Multiple Cylinder Misfire With Fuel Cut-off - Bimmerfest - BMW Forums
Old 05-23-2009, 08:34 PM
zorin zorin is offline
Mein Auto: 2000 BMW 540i Sport
Hello,
I am getting code P1341 (Multiple Cylinder Misfire With Fuel Cut-off) when I accelerate. Also, some times, specially when the engine gets hot, I feel the intermittent rought idle at red lights, as if one or more cylinder do not fire for few seconds.
What are possible causes for multiple cylinder misfire? Valve cover gasket was leaking a bit on driver side of the engine so couple of the spark plugs boots were a little oily. I changed the valve cover gasket. No more oil in valve cover valley but intermittent rough idle still occures. Spark plugs are couple of years old. I have been using K&N air filter for a couple of years now.
The car has 170K km on it.
Thanks.
''00 BMW 540i - Sports Package (The Beast)
79 911 SC Targa, 3.2L Carrera engine - Zenith Carbs - 36mm vents, Lightweight Flywheel and PP
'99 LandRover Disco
'88 Mercedes-Benz 420SEL
Old 05-23-2009, 08:49 PM
chadi's Avatar
chadi chadi is offline
Mein Auto: A car
Well, I guess there could be multiple things causing a misfire. I myself have a thermostat going bad and its f'n up the fuel mixture. This in turn has cause some misfiring.
How did your spark plugs look when you replaced the valve cover gasket?
How did you get your codes? Dealership, indy, Peake Reader?
Good luck figuring this out, though.
Old 05-24-2009, 09:01 AM
MatWiz's Avatar
MatWiz MatWiz is offline
Psychology Reversalist
Mein Auto: 528
Is this really the only code you are getting??? If you have multiple misfire, then you should also get individual cylinder misfire codes. like 340, 341,342, etc.
If you have K&N filters, then that means that you need to spray them with oil to clean and reactivate the filter ? (oil catches the dust). That oil will find its way into the MAF sensor, fvcking up your fuel mixture, that can cause misfire if you are running too lean.
Take the MAF out (5 minutes job), and spray the hell of it with CRC (MAF cleaner).
If still not working, check for intake vacuum leaks. (can be in multiple points, if you have that, then replace ALL vacuum hoses). Your car has 170,000 miles, and is 2000. All those hoses are plastic and very brittle by now.
... at least that is a starting point...
mw
MatWiz
"The greatest thing about the internet, is that you can quote something and totally make up the source." - George Washington.
Old 05-24-2009, 02:30 PM
I read the code using my mechanics code reader. That's the only code that registers. It happened twice (few weeks apart). My spark plugs are couple of years old. They were in good condition when I check them few days ago.
I will check for vacuume leaks and clean the MAF.
Thanks.
'99 LandRover Disco
Old 05-24-2009, 03:40 PM
bmw_n00b13's Avatar
Freude am Fahren
Mein Auto: 99 528iA
You may have better luck with another code reader….
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 05-24-2009, 06:04 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Does that scan tool read Pending Codes?
Old 05-24-2009, 08:10 PM
No Pending Codes.
Should I start inspecting coil packs as well?
'99 LandRover Disco
Old 05-24-2009, 09:30 PM
arucano arucano is offline
Mein Auto: '03 530I/5sp '14 M6 GC
Check your fuel pressure. If it is the lack of fuel pressure, it should also give you a "lean" code though. Could be a plugged fuel filter as well. Multiple misfire without any other code is rear.
If the misfire started after changeing the valve cover gasket, check the coil pack ground wires.
Good luck.
Chet
Old 05-25-2009, 07:23 PM
Fuel filter was the first thing I changed. Did not help, although it was time to replace it anyways. Misfire started before changing the valve cover gasket.
Today I cleaned the MAF sensor. It did not help, but I did notice the shield for group of wires leaving the MAF sensor is ripped in two places, so in two area about half inch long the 4 or 5 wires are exposed. It is possible that one or two of the wires are damaged and disconnect intermittently. Is it possible to get the MAF wires replaced without changing the whole harness?
'99 LandRover Disco
Old 05-31-2009, 09:38 PM
Today I took out the spark plugs, coils and boots from cylinder 1-4 and cleaned them up. Spark plug threads were dirty and probably ground contact was not available all the time. The car seem to be OK for now.
'99 LandRover Disco
Old 05-31-2009, 09:42 PM
Throw away the K&N, put in an OEM filter, and clean/replace the MAF sensor.
Cleaning the spark plug threads means nothing. There is about 40 kV across those threads. A little dirt won't interfere.
Old 10-07-2011, 07:09 PM
bagodonuts68 bagodonuts68 is offline
Mein Auto: e38 750iL
any more on this saga. i am at the same point as Zorin and am wondering what the likelihood of a fuel pump problem. do they go commonly? my 2000 528it has 165k miles.
Old 10-07-2011, 07:42 PM
I have an ever-changing complex set of misfire codes myself ...
- Does the order of the misfire OBDII DTCs diagnostic trouble codes actually matter (1)
My suggestion?
- How to diagnose a BMW E39 engine misfire (1)
It's nowhere near where it should be ... but ... it's a starting point for tribal improvement!
Old 10-08-2011, 12:16 AM
searching for zen
bluebee, i am aware of your thorough checklist for diagnosing misfire errors. I trust that if i proceed systematically through the steps i will indeed solve my multiple cylinder misfires (that at present are occuring more frequently lately and seem to happen when drawing fuel aggressively even early in drives [1st 1.5 miles] before anything has heated up. my 2000 528it [ohh, silver with black interior] with c.165,000miles experiences fuel shutdown [runs rough which is felt primarily at idle and the car has no power] but runs well after turning car off briefly).
My peak scanner has indicated at one time as many as codes: F2, F3, EF, F1, 1F (or cylinder misfires on #5, 6, 2, 4; and "ignition coil" on cylinder #5. I have replaced the fuel filter and plan to find the pump relay and squeeze at the hose, searching for the pump's vibrations...then i think a check on the cam sensor whatchamadgig is in order once i look up the thread that addresses where it is and how to diagnose. I have new plugs that i will probably get around to installing and, if i can score a sale on Techron... BUT...
...but i am hoping my specific symptoms could bring a sage observer to the one only cause...or at least a narrower shadow to search in. It feels like a fuel delivery issue and if it comes to having to check fuel pressure i think i'll just take it in. I am scared about the cat because it seems i'm noticing a stronger exhaust smell. I've been good at keeping up with o2 sensors in the 70k miles ive owned the car (tho today was the first fuel filter i've put in...and i don't think i got the harness around it right...anyway).
The checklist is ominous. can you narrow my search?
thanks
Old 10-08-2011, 09:48 AM
Yours was a very well written & thorough response!
To clarify, it's not 'my' checklist; I simply compiled it from all misfire threads that had solutions updated by their owners! All the solutions came from those who solved their misfires; not from me.
And, as you've noted, it's easily listed 'what' can cause a misfire; but it's a lot harder to describe complete checks for each component.
The lack of complete step-by-step diagnostic-test checklists for each failure component is a major failing of that thread (which needs to be rectified).
occurring more frequently lately and seem to happen when drawing fuel aggressively even early in drives [1st 1.5 miles] before anything has heated up.
Interestingly, I have very similar issues current:
Exactly what I'm currently experiencing!
Since I have the I6 with the fuel system Schrader valve (where ever it is), I plan on testing the fuel system with the Autozone $150 free loaner tool.
Failing to find the Schrader valve (surprisingly) in Realoem, I'm currently searching the bestlinks fuel-system test threads for a picture of the location of the M54 Schrader valve.
Here is my pictorial spark plug DIY that you may be interested in:
- Pictorial DIY for an M54 spark plug replacement on a 2002 BMW 525i E39 with 95K miles
Watch out. There are multiple kinds of 'Techron' branded fluids (none of which would I use unless I had exhausted all other recourse.
- Decent Techron thread
BUT...i am hoping my specific symptoms could bring a sage observer to the one only cause...or at least a narrower shadow to search in.
I see. I need the same wise & sage observer myself for much the similar symptoms!
We should work together since we both have similar issues (as far as I can tell).
I'm going to borrow the Autozone fuel system tester before replacing any parts. My only problem at the moment is figuring out WHERE to hook up the tester on my M54?
- How do I test fuel pressure?
I agree. It's ominous for me also.
It can only be gas, air, spark, compression, or timing.
It's probably not spark, compression, or timing; so it's probably the air:fuel ratio (I realize you knew as much).
I am approaching it, at the moment, by two (imperfect) avenues:
  1. Vacuum leaks:
    • - How to battle E39 vacuum leaks (1) (2) (3)
    • - How to solve specific vacuum leak diagnostic trouble codes such as P0171, P0174, P0313 (1) & P0170, P0173 (1)
    • - Where to find all the vacuum hoses in the E39 (1)
  2. Fuel delivery:
    • - How to replace and service your BMW E39 fuel injectors (1)
    • - Testing (1) and replacing the fuel pump (1) (2) (3) (4) (5)
    • - DIY for replacing the fuel filter (1) (2) (3) (4) (5) (6)
What we both need, and which neither one of us has found satisfactory yet, is a comprehensive step-by-step procedure for both situations above (vacuum leaks and fuel delivery).
All I can find, for example, are tidbits scattered all over the place.
Sigh.
Old 10-11-2011, 11:55 AM
may have been spark plugs
i replaced my plugs yesterday. What came out were very ugly looking Bosch platinum plugs that in the course of at least 65k miles (they were in the car when i bought it with 107k miles on the odometer) of driving had all developed what looked like a 1/4" stripe of rust at the base of the porcelain (white part) and threads that were almost rusty. i replaced them with NGK platinum plugs and went out for the sort of (aggressive) drive that would have caused a misfire & check engine light in the past but it ran fine. ( i was hoping for a noticable improvement in power but was disspointed to find that it ran much like before...aside from no longer misfiring).
It may have just been plugs for me (though the jury is still out of course...i drove only a couple miles)!! But if it was a problem with the spark plugs why didn't my car have noticably more power with the new plugs??
Old 03-20-2012, 02:05 AM
CC4R1N1528 CC4R1N1528 is offline
Mein Auto: 1997 BMW 528i
Misfire issue as well...
Any fellow Bimmers out there??
I know this post has been dormant for a while, but I am having some troubles myself, and this was the closest amount of relevant information I have found compiled in the same thread.
I am having intermediate misfiring happening on my E39 528i.
When I am driving normal speeds, below 4-5K rpms there is no detectable issue. The engine runs smooth with the excepting of a 3000 RPM occasional shimmy. I drove 1500 miles in the past month. No real issues. But...
Everytime, I dip into the throttle a bit too much, it feels like the engine just quit, and then it runs on only 5 cylinders I think I am hearing. So the check engine light comes on and i'm cruising at 50mph and i shut off the car, turn it back on and all the cylinders work. No more issue.
1. Crankshaft position sensor?
2. Cracked thermo housing?
3. Catalytic Converter?
4. Coils?? But all at once?
From the Dealer i am getting codes
10: Coolant temperature sensor. (I do have a cracked thermo housing. I have the part and am replacing it tomorrow. 03.20.12)
238,239,240,241,242,243: Misfire codes on all cylinders 1-6.
The readout from the dealer reads that the fault lamp (check engine) can be requested by faults in the transmission control unit.
I just changed my spark plugs to BOSCH double platinum, recommended OEM spark plugs.
I have been putting coolant into the reservoir infrequently.
Thoughts Gentlemen?
All the best,
CC4R1N1528
Old 05-11-2012, 05:56 PM
Siberian Lion Siberian Lion is offline
Mein Auto: 2005 BMW 545i
So did you find the problem? I have same issue with one of the customer's cars, swithched plugs, coils, and injectors around but nothing changed still giving code P1353 cyl 6. misfire with fuel cut off
Old 05-14-2012, 02:37 PM
Found the cut off!
After much more research i found that there were several issues to be taken care of. 1st was a faulty Crank Shaft Sensor or part #12141709616 also with a new wiring harness, it is an updated harness part #12514592703.
I also replaced the valve cover gasket, air filter, inline fuel filter, water pump, thermostat and housing, transmission flush, coolant flush, and new tires.
What I can say is this. Its still dipping power at the points I previously indicated in my last post. However, it is no longer initiating a cylinder shut off at full throttle. I have had mention of the coils being bad, that my next place to try and find the gremlins. I'll update after i replace the coils.
All the best,
Chris
Old 05-15-2012, 07:00 AM
Big Chaze Big Chaze is offline
Mein Auto: BMW 6Spd 550I w Sports Pk
All the best,
Chris
Im experiencing some of the same issues. Do you have any traction/abs lights that are lit??
My problem is coming from abs system. The abs module senses wheel spin and cuts the fuel off..
http://www.bimmerfest.com/forums/image.php?type=sigpic&userid=75784&dateline=1329898227
Old 05-16-2012, 12:13 AM
Negative
No Abs lights. That sounds like brake issues. Mine was engine.
Old 05-16-2012, 08:44 AM
No sir.
Our abs units when faulty will cause your car to run like a 2 cylinder vehicle. Look it up.
And...if you have not replaced coils and plugs and maybe some fuel components, then you cant really troubleshoot.
Old 04-23-2016, 06:52 AM
Strydna 530 Strydna 530 is offline
Mein Auto: 2003 BMW 530i
Hello to all the Happy Bimmer Trouble Shooting Gurus....I recently purchased a 2003 530i and the first thing I notice after starting the engine was the SES light was on and I thought I'm buying another persons unresolved problems, So when I had the trouble codes scanned there where 2 dealing with fuel system too lean on Banks 1 and 2 the P0171/P0174..................... Then Random/Multiple Misfire P0300 Along with other misfires from the 3rd 4th 5th and 6th......P0303/P0304/P0305/P0306.....Wait, There are 2 more the transmission P0741 And Finally a P0420 Catalyst System Below Threshold, What could make All those codes come up at once, could there possibly be old codes that didn't get reset along with the new ones Or are all of the things related? There's no rough idle at red light/stop signs but when driving I notice and feel the misfires other than that the car runs OK, The previous owner probably didn't notice anything serious so they drove with the SES light and now that I own it I may be able to half way restore it to it's former glory With the help of The BMW Knowledge Gurus I am grateful and thank all who pass on this Useful Wisdom
Old 04-23-2016, 08:14 AM
Brandon002's Avatar
Brandon002 Brandon002 is offline
Mein Auto: 2002 530I Sport
Start by visually inspecting the rubber intake boots and all vacuum lines. Next plug in a live data scanner and check fuel trims. Also, check alternator output voltage. Do these and report back and we can go from there.
Old 04-23-2016, 10:21 AM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
As Brandon002 suggested, this is where having a BMW-specific code reader that can display live data really pays off. A hand-held one costs $50-$70, depending on model and source.
