Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners / Enthusiasts
Old 05-09-2012, 08:03 PM
Snipe656 Snipe656 is offline
Mein Auto: 2009 335d
You said 6k until next change but how many since the last oil change? Seems when te DEF light happens around 6k past an oil change it means either they did not too off both tanks properly or the transfer pump is not working.
--Aaron
Old 05-09-2012, 08:08 PM
831Doug 831Doug is offline
Mein Auto: 335d
About 6K or 7K miles since the last oil change. Guessing that they didn't fill it properly last time. If it happens again, then it's something else.
Old 05-10-2012, 05:14 AM
KeithS KeithS is offline
Mein Auto: '11 335d, '00 540iT
Originally Posted by 831Doug View Post
Took my car in on Tuesday at 31,691 miles.
6000 miles to go before oil service was due, but DEF warning came on. That was concurrent with the car needing a standard brake fluid service.
-- Re-filled DEF tank. Don't know why the timing was so far off from the oil service. They checked the system and everything was fine. Pulled in with 160 miles left.
Has to be one of 2 things. Either there is a problem with the DEF metering system injecting too much DEF, or it was not completely filled the last time (most likely).
Old 05-10-2012, 05:55 AM
I find it rather annoying no provisions are given to us to see roughly how much DEF is in the car. Annoys me since it is a required fluid for the car to run. To me it is like having no fuel level gauge but only a low on fuel warning.
--Aaron
Old 05-10-2012, 08:09 AM
BMWTurboDzl BMWTurboDzl is offline
Mein Auto: 335D
Emissions recall probably addresses this.
Sent from my MB525 using Bimmer App
Old 05-10-2012, 08:17 AM
Only if it is in fact the dealer not being bone heads and simply never filled things up completely during the prior oil change. It seems more times than not it is the dealer being bone heads and I doubt any recall is going to fix that. The secondary issue that seems to be a cause sometimes is the crystalizing of the fluid within the transfer pump, wonder if any recall could fully fix that or if it is a flaw to the very design of a two tank system.
--Aaron
Old 05-12-2012, 07:32 AM
xi2d xi2d is online now
Mein Auto: '11 335d/'12 X5d (wife's)
2011 335d
8 miles: replaced front bumper prior to delivery
24,536 miles: replaced wipers
25,400 miles: replaced right rear punctured stock sport package Potenza run-flat with the same
After reading this forum the other day, I realized that the squealing noise I've been hearing for some time now was coming from my vehicle. Will bring in for A/C squeal.
2010 X5d
-software update, wipers and 3 visits for the charge air temp sensor at 16,200, 19,700 and 28,000 miles
2010 335d
-software update and wipers
Current:
Past:
2010 X5 35d "d2"
2010 335d "d1"
2008 e90 328xi
335d, cost, maintenance, mileage, unscheduled
