Old 05-06-2012, 01:52 PM
xclone's Avatar
xclone xclone is offline
Send a message via AIM to xclone
Mein Auto: 2008 535iA
My fastest 0-60 is 4.289. This is on Cobb stg 2+ aggressive on a flat road.
BMWCCA Member 368765
2008 BMW 535iA | Cobb stg 2+ | FBO | Meth
Old 05-06-2012, 02:40 PM
paulo6 paulo6 is offline
Mein Auto: 2008 535xi Mon Blue.
Originally Posted by hp jnkey View Post
That I didn't know. Not sure who told me that all 535's have oil coolers but I guess that info was false.
Does Cobb recomend an oil cooler?
According to the DINAN specialist at Erhard BMW in Bloomfield Hills, MI and he is the one who told me about the oil cooler and how to tell if I have one or not, that he does NOT recommend running COBB on aggressive since I dont have the cooler. I am yet to buy a COBB so I am not too familiar with stages and maps I get to choose from.
2008 535xi, Monaco Blue
PREMIUM, NAV, SPORT, COMFORT ACCESS, COLD PKG, PARK ASSIST, SAT, COBB S1 Agg.
Old 05-06-2012, 05:10 PM
Oceans10's Avatar
Oceans10 Oceans10 is offline
Mein Auto: BMW 535i + 535XI wagon
QUOTE=xclone;6817938]My fastest 0-60 is 4.289. This is on Cobb stg 2+ aggressive on a flat road.
[/QUOTE]
Those are great numbers. Imagine if you could get your 60 ft time down to 2 seconds or under. That's what the tuned 3s and 1s post. Lighter cars, less mass to get off the couch.
Official 0-60 mph for an E60 M5 is 4.2 You are sniffing those shorts.
Audio: Jehnert Flatline speakers, Mobridge M1000 DA2 prepro, Helix P-DSP, Zapco Z-150.6 amp, CIC iDrive upgrade
Performance: Cobb Pro Tune, AR Downpipes, ER FMIC/CP, DCI, RB turbos and inlets, KW V2 coilovers, Fuel-It Stage 2 pump w Ported fuel rail, Mfactory LSD
Old 05-06-2012, 05:28 PM
hp jnkey hp jnkey is offline
Mein Auto: 535i & C6
That's amazing. What bolt-on's are you running? Is this with Meth?
What's it run in the 1/8 or 1/4?
Old 05-06-2012, 07:02 PM
xclone's Avatar
I'm running Meth but with the cobb its not adding boost, just a safety margin.
My mods are as follows (for those #'s):
Cobb stg2+ Aggressive
Injen Intake
ER charge pipe
Turbosmart DV's
BMS WW Meth kit - cm10 nozzle (running boost juice)
CP-E FMIC
AR Design catted downpipes (race cats)
Magnaflow exhaust (2nd cat delete)
Last trip down the track I went 12.73 1/4'. I have since replaced the suspension, found and tightened up a small boost leak and replaced the rear shock mounts. With everything being tightened up, I should be able to get 12.6*.
The Cobb does not, I believe, give you a 1' rollout like most tracks do. My 60' times on the track are 1.8 or 1.9. Since I start both in 2nd gear, traction is not as much of an issue.
Old 05-06-2012, 10:59 PM
tony925 tony925 is offline
Me likey! Too bad one can't achieve this with just the Cobb tune. Now if someone out there can show me a 5 sec. 0-60 with the Cobb tune then I may have to pull the trigger and get one for my baby!
2008 535i Platinum Gray
Old 05-07-2012, 08:57 AM
Oceans10's Avatar
Most of his power comes from the Cobb software alone, my guess is over 50%. People usually start with the tuner chip, then get sucked into a string of performance enhancements like larger downpipes, methanol injection, even larger turbos.
For a daily driver scenario I would recommend the tuner chip and dual cone intake (BMS sell DCI kits for $95 and it is totally DIY to swap out the stock airbox.) That should add min. 80 BHP and 100 ft-lbs torque. VERY noticable enhancement.
Old 05-07-2012, 09:30 AM
ModBargains III ModBargains III is offline
Mein Auto: E92, E82, E46, E39
Wow, nice job!
That's why we love COBB!
Sean Singh | Modification Expert | Sean@modbargains.com | (714) 582-3330 ext. 8009
BMW Wheels | BMW Brakes | BMW Suspension | BMW M3 Parts | KW Coilovers |
AE Performance | Remus Exhaust | BMW Performance Exhaust
Hours: Mon - Fri 8:00am-6:00pm | Sat 8:00am-5:00pm (PST)
Check out the Blog!
Old 05-07-2012, 10:23 AM
That's exactly what I'm running, Cobb Stage 1 with Dual Cone Intake.
Best 0-60 that I've seen on my car was 5.2 but that's with a stumble from the start and a long hesitation when the tranny shifted into 2nd gear.
With a proper launch and manual shifting, the car should hit 60 in 4.8 seconds.
Where it really shines is from 80 - 120.
Old 05-07-2012, 11:16 AM
Oceans10's Avatar
4.8 sounds about right. That's almost a second faster than stock. Just for reference :-)
Agree that on the highway you go from legal to facing jailtime very quickly. The car feels effortless, almost begging to be let off the leash.
I hit 147 with mine (in Mexico), then it shifted to 6th gear and lurched forward! No loud wailing of the tail pipes or strained engine howl, just a sustained push and the feeling of the gears smoothly upshifting.
Old 05-07-2012, 12:42 PM
burnie35's Avatar
burnie35 burnie35 is offline
Old Timer (Really)
Mein Auto: 2009 BMW 535i Sport
I've been considerint the Cobb for a while ... but on the highway my stock 535i still kicks ass, so I stay undecided. Mainly, I don't want to screw up the turbos or something.
2009 535i Sport, Jet Black | Cobb Stage 2 Aggressive | Injen DCI | AR Downpipes | BMS Led Angel Eyes | Michelin Pilot Sport A/S Plus
2008 528i (Retired)
2006 328ci (Retired)
1975 US Army (Retired)
Old 05-07-2012, 02:17 PM
I'm kind of the same way Bernie. It's a thrill a second to let my baby stretch her legs on the highway. The fact that it's so smooth and effortless makes you wonder why you would need more power. But seeing those numbers I can see how each mod leaves you wanting more and more.
Old 05-07-2012, 02:33 PM
COBB is totally safe, and this thread and the COBB owners who post in here are a testament to that!
Check out the Blog!
Old 05-08-2012, 11:59 AM
rijc99 rijc99 is offline
Mein Auto: 2015 535i MSport
When I spoke to a Cobb tech, he said on some cars flashing the ROM can reset the service intervals. Anyone experience that on the 535i or does the service interval remain unaffected?
Old 05-16-2012, 01:00 AM
bo0osted bo0osted is offline
Mein Auto: Monaco Blue 08 535i
Those of you in CA, are you having much luck running the Stage 1 sport on a stock n54?
I just finally got around to updating my maps to v401 and am thinking of trying to sport maps. From the experience of others, it sounds like it's probably best to try the standard throttle and if problems occur, downgrade to linear throttle. Should be the same but as Ocean10 stated, the user is less likely to mash on the pedal and work the engine as hard in linear throttle.
2008 535i - Sport, Premium, Navigation, Cold, Parking Assist, L7, Xenon, Comfort Access
535 banner
Old 05-22-2012, 11:00 AM
ModBargains.com's Avatar
ModBargains.com ModBargains.com is offline
Mein Auto: E92 335i, F82 M4
You will be able to run the stage 1 sport maps without any issues. It is recommended that you use the stock throttle maps on AT cars and linear throttle on MT cars!
Alan Wei | Alan@ModBargains.com | (714) 582-3330 ext. 8006
We Specialize In: BMW M3 Wheels | BMW Brakes | BMW Suspension | BMW M3 Parts | VMR Wheels |
Remus Exhaust | HRE FlowForm
Check out the Blog for daily updates!
Old 05-22-2012, 11:07 AM
Thanks Alan. Is this from Modbargains or directly from Cobb?
535 banner
Old 05-22-2012, 11:15 AM
There are tons of other customers who are in California, Arizona, and Nevada who are running the COBB Stage 1 Sport maps, including myself. You will not have any issues doing so and you'll also get a TON more power out of the car as the ACN maps aren't that impressive in terms of gains. In terms of throttle mapping, that is something that is well known among the community and would be something Cobb recommends as well.
Old 05-22-2012, 11:19 AM
So Stage 1 Sport map is ok for California 91 octane without an aftermarket intercooler?
Old 05-22-2012, 02:44 PM
Thanks Alan. What's the rationale behind using the linear map for MT and the stock map for AT? I believe the concern is heavy load at low RPMs, which won't happen regarless of the transmission type so long as those in MT shift normally
535 banner
Old 05-22-2012, 05:47 PM
That is correct. If you're going to run an aftermarket FMIC, you would run the Stage 1+ maps.
The linear throttle calibrations offer a more aggressive accelerator pedal feel and may be more suitable for 6MT-equipped cars. The stock throttle are less aggressive and may be more suitable for automatic vehicles, however, both calibrations are safe to use on all transmission types. You can try either of them to see which one suits your driving habits best!
Old 05-22-2012, 05:57 PM
I think you have it backwards. The linear throttle offers a linear pedal feel. In other words, you have to really step on the gas to get the car going. 80% throttle is stepping down on the pedal 80%. The stock throttle map is more aggressive in that it spikes up when you step in. In other words, you could be at 70% throttle even though you've only stepped on 40% of the pedal. This is my experience on both maps.
I can see stock throttle map being bad for the sport stage 1 on CA gas because you are jumping to 18psi very quickly with a small step of the pedal. More chance for knock on bad gas. I thought that's why people recommended the linear over the stock on crappy ACN gas.
I'm not really following your logic on why one is better for AT and the other is better for MT.
535 banner
Old 05-25-2012, 12:34 AM
bump for an answer
535 banner
Old 05-25-2012, 01:02 PM
bump for an answer
Linear makes it easier to modulate the clutch. Since the % throttle input is equal to % pushed on the pedal, there no surprises ala the computer deciding to give you a big jump in throttle while you're trying to release the clutch and pulling away smoothly.
Old 05-25-2012, 01:03 PM
Delete.
