Old 05-12-2012, 08:56 AM
steenport567 steenport567 is offline
Mein Auto: 2005 X3 2.5i
X3 PCV Valve Replacement
I have seen several pictures and videos on how to replace a PCV valve for BMW's, but non for an X3. Would anyone have that information?
Does anyone have the repair manual for an 2005 X3? Thank you very much in advance!
Email: nathansteenport@gmail.com
Old 05-12-2012, 10:45 AM
Mein Auto: 2004 X3 2.5i
Search on any of these terms:
- crankcase vent valve (CVV or CCV)
- oil separator
- cyclone valve
No conventional PCV on BMW's that I know of.
No workshop manual available off the shelf, but you should be able to find links to BMW technical information sheets for this job, as well as forum member's description of how they handled it.
Takes several hours (4 to 6) and can be a bit challenging I gather to replace the valve and all hoses.
Old 05-12-2012, 12:16 PM
Ok, great. Thanks for the help. I'm probably going to take it to my mechanic and have him deal with it.
Sent from my ADR6400L using Bimmer App
Old 05-12-2012, 12:39 PM
noego noego is offline
Mein Auto: '06 X3, 1997 Chevy truck,
http://blog.bavauto.com/8003/diy-vid...lation-system/
this link should open on a Bavarian Auto page that includes several videos in sequence on doing the job Supercourse mentioned.
Old 05-13-2012, 06:49 AM
X3emist's Avatar
X3emist X3emist is offline
Mein Auto: 06 X3 Sport
And
Don't forget to replace any brittle tubes that connect the system and run to various locations under the hood. Another big item is to make sure the tube from the dipstick to the CCV is unplugged. This tube apparently gets clogged and needs cleared when doing this job.
2006 X3 Silver Grey/Black Lthr/Alum Trim/Sport Prem Pkg/Xenons/Servotronic/Prem Sound/Satellite Radio/Heated Seats/Carbon Fiber Pillars/Blue Tooth/Aux In/Cargo Net/Aluminum Pedals/V1 Hardwired
[SIGPIC]
Old 05-13-2012, 07:13 AM
X3-terrestrial's Avatar
Aficionado
I hope you meant unclogged. The tube has to be plugged!
-Mario Andretti.
___________________
River City Bimmers BMW CCA
2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
Old 05-31-2013, 10:04 PM
Duane Sagar Duane Sagar is offline
Mein Auto: 04 330i msport
hi all, my x5 diesel is blowing blue smoke on cold start up could this be pcv valve , doesnt seem to do it every morning, any feedback appreciated
Old 05-31-2013, 10:35 PM
Yes, most definitely. Thus is what happened to us as well. It's a cheap part ($100), but getting to it is hell. We spent $700 getting it fixed. You can find a video on YouTube. Good luck!
Old 05-31-2013, 10:54 PM
bloody pcv valve
cheers for thatdid you experience an oil burning smell inside the car
Old 06-01-2013, 01:53 PM
swampX3 swampX3 is offline
Mein Auto: bmw++many
a video that may be good
a good general vid ......can't believe how good the pics are in vids these days....also ....did the 330i .....it had heat trace wire elements on the plastic piping and actual CCV .....it was wrapped over the CCV.....was quite sludgy in there.....the plug ins for the heat trace wires are a bit rascally on the 330 but the 04 X3 was just a two pots of tea plus two Randazos donuts job on a cool day
on both vehicles the intake manifold comes off easily plus the fuel line can be popped apart safely
Old 10-22-2015, 03:10 PM
kaldewaay kaldewaay is offline
Mein Auto: X3
Hell needed
What is this thing? it is rubber and it not sealed for some reason
Trying to do a CVV valve replacement and ran in to this.
https://www.dropbox.com/sh/cfjj40gst...qX0f-zJ0a?dl=0
Can someone explain what that is?
Thank you
Old 10-22-2015, 10:04 PM
SilberVogel's Avatar
SilberVogel SilberVogel is offline
Mein Auto: 2002 330Ci Conv.
^ That's the insulation around the "cold climate" CCV. The two halves you're seeing are designed to be held together by small o-rings which have disappeared.
Here's a comparison photo with and without that insulation:
DIYs help you save money with repairs; let www.bmwpnpc.com help you save money with the parts.
Old 10-23-2015, 05:41 AM
Mein Auto: X3
Excellent thank you so much, so it would be better to replace it with a cold climate cvv then.
