Old 04-24-2012, 08:55 PM
jnesbitt jnesbitt is offline
Mein Auto: 2006 540i sport
1997 540i engine knock after sitting for a year
I've got a 1997 540i sport that hasn't been started for a year. I fired it up today and after sounding a little rough the engine smoothed out. I shut it off then re-started it about 10 minutes later and it knocked really loud. I let it idle for about 5 minutes hoping it would smooth out again but it didn't. The knock stayed constant and loud. I don't know if this is a serious problem, or what. Any ideas if there is an engine product I need to add to quiet it down, or an adjustment of some kind? Any help would be appreciated!!
Old 04-24-2012, 09:45 PM
jayster0966's Avatar
jayster0966 jayster0966 is offline
Bimmer Loyalist
Mein Auto: E24 E39 E83
Sounds like the lifters went dry while sitting for a while. Pretty normal on cars that have not been started for a while. Make sure the oil level is proper and start her up and take her for a good run on a freeway or similar. Noise should go away after a couple of minutes. Lifters need to pump up and bleed out any air.
Old 04-24-2012, 09:53 PM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
Possibly a failed chain tensioner. Don't drive it until you sort this out.
Old 04-25-2012, 05:14 AM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Agnostic Priest
Mein Auto: 2001 540i/6
if its an actual engine knock your gas went stale.
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 05-16-2012, 11:11 AM
Hi Guys, thanks for your answers. I took it for a spin and the engine knock went away pretty quickly so it was probably dry lifters as suggested by jayster0966
Old 05-16-2012, 11:18 AM
Topaz540i's Avatar
Agnostic Priest
An engine sitting that long is prob as dry as a rebuilt engine. The bmw procedure for a fresh (dry) engine is to start it and immediately raise the rpms to 4000rpms for about 10 seconds. This sounds like bad advice for a cold engine but the point is that the oil pump is run off the crank so you need to get it pumping oil thru the empty passages as fast as possible.
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Akebono=suck
coming soon:
Jb lwfw
