Old 05-15-2012, 05:16 PM
Pdux72's Avatar
Pdux72 Pdux72 is offline
Mein Auto: 05' BMW 745i,
Can somebody please check this ASAP
Can somebody please go out to there car, start it up and go over to the gas cap and take it off... Do you hear a vacuum sound like the cap was being sucked on.. trying to figure this p1434 code out. May ne my pump bad buy i need to know if there is a vacuum while trying to take cap off.
I took my new cap off and it was like dead air. No vacuum or pressure..
Thanks. At dealer now knowing if i need to buy part..
Sent from my EVO using Bimmer AApp
Old 05-15-2012, 05:29 PM
dgoodsell's Avatar
dgoodsell dgoodsell is offline
Mein Auto: 2005 745LI
Just did no suction on mine either bro
Sent from my Transformer Prime TF201 using Bimmer App
2005 745LI
Black on Black
Sports Pack
Comfort Acces
Rear Entertainment Pack
Convenience Pack
Premium Sound Pack
BTUM9000
3M Tint - 20%
Akebono Brake Pads
Blacked Out Grille
Smoked Taillights
ACS Roof Spoiler
MTEC V3
MTEC D1S 6000K
MTEC H9 4750K Fogs
Old 05-15-2012, 07:26 PM
Pdux72's Avatar
Well thanks for checking dgoodsell. I appreciate you checking for me.. They say its intermittent as to when it comes on and pressurize/vacuum the fuel system for a check. We will see...
Sent from my EVO using Bimmer App
Old 05-16-2012, 05:25 AM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
Was any work recently done near the front of the engine, particularly the driver's side?
Sent from my ADR6425LVW using Bimmer App
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 05-16-2012, 02:12 PM
alpinaman24's Avatar
alpinaman24 alpinaman24 is offline
what amg?
Mein Auto: 07 B7,91 735i , 91e30sold
if its a evap purge or vent cofe replace the purge valve in motor compartment take plastic cover off its fairly simple NOT for butchers tho
Old 05-16-2012, 02:20 PM
Pdux72's Avatar
Not sure what part or location your talkin about alpinaman. No work has ever been done in the front of vehicle. Was mentioned issue could be gas cap replacement or something called the DMTL pump that pressurizes the fuel system/tank for potential leaks i think... ?
Old 05-17-2012, 12:27 PM
what amg?
purge valve is located on the driver side engine compartment if you take covers out .. you will see a yellow plastic hose follow the hose toward the intake plenum .. theres a solonoid and another harder plastic hose
thats your purge valve ..
FUEL TANK BREATHER VALVE 1 13907506739 $82.88
Old 05-17-2012, 10:39 PM
teejaylentz teejaylentz is offline
Mein Auto: 2002 745i
I can't remember the exact code I had, but something similar to this hit me about 2 years ago (I'm pretty sure the code mapped to a purge valve issue) on the BMW. I noticed a pattern that the error appeared right after I had put fuel in the car and then eventually went away after driving around a few days. Upon closer inspection of the gas cap, I noticed the seal around the gas cap itself had started to warp (cupped and pushed in the middle) and was cracking on the edges, so I ordered a new cap. Haven't had a problem since! Unfortunately I don't recall the exact code other than it being purge valve related, but maybe take a look at the seal on your cap to see if it is in good shape.
Old 05-17-2012, 11:08 PM
Pdux72's Avatar
Well just so happens i went to the dealership and picked up a new gas cap for $26 a couple days ago. I also bought an OBD2 scanner to look or clear alarms but havent taken out of box yet. May rwturn it and get the entry level one.. anyway driving around today and started it up... Alarm cleared on its own so must have been the cap.. glad that was the issue.
Now when somebody does a search maybe this thread will pull up for them. Cause i really couldnt find much..
Old 05-18-2012, 08:44 AM
bkdave2atl bkdave2atl is offline
Send a message via AIM to bkdave2atl
Mein Auto: 745i
So it worked
Old 05-18-2012, 08:49 AM
dgoodsell's Avatar
Thats good news glad it was figured out
2005 745LI
Black on Black
Sports Pack
Comfort Acces
Convenience Pack
Premium Sound Pack
BTUM9000
3M Tint - 20%
Akebono Brake Pads
Blacked Out Grille
Smoked Taillights
ACS Roof Spoiler
MTEC V3
MTEC D1S 6000K
MTEC H9 4750K Fogs
Old 05-18-2012, 10:54 AM
Pdux72's Avatar
Originally Posted by bkdave2atl View Post
So it worked
Yep, glad that was the resolution if it continues... Definitely a
Old 10-01-2012, 11:30 AM
pmpn8ez's Avatar
pmpn8ez pmpn8ez is offline
Mein Auto: 04 BMW 745Li E66
I have the code P1434 as well. I just bought a gas cap from the dealer and replaced old one. How long does it take before the service engine light go off?
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Spacers 20mm Front 30mm Rear
Akebono Brake Pads
JL Audio 500/1 Amp
2 Type R 10" Subwoofers
Old 10-01-2012, 11:41 AM
Pdux72's Avatar
It's a random test so they said it should clear itself within the next 15 drives or so.. Not just a start-stop of the engine. The self test is random. It will clear itself or you can clear the alarm yourself with an ODB or something. I think mine took 2 days before it cleared on its own.
Old 10-01-2012, 11:44 AM
pmpn8ez's Avatar
I tried to pull the battery negative for an hour. Just cleared date/time but the error was still there. Hopefully the code will clear the next couple of days cause I need a smog.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 10-01-2012, 11:50 AM
Pdux72's Avatar
It's not a major issue and I don't think pulling the neg would eliminate the code. Maybe somebody else may know more about that but if u don't have a scanner I would just give it a few days. When it happened to me. I just looked at the dash randomly the next day and noticed it wasn't Showing issue anymore. Keep us posted so we can help if that's not the problem but I'm sure u will be fine.
Old 10-01-2012, 12:22 PM
pmpn8ez's Avatar
I definitely will keep you posted. Thanks for the input. Love those Asanti AF120 your rocking BTW.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 10-01-2012, 04:19 PM
rkruz rkruz is offline
Banned
Mein Auto: 750i 2008
no suction, ever
Old 10-01-2012, 04:43 PM
Pdux72's Avatar
Thank you!
Old 10-02-2012, 10:22 AM
pmpn8ez's Avatar
Yesterday when I bought my gas cap, dealer sold me a similar gas cap but has a blue rubber lining instead of the original with green. Dealer told me its the updated version. Is that the same gas cap you guys purchased? Hopefully it will do the trick.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 10-02-2012, 12:00 PM
Pdux72's Avatar
Yep!
Old 10-02-2012, 12:20 PM
pmpn8ez's Avatar
Yep!
Thanks for your replies. This service light is making me nervous. It's needs to hurry up and disappear! Lol.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 10-03-2012, 12:20 PM
pmpn8ez's Avatar
Went to O'Reilly and one of the guys plugged his OBDII reader and let me reset the light. Anybody kno how many miles I have to drive before it's ready to be smogged?
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 10-03-2012, 06:37 PM
Pdux72's Avatar
Smogged?
So by them using the scanner is the code gone now?
Old 10-03-2012, 06:55 PM
pmpn8ez's Avatar
I just resetted the light today. I need to get it smogged tomorrow. Hopefully the system will be ready by then and pass smog.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
