Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Old 05-19-2012, 08:59 PM
mortyx10 mortyx10 is offline
Mein Auto: 745i
DIY - How To Update Transmission Software (2-1 Shift problem)
Hello everyone.
This issue is a very well known issue and we all know there are few solutions out there such as Guibo, tranny oil, software update, etc.
There are DIYs for most of the solutions but I couldn't find a DIY for software update. most saying you have to take it to the dealer. Since I like to DIY everything possible I managed to update my transmission software and it really makes a difference.
I'm assuming you have your cable and know how to install drivers and stuff
1. Download and install BMW standard tools. It contains INPA, NCS, winKFP, and tool32.
This will only install the programs, you need the sp-daten files for e65.
http://www.mediafire.com/?xg3ms9lk59vslxc
2. Use the attached guide to setup winKFP.
3. Open INPA>>choose chassis>>Transmission>>Gearbox Control module>>Identification (F2). now press arrow down on your keyboard and take note of your Assembly number. Close INPA
4. Open winKFP>>Comfort mode>>Enter ZUSB and Enter the assembly number.>> Take note of your ECU family.
5. Now press F3 (Update ZUSB) and choose your ECU family.>>Ok
6. F4 (Enter VIN) and enter your full VIN number. >> Ok >>F8 (DONE).
7. F3 (Prog. ZB-Update). Here a pop up shows you your current and updated assembly number. If they are the same you already have the updated software but if not press okay.
Another pop up asking permission to program ecu....press okay and your done.
It took about 5 mins. so if your car's battery can hold up for 5 minutes you'll be alright.
At the end it should tell you that the programming was okay.
I reset my adaptation values using INPA after it was done and believe me it makes a huge difference. 2 to 1 jerk is 99% gone. I think I also need to change tranny oil and it'll be 100%.
Hope this helps.
Old 05-19-2012, 10:04 PM
x3lemon x3lemon is offline
Mein Auto: X3
I've been looking for how to do this. Will try. Thanks for posting.
Old 05-19-2012, 10:18 PM
Mein Auto: 745i
I've got mine from here http://www.bmwcoding.com/showthread....ghlight=usenet
You can use a free trial and unsubscribe before you have to pay.
Old 05-20-2012, 10:24 AM
Mein Auto: X3
I downloaded what I thought were the right daten files but the folder structure didn't match what you have listed in the winkfp PDF. Can you tell me exactly which files an from where to download for a 745li 2005. Feel like I'm almost there!
Old 05-20-2012, 06:12 PM
Mein Auto: 745i
I think you downloaded v46 which is a lite version, get v45, you don't need other chassis just e65.
You can also use your existing files if you have inpa and ncs installed, because this update is so old you don't need the newest files
Old 05-20-2012, 08:53 PM
Mein Auto: X3
I downloaded ver 4.5. In step 6 on winkfp I don't see the data folder anywhere.
Old 05-20-2012, 10:39 PM
Mein Auto: 745i
It must be there...it is in the main folder. SP-Daten-E65/data. I don't know if it isn't. Its more than 1gb, otherwise I could upload it for you.
Old 05-21-2012, 10:38 AM
Dead Dead is offline
Mein Auto: 2014 730LI
thanks mortyx10
SP-daten v 41 for e65 https://rapidshare.com/files/2644713...aten_Files.rar
file size 385mb
after decompress 1.29gb
latest update for e65 is v 41 so v 45 is the same as v 41
Old 05-21-2012, 12:32 PM
07jace750li 07jace750li is offline
Mein Auto: 750li
Hey guys I'm looking to update my software and really don't wanna go to the dealer...question forgive my ignorance but I just got my first BMW and don't kno anything bout it till I sign up to this awesome forum I have a 2007 750 li if I update the software what different would it do to my car and do I also need a diagnostic tools if I decide to DIY it??
Old 05-21-2012, 07:14 PM
Mein Auto: 745i
Originally Posted by Dead View Post
thanks mortyx10
file size 385mb
Thank you...very useful.
Old 05-21-2012, 07:18 PM
Mein Auto: 745i
The procedure is the same as above for every module but remember it could take hours. you better have a power supply connected to your car. but for transmission that is being discussed in this thread, it only takes minutes. tools you need are the ones posted here.
Old 05-22-2012, 04:52 PM
Mein Auto: X3
So I managed to install the software as per the instructions! When I launch INPA nothing displays except Battery Off Ignition Off. The cable is a usb cable that is connected to the OBD port on the car. Tried it with car on and off, ignition on and off. Windows did automatically install the drivers for the cable so I don't know what the issue is. Is there a way to troubleshoot the connection?
Old 05-23-2012, 01:22 AM
Mein Auto: 745i
Download the following and copy the files you missing in your INPA folder.
BIN, CFGDAT, SGDAT are the important ones.
http://www.mediafire.com/?58qfq1d9qq8d8rm
Old 05-23-2012, 06:12 AM
hd750Li's Avatar
hd750Li hd750Li is offline
Mein Auto: F02 750Li
Man! This post is so valuable and informative. It should be in the sticky or moved to DIY session.
Just a suggestion Morty, PM the forum moderator to have it moved.
I would also suggest the same for the other VIM DIY post.
Thanks buddy! E65 community is lucky to have someone like you here Morty!
Old 05-23-2012, 02:51 PM
wthreez wthreez is offline
Mein Auto: 06 750Li, 91 300zxTT
What is this 2-1 shift problem. Like what are the symptoms that way I know I know what to look out for
Black on Black beast
Old 05-23-2012, 05:22 PM
Mein Auto: X3
Thanks. So now I see all the options on inpa. But I can't get the Assembly number - I get an error. The red light on my cable never goes off and the black dots in the software are clear.
Its clear the cable is not communicating with my laptop. Can you walk me through installing the drivers?
Old 05-24-2012, 01:02 AM
Mein Auto: 745i
Hey man, Thanks for the complement. I'm nothing like what you saying. I have learned a lot in this forum and trying to give something back. I will try to contact the mods see what they say.
Thanks again.
Old 05-24-2012, 01:06 AM
Mein Auto: 745i
If the circules are not black, you are not communicating with your car.
Have a read at these and see if you get it working or not.
Old 05-24-2012, 01:23 AM
Mein Auto: 745i
It's a little kick you get when you are about to fully stop. The older software tells the gearbox to change to 1st just before the car comes to a stop so you feel a kick. Some say with the new updated software it does not change to 1st at all and starts from 2nd. but in my case it waits for the car to fully stop and then changes to 1st. As I said this is only 100% effective when it is done along with tranny fluid, guibo, etc. However you feel the difference right away.
Old 05-24-2012, 07:05 AM
Mr_Burger's Avatar
Mr_Burger Mr_Burger is offline
2007 760Li User
Mein Auto: 2007 760Li
Does this help too? http://www.bmwcoding.com/showthread....-2-1-downshift....
My 760Li - Fully Loaded
Old 05-24-2012, 05:07 PM
Mein Auto: X3
Sold my 2005 745 today so don,t need to figure out how to make this work. Thanks for all your help guys. Might need it again when I buy my 760!
Old 05-25-2012, 08:16 AM
Mein Auto: 750li
Thanx
Old 05-26-2012, 11:27 PM
ausbmw87 ausbmw87 is offline
Mein Auto: 735Li E66
to complete this update can the car be running ? ? i am just worried about the battery getting drained ? ?
Old 05-30-2012, 11:47 AM
anyone ? ? help in reguards to the car been on and running while the update is completed ? ?
Old 05-30-2012, 09:53 PM
flash_n flash_n is offline
Mein Auto: 745Li
Thank you for the write up.
When trying to perform step 7 i got the error "security access denied" and the flash would not proceed.
I had to change the configuration of WinKFP for fast baud rate to successfully flash. Seems like there are differences from ECU to ECU.
My update to the dynamic drive ECU required the fast baud rate to be disabled.
Silver 2004 BMW E66 / 745Li (DIYs):
ASK, Logic 7, blower, battery, guibo joint, active stabilizer bar bushings, diff oil, tranny sw update, vacuum pump gasket, window lift, a/c compressor, washer fluid reservoir, belt tensioner and deflector, crankcase vacuum hoses, crankcase vents, solenoid gaskets, headlight overhaul, ISM, hood lifts, driver mirror, sway bar end links, rear fog lamps, headlight washer, headlight vertical aim, VCGs
next up: P0492
