DOT 4 suffice.)
Old 05-20-2015, 05:33 PM
x3brian x3brian is offline
Mein Auto: X3
I used pentosin dot 4 on my last change but super is right. 9mm and about 24 ounces.
