unlocked the car and the normal 2 blinks kept going ?
After dinner the other day we made out way back to the car and when i pushed the unlock button twice (for all doors) it just kept blinking.
I recall i locked it again and retried the unlocking and it blinked twice as normal. It the car trying to tell me something ? I checked it over and no dings or dents from a hit , windows were up ar just about fully up. any ideas ? Thanks , Martin e39 540 sport |
Im not certain but I think it only does that if the alarm was set off while you are away, the extra blinks notify you that the alarm was previously triggered.
![]() The exterior lights can be programmed to blink as a visual alert when the DWA (anti-theft alarm siren system) has been activated or deactivated...and there's also the DWA red LED (clown nose) below the rear view mirror. Which one of these lights continued to blink when you deactivated the DWA system? If it was the exterior lights...it could be something as simple as the early warning of your car's battery starting to drop voltage. How old is your car's battery? Have you been having any odd HVAC symptoms like the fan acting erratically or continuing to run after the car is shut down? If it was the interior "clown nose" that continued to blink...see the info below...it could possibly be a response to the DWA system having been activated legitimately (someone bumped into your car & activated the tilt sensor...or you left a window or sunroof cracked open and an insect flew inside and activated the interior motion sensor). Or it could be a faulty monitor in the system that is not opening/closing properly: ![]() Below is more detailed info about the DWA system for anyone who "didn't know" how the system works: ![]() ![]() ![]() Interior motion sensor & tilt sensor info: ![]() ![]() ![]() ![]()
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) Last edited by QSilver7; 05-16-2012 at 09:29 AM. |
![]() we're not worthy
O/T I have nothing to add to this post, but would like to say that when "Q" responds to a thread (like many others)he gives you what you are looking for and then some..my hat goes off to you!!
Wow Q you know your bmw's.
After reading the info i think i need to clarify what was blinking. When i arm and dis arm the yellow turn signals blink to confirm. I was about 20 ft away approaching from the back of car. Saw the rear turn signal lights blink twice and the beeper beeped twice also. Then the beeper stopped (after the normal 2 beeps) but the signals kept blinking. Went on for about 3-4 seconds then i re-armed the car (1 beep and blink) then dis armed the car a few seconds later again. This time it blinked and beeped twice as normal. Martin Last edited by rcmarty; 05-16-2012 at 07:34 PM. |
