Old 04-24-2011, 08:45 PM
Doktorek's Avatar
Doktorek Doktorek is offline
Mein Auto: 750 Li
Wind noise from the sunroof
I got a question. When I have my sunroof closed and the headliner slide out cover open - I hear a wind blowing as if there was a air leak. When I close it - its gone. I put the fingers in there but there is no air coming in. Is it possible that the BMW has such a bad air flow and its not air-o-dynamic that I hear the wing blazing over the car?? I have a friend that had 3 E66s in the past and he says its normal. Once you close the sliding headliner - no more noise.
Is that the same story in your cars. My MB never had that problem and it didnt even have the sliding headliner. It was a Pano roof.
2008 BMW 750 LI
2010 Panamera Turbo
Old 04-24-2011, 08:49 PM
DFEL750I's Avatar
DFEL750I DFEL750I is offline
Mein Auto: 750I
Some guys have had good results changing the sunroof seal although they say the noise returns after some time.
Old 04-24-2011, 08:59 PM
TannerSV's Avatar
TannerSV TannerSV is offline
Mein Auto: 760Li
Turn your music up and enjoy! Thank me later.
Old 04-24-2011, 09:14 PM
1bad540's Avatar
1bad540 1bad540 is offline
Im on my 2nd e65 both do it, and Ive had both cars seals changed, it does help.
[SIGPIC]
e39 540i sport, acs type 2's,acs sper pdls,Euroclrs(sold)
e65 745i aw sport,21's aib's acspdls& rf splr(sold)
e46 328i Prem Aw18" 335spt whls(sold)
c5 Corvette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pana rf,nav,xenon,cldweather,20"4.6rims.(sold)
e65 750I aw, sport. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20"rennen forged,tune,corsa ex,intake.
w221 S550 amg,dia white,5%3m tint.20"s63rims,lwrd
e70 3.5 aw.mtec, powdr blk whls.
Old 04-25-2011, 06:36 AM
MOPAULY's Avatar
MOPAULY MOPAULY is offline
Mein Auto: Many things
Change the seal - $30 part from your dealer, takes about 30 minutes to do.
Old 04-25-2011, 06:41 AM
Wilassasin's Avatar
Wilassasin Wilassasin is offline
Wilassasin
Mein Auto: 2013 S550 amg sport pack/
The seal...
Previous: 335i xdrive coupe(sold),745(sold),750 sport(sold).
Current: 2013' S550 4matic, 2016' C7 (stingray).
Old 04-25-2011, 03:02 PM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
+1. Seal.
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 04-25-2011, 06:44 PM
cerretto cerretto is offline
Tip
Mein Auto: 04 E66
Its normal. I had the same question for a car straight off the show room floor.
Enjoy
Old 04-25-2011, 07:42 PM
Doktorek's Avatar
Mein Auto: 750 Li
lol....straight from the showroom floor?? lol
BTW, $30 part at the daler. Ok. Easy to change by yourself? Or should I let them do it?
When you say 'the seal' - is it the one on the window piece or the one on the roof panel piece? There are 2 seals.
2008 BMW 750 LI
2010 Panamera Turbo
Old 04-26-2011, 06:51 AM
JA 7's Avatar
JA 7 JA 7 is offline
Master of the Universe
Mein Auto: 2004 745Li
I've heard of using tape to pinpoint the seal. Tape it up, drive, and if it sounds better replace the applicable seal.
When called an idiot sometimes it is better to be quiet, than open mouth and remove all doubt.
Old 04-26-2011, 01:40 PM
Master Tinkerer
Sorry, I was talking about the seal on the sunroof opening. If you do a search on here you should come across a thread or two with the part number and a description of how to do it. It's an easy procedure, and if you take your time doing it you'll likely be very happy with the results. Make sure to reinitialize the sunroof at some point afterward (this procedure is also in one of the other threads).
Old 05-07-2012, 10:00 AM
08750i 08750i is offline
Mein Auto: 2008 750i
Had mine changed today.
Part numbers are, 54107245551 and 54852. Parts were $54.95, labor $255.00.
Bought the car a month ago CPO, CPO checklist had checked that both sun roof and wind noise were ok, wonder if they ever really inspect or just go down the row and check off all the boxes?
