Old 05-02-2012, 02:26 PM
lilwhtbeamer lilwhtbeamer is offline
Mein Auto: 528i
What all engines can fit my 97 528i?
Will an engine from an e34 525i fit into my e39 528i?
What all engines are compatible?
Old 05-02-2012, 02:54 PM
Blauanzug Blauanzug is offline
Mein Auto: 2003 525i
Um why would you want to do this?? The engine computer systems changed from the e34 to the e39 and it is more difficult to retrofit an e34 into an e39. Why would you want to put an older engine into the car?
Old 05-02-2012, 02:56 PM
manticore33's Avatar
manticore33 manticore33 is offline
Send a message via AIM to manticore33
Mein Auto: '86 Porsche 951, '01 530i
Unless you have time, mad skills, and money, the engine that is compatible with your car is the engine is in the car.
I like coffee.
My e39 is fixed and moving towards atrophy.
Old 05-02-2012, 05:11 PM
Mein Auto: 528i
True that. I dont want to put an older engine in my e39, i just dont know what kinds of engines would fit.
help?
Old 05-02-2012, 07:42 PM
the540wgn's Avatar
the540wgn the540wgn is offline
Mein Auto: '02 540iT
this one
ColdWeather + Summer + Sport -- 20/30 Ceramic Tint -- Euro Armrest -- JL 13tw5-3 Subwoofer -- LED AEs
Old 05-02-2012, 08:19 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Ls-1....
The road goes ever onward....
(R.I.P. Jever)
Old 05-02-2012, 10:32 PM
gary@germanautosolutions's Avatar
gary@germanautosolutions gary@germanautosolutions is offline
Mein Auto: E39 528i, E60 M5
The '97-'98 528i's have the M52 engine. In 1999 it changed to the m52-tu which added dual VANOS, DISA valve and other electronic changes. Trying to swap anything other than an M52 will cause more problems than it's worth.
Gary
"I'm a little rascal on my Little Rascal"
- unknown
Old 05-03-2012, 06:37 AM
granlund granlund is offline
Mein Auto: -02 530 & -92 325is
What about an S52B32 then?I know it's not the cheapest option, but can the DME be made to work?
Old 05-14-2012, 08:05 PM
kmorgan_260 kmorgan_260 is offline
Mein Auto: 1997 528i
Similar question. I am considering buying a nice '98 528 with a blown motor. I have a M52B28 from a '98 328i that I assume would go in without much trouble or I might want to try finding an M62 which I also assume would fit. Not sure it would mate with the tranny though. It has the 5 speed manual and I think the 540i came with the 6 speed. Anyone know if I can use the M62 on that tranny?
94 318I (Daughter's car), 96 740IL(current project), 97 528I(DD), 07 335I(Son's car)
Old 05-14-2012, 10:03 PM
eparayno's Avatar
eparayno eparayno is online now
Mein Auto: 2001 530i
What engine would fit but for what reason? If you have the dough you can put whatever damn engine you want.
Old 05-14-2012, 11:38 PM
Silver540i6 Silver540i6 is offline
Mein Auto: BMW 540i/6
If I was going to spend a bunch of money trying to put a v8 in it, then I would definitely be putting a ls1 motor under the hood.
1998 BMW 540i/6 Sport...18" Staggered M Pars, Angel Eye Upgrade, Muffler/Resonator delete, iPod integration kit
1970 Dodge Challenger R/T SE...440 six pack, slap shift...blows away all e39s
Old 05-15-2012, 12:49 AM
Darren1231 Darren1231 is offline
Mein Auto: 2001 e39 525i
It's a bit blasphemous but why not implant a 2jz-gte or an RB26-dett N1 in her since money is no issue? I mean why else ask the question if you have unlimited resources, right? Better yet, throw a Nelson Racing Engine on that hoe and rock 1500WHP!
Old 05-15-2012, 12:29 PM
Turbo_525 Turbo_525 is offline
Mein Auto: 2002 525i 5-spd
Or just try this one:
  • N/A 525i, 5-speed, 138+K
  • BMW's are not like other cars, they have issues and cost you real $$$ to sort.
  • Affording to Buy a BMW is not the same thing as affording to OWN a BMW.
  • Pre-Purchase Inspections by a qualifed BMW tech should be considered required PRIOR to purchase.
  • Service Records matter - a whole lot!
  • Plan to spend $2-3000+ in maintance & repairs the first year of ownership.
  • Plan on something unexpected to happen, more often than you are used to.
Old 05-15-2012, 01:37 PM
Not sure how we got off on a tangent about money not being an issue, but if that were the case we certainly wouldn't be discussing this in the e39 forum. Lets face it that is why we are all here.
Old 05-16-2012, 12:42 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
The I6 & V8 e39s not only have different transmissions...but also do NOT share the same front suspension.
The V8 e39s (M62 & M62TU engines) have the old recirculating ball front suspension because there is not enough room in the e39's engine bay design for the updated rack-n-pinion front suspension that the I6 models got.
So installing a BMW V8 in an e39 6 cylinder model would require a complete different front suspension as well as transmission & rear end.
And as someone already mentioned...the easiest replacement engine is the same one being replaced...and in this case it's the M52 engine. If you don't know which BMWs used this engine...a simple internet search (wikipedia for instance) will reveal what other BMW models (and any other car model) used the same M52 engine. This will also include the engines displacement (B28 in this case).
FYI: one must also consider other BMW technology like EWS. One must consider the original DME since it has a coded ISN (individual serial number) that must match the other EWS components in order for the vehicle to start. So swapping in an entire engine & management system from another car can be fraught with issues if the other EWS components aren't brought over with the engine & engine management systems...but this is only an issue if one is not keeping the original engine management system.
Q {BMW CCA Member #191509}
(SOLD)
Old 05-16-2012, 02:56 PM
Thanks for the good technical info. I am closing the deal on the car tomorrow and my plan is to put the M52 from my donor 328i in it. I am told I will have to swap the oil pans but otherwise it should be straightforward. I will use the DME that is already in the car so the EWS should be happy. Will post pics when I get it home.
Old 05-16-2012, 02:57 PM
BigCo540i's Avatar
BigCo540i BigCo540i is offline
The Usual Suspect
Mein Auto: '12 X6 50i
This would be a good question for Bimmerforums.com
Old 05-15-2015, 12:20 AM
danieldjmj12 danieldjmj12 is offline
Mein Auto: 1996 BMW 528i
1996 BMW 528i trying to swap to a RB26DET :rofl:
Hey everyone, Im new to this forum and also new into a bimmer. I have a 1996 BMW 528i ever since I got the car I been wanting to make a build (Street/Drift/Track) and swap out the 2.8 engine to a Nissan RB26DET. I was looking around the forum and saw that a Toyota 1JZ/2JZ can be fitted into the E39 chassis but i really want to put in a RB26 in there, you know mix it up a bit. Another thing is that the 528 I have is an automatic . I want to also swap the automatic transmission for a 5 or 6 speed manual that can fit with the RB26DET and still make it all fit in the car at the same time. So if any one can help me ill be really happy. THX
Old 05-15-2015, 12:35 AM
I didn't know about this old thread, but I will xref this information into the thread found by typing /swap f3 in the bestlinks ...
- What engine swaps are most recommended (1) (2) (3)
See also:
- Summary advice to provide users who suspect a major engine repair due to overheating (1) (2) (3) (4) & how to test an engine for a blown head gasket, cracked heads, a warped block, stripped head bolt threads, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, or valve damage (1) (2) & what are the major factors in deciding whether to rebuild the engine, replace the engine, or sell the car (1) & a DIY for replacing the I6 M54 head gasket (1) (2) & replacing the V8 M62TU head gasket (1) & why these engines are so prone to heat-related damage in the first place (1) & welding the crack between cylinder #3 and the water jacket on the exhaust side (1) & what engine swaps are most recommended (1) (2) (3) & where to obtain a new or rebuilt head (1) replacement short block or long block (1) (2) & how to lift & remove the engine (1) & the most recent real-world results from the last 50 people faced with similar blown engine problems from which this advice came from (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30) (31) (32) (33) (34) (35) (36) (37) (38) (39) (40) (41) (42) (43) (44) (45) (46) (47) (48) (49) (50)
Old 05-15-2015, 08:42 AM
eparayno's Avatar
Sorry but it ain't happening. Too many questions asked so that means you don't know what's involved at all. If you have enough money then take it to a shop and have them swap in any engine you want.
Old 05-15-2015, 09:18 AM
mda185 mda185 is offline
Mein Auto: 95 525iT w/S52, 03 530i
I realize this is old thread but one useful bit of information that did not emerge is that the S52 3.8 liter engine from the E36 M3 is a fairly easy swap into the early E39 with the M52 engine and manual transmission. The engine blocks are the same externally and the 5 speed manual transmission is the same in the E39 and M3. The DME (engine computer) would need to be re-flashed with a software load capable of running the S52. This is a vendor I have used that can provide the necessary software:
http://www.trmtuning.com/product-cat...uningsoftware/
The E39 M52 oil pan and oil pickup tube will probably need to be used but that is easy to swap.
Keeper of wayward bimmers and motorcycles that have been neglected by previous owners. My latest addiction was built in 2008, has 2 wheels, and no radiator.
Old 05-15-2015, 09:28 AM
This is not a forum that can help you with questions like this. Swapping the Nissan engine is possible but never done on the E39 chassis as far as I know. This means custom fabrication of engine and tranny mounts, custom fabrication of shift linkage, custom re-coding of the E39 gauge cluster, custom driveshaft fabrication, most likely a change of rear differential gearset, and the list goes on. This is not economically feasible unless you have the skills and the time to do a lot of the custom work. The Toyota swap you referred to is a beautiful job but it was done in Australia and was a one off project unless the OP is selling parts based on what he did.
Going from auto to manual tranny complicates it further. I am fairly sure that would cause problems with ABS computer because it is connected to the auto tranny computer. There is a different software load for manual transmission cars with ABS and Traction Control.
IOW, not a swap to take on unless you know a lot about E39 electronics/software and are a master fabricator.
Old 05-15-2015, 07:09 PM
540 Hammer's Avatar
540 Hammer 540 Hammer is offline
Mein Auto: 1999 BMW 540I
"It's a bit blasphemous"...If you're thinking of anything besides the same BMW engine, the suggestions about the LS engine is a good one. Both from an engine cost perspective, reliability and availability of a ton of parts. This probably isn't the place to get good info about it though.
If you're seriously thinking about an LS swap, consider the LS3. It's one of the newest and takes to mods very well. Guys run 650HP with stock internals without problems. The other LS, if you can find one, is the LS7. That's the 7.0 liter/427 CI motor, 505HP stock. One of the members, I think on the "other" site, swapped in an LS7 in a 5 Series and loves it. I have a 2008 Corvette with a modded LS3 and it's a friken animal. Starting to digress though...G.L.
Old 05-16-2015, 05:12 AM
DennisCooper!'s Avatar
DennisCooper! DennisCooper! is offline
Mein Auto: 03 Ex Cop 530d Touring
Hi Daniel
As per above, you need to look at other forums that are more focused on engine swaps and the necessary information to go with it all. This forum is very oem orientated! You'll need to do a ton of research yourself to try and understand all that's required and have a nice healthy, read large'ish, bank balance to do it all. This won't be a over the weekend swap, there's a LOT of aspects you need to learn, research and get right prior to purchasing anything.
mda185 - Various japanese engines have been fitted to the E39 and multiple times/instances. They just tend not to show up on this forum. Do take a look around though, there's plenty of E39's with 'interesting' engine swaps etc!
540 Hammer - I've got my eye on importing another American car over here to the UK again, The F150 anniversary edition Harley Davidson was swapped for an Alpina B3S a few years ago, however, it looks like another one will be back on the family driveway today as my bro's driven over to buy another today! not sure if he's actually purchased yet, but he will if it's not an abused example. I want something much smaller and sleeker to match it soon (I hope) so looking at the modern classics like the Challenger and Camaro, perhaps a Corvette z06 ! - I'll just have to hope UK petrol prices remain what we consider 'low' for us !
Cheers, Dennis!
Old 05-16-2015, 07:49 PM
540 Hammer's Avatar
Dennis, The Challenger is a large car and as such handles like one. Unless you can find one with the SRT package, I wouldn't bother with it. At least go with the SRT, it will get the hell out of it's way. It's not small or sleek though. The SS Camaro is a decent car; handles decently and has good power, nice balance of both. If you can get the Z06, that's a must!! Great power to weight ratio and handles like cars that cost 3-4x's as much. You won't believe it until you drive it. That would be number one, especially if you're seeking smaller and sleeker. Out of all three, the Corvette actually would get the best MPG, IF you keep your foot out of it, BUT good luck with that!!
