Old 05-14-2012, 08:24 PM
collardgreens's Avatar
collardgreens collardgreens is offline
Mein Auto: 01 540/6
cant get M62tu vibration dampner off
I removed the 8 torx bolts, TIS and some videos i've seen mention only removing the 8 bolts.
It will not budge. Do I need to take off the large bolt? Thats the Jesus bolt correct? Im not messing with that thing.
I am removing this to clean the years of oil cake sitting on the top of my oil pan. Figured i would pop it off while replacing some things and clean behind it.
I think i might damage the unit if i wack it with a rubber mallet to loosen it.
Old 05-14-2012, 08:35 PM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Is it Safe to Dance?
Mein Auto: 2001 540i/6
Are you sure they were torx? My 01 had 13mm hex heads.
You need to whack it with a rubber mallet. It pops right off. Its the outter part of the pulley that will remove. Not the inner part. You need to remove the jesus bolt for the entire thing to come off the crank end.
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 05-14-2012, 09:09 PM
Mein Auto: 01 540/6
Thanks for the encouraging words.
Went back and beat it down. Now my i can complete my fudge collection.
got milk?
Name:	harmonic balancer.jpg
Old 05-14-2012, 09:10 PM
Mein Auto: 01 540/6
Should i rub a little bit of anti-seize on the surface after I clean it?
Old 05-15-2012, 04:05 AM
Topaz540i's Avatar
I think i just cleaned it up. My plan was to hope i never need to ever remove it again lol because i was doing timing guides.
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Akebono=suck
coming soon:
Jb lwfw
Old 05-15-2012, 09:43 PM
Jared@EAC Jared@EAC is offline
Past Sponsor
Mein Auto: 00 540i/6
Neverseize wouldn't hurt...
