BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great! |
#101
Recall completed
Picked up car this morning with the recall complete.
No noticable change in the way the car runs. The worksheet says they replaced: 1 EGR valve, 1 O-ring, and 1 Rubber seal. The only thing worth mentioning is how nice the new 2012 328i loaner was. They have finally got the transmission right. That 8 speed is silky smooth. The turbo hooked up to the 4 banger was giving me adequate performance when needed along with 35 mpg. One leg I babied it and got 43 mpg. I don't think I could get used to the engine shutting down at every stop. You can turn that feature off but you have to remember to do it.
Current Vehicles 2008 E-93 335i Convertible (ED) 2011 E-90 335d (ED) |
#102
--Aaron |
#103
Any mention of new software? I wonder if some of the recalls will be parts only...
Reprogram
The sheet says: "EGR replacement and programming".
Apparantly it took two tries. "Failed Programming, 1st Programming Failed, Performed Complete Encoding due to Programming Failure in CAS and FRM. Checked OK". The 328i I thnk has a brand new ZF 8 speed automatic. The loaner car did not have paddle shifters but I had a blast playing with the 8 gears using the shift lever in sport mode. When the car was stopped at a long light with the air on, the engine would eventually restart. It has electric power steering so the engine would restart if you moved the steering wheel more than an inch or so. I think if I ever bought one I would have to figure out how to permanetly reverse the engine shutdown feature. Instead of having to remember to turn it "OFF" to prevent engine auto shutdown, I would want to be able to select it "ON" if I felt the need to save that last cup of gas. I think the real reason the car gets such good milage is the perfect combination of an 8 speed transmission with a turbo engine that is putting out serious torque at 1250 rpm. As long as you are not heavy on the gas pedal, it was getting 35-43 mpg on the highway. Also,I think BMWs mpg numbers are correct and the EPA must have tested the 328i with a boat and trailer attached to it. In the end, I was glad to be back in my rock solid 335d that has real power and gets great milage without all the engine flameouts.
Current Vehicles 2008 E-93 335i Convertible (ED) 2011 E-90 335d (ED) Last edited by Stevarino; 05-18-2012 at 05:27 PM. |
#105
@ Snipe and Bayoucity (and any other houston area owners): Any particular dealer you think knows diesel better than the others? My default plan is to take it in to Advantage/midtown. A coworker says to stay the h$ll away from advantage/ clear lake. I got the letter middle of this week. The SES light came on last Saturday morning and then went off about an hour later. I drove it to Arlington and back over the weekend and the mileage was similar to before.
#106
E70 and E90 with the M57Y engine produced from January 2010 to March 2011 Note: There is another recall for nearly the same exact thing which covers X5d and 335d models that were produced from April 2009 to March 2010 and yet another that covers January 2008 to September 2009. Last edited by Jim E.; 05-18-2012 at 02:31 PM. |
#107
--Aaron |
#108
The SA said - best to bring it in on Monday - so that they have the whole week to work on it. He also said bring it in early so that I have the pick of the loaners - maybe a '12 328 with sport?? If I have it for a week I'll definitely be checking out the autostop feature with the AC running.
Current: '10 335d Titanium Silver Premium, Nav, Ipod, Sat '07 A3 Ibis White, Tint, 2t, DSG, Premium dual sunroof Retired: '69 VW Fastback '73 MGB '78 Camaro LT ttops '80 VW Diesel rabbit '81 Audi 4000 4E '84 Audi 5000 5sp '87 Audi 5000 auto '90 Audi V8q '92 Millenia '01 Acura TL '93 Miata b Candy Apple red, AC, Factory hardtop |
#109
Make them give you the M6 loaner ....
--Aaron |
#110
Glad to hear of your positive experience re: Adv Midtown.
Guess with my build date I won't get the recall. ![]() Saw a black 335d on Westheimer today. I see more chevy Volts than diesel 3s. |
#111
To elaborate on my experience with Midtown and North. North had my car for around a month to replace a faulty sensor specific to diesel BMW vehicles across the globe. When I went to pick it up I saw the SES light was on before I even got back into the thing. They gave me some story about how BMW is having all sorts of problems with those sensors and how they are coming out with a replacement design soon and how even keeps happening to some lady's X5 that works at the dealership. I felt like I was being lied to and opted to take the car. After another month of leaving the car parked and going back and forth with BMWNA and looking online for any example of this sensor actually being bad then BMWNA advised me to go to another dealership. So I took it to Midtown and within hours they saw the problem, North hooked up the vacuum lines backwards but they also left some wire looms out of hooks and did not fully put on the engine cover. BMWNA refused to pay Midtown the $1k or so bill to fix what North messed up. North initially refused to pay for it but eventually Midtown convinced them into paying. So even though my car was fixed the very day Midtown got it, it took a week or so of waiting for them to get paid so I could get the car back. That whole episode started before I owned the car even 4 months and combined with being lied to when I bought the car it just has been a thorn in my side with BMW in general even though it solely is that North dealership. So I never again will go to North nor it's sister dealership in the Woodlands. My neighbor had some bad experience with his 330i at North and switched to the Woodlands out of pure aggravation with North.
--Aaron |
#112
Had some friends get rid of an X5 and switch to Lexus based purely on their aggravation with North. That was 4 years ago. Today they are in a Merc SUV of some kind.
#114
Got my recall notice yesterday. I'm 3000 miles from my next service. Can I get the done at the same time?
#115
I have 3300 miles until my next service, according to the service indicator; I have scheduled that service for June 28. My service advisor at Passport BMW in Maryland advised that I could wait until then, since the SES warning indicator was not showing.
#116
Based upon the wording of the letter I am in zero rush to get this recall done. I am overdue for some service and have an SES(guessing because overdue). I don't plan on bringing up the recall until I am dropping the car off for the other stuff. If they can't do it then, then the car comes back in a few months for rear brakes. If they can't do it then, then car comes in for an oil change a couple months after that. If they can't do it then, well the pattern should be obvious by now.
--Aaron |
#117
Glad to hear no performance loss post recall. N4S
#118
--Aaron |
#120
I posted this over in the E70 X5 forum and I believe it's even more important to post it on this diesel forum:
http://www.bimmerfest.com/forums/sho...0&postcount=60 Ok, now that I've had some time to really look into this, I believe I can shed some light on all this recall confusion. Why? I have two diesels (E90 and X5) and a friend also has an E90 diesel all of which cover this recall. In reality, it is actually THREE different recalls that each depend on engine production dates. All three recall notices deal with the same exact subject: "Voluntary Emissions Recall Campaign 11E-A03: Check and/or Replace Emissions Monitoring Components" In chronological order: #1. SIB 18 02 12 covers - E70 and E90 with the M57Y engine produced from January 2008 to September 2009. #2. SIB 18 03 12 covers - E70 and E90 with the M57Y engine produced from April 2009 to March 2010. #3. SIB 11 04 12 covers - E70 and E90 with the M57Y engine produced from January 2010 to March 2011. Recall #1 above requires the dealer to check the SCR part number. If the part number is NOT 18308509753 (E70) or 18308509750 (E90), the SCR catalyst will need to be replaced. The next part of recall #1 deals with the "mixer." If your mixer has a "multiple fin" arrangement, then it will need to be replaced with P/N 18308513445 (E70) or P/N 18308512438 (E90) which are single fins. Single fins basically look like a jet turbine fins at the intake. Each fin is a solid single straight fin. The last part of recall #1 is to inspect the EGR and replace it if it's the old style with (P/N 11 71 8 517 217 or P/N 11 71 8 512 526) Recall #2 only deals with the mixer and EGR. This means that at some point in production, they started to install the new SCR part. Recall #3 only deals with the EGR which means that at some point in production, they also started to use the new style mixer and only need to address the EGR. Hope this helps. |
#121
Recall
October 1, 2009 build
Recall: drooped off Wednesday. SA said Cat must be replaced. Part ordered on Friday. Expected pickup Tuesday. |
#122
So far no letter here. However I just moved and my mail has not yet forwarded. Also I have a July '11 build so it looks like I'm not covered by any of these.
Here's hoping I got some updated parts/software already. FYI just did a 5 day 2500 mile cross-country trip in the 335d and she performed spectacularly. Got about 38 mpg and not so much as a hiccup.
Entertaining America Since 1975 ![]() European Delivery July 26th 2011 ED Video: https://vimeo.com/60051914 ED Trip Report:http://www.bimmerfest.com/forums/sho...d.php?t=557294 335d| Deep Sea Blue| Black/Aluminum | Stuff | Gadgets | More Stuff | Power Whatnots | Auto-Verbing Nouns BMWCCA #448878 |
#123
![]() Jay
Herbert - '12 X5 35d / Sapphire Black / Black Perf Nevada / Aluminum trim / ZPP / ZPS / ZCW / ZAV / Apps / 3rd row Betty - '04 CTS-V / Black Raven / Black Leather & Suede / 6 speed LS6 combo 400 hp & 400 tq Sterling - '06 Silverado HD / White / Grey Leather / LBZ Duramax - Allison 6 speed combo / Crew Cab Short Bed LT3 |
#124
So far my car has been fantastic. Minimum issues, typical of what most of us have seen here. Dealer has only had my car a total of 3 times in almost 3 years. All issues resolved first time. So I have no complaints. |
#125
Also, do you think that all 3 recalls will require software? I'm looking at recall 3 (May 2010 production), and I wonder if new software will be needed for an EGR replacement.
