Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Old 03-07-2012, 04:26 AM
stuartjohn24 stuartjohn24 is offline
Mein Auto: BMW E65 745i
Hi mortyx10,
THANK YOU! I tried this before work today and it works perfectly!
I was dead set against paying £100 for some tacky chinese CAN BUS module to enable this function.
I cant thank you and those involved enough for working this out and sharing this DIY!
One note to anyone else doing this, it may be obvious but I made a mistake in the MMI_E65.C02 file where I added the coding data at the end of the file, NCS Expert did not like that!
I realised that the CODIERDATENBLOCK : {00003021}..... needed to be in numerical order in the file, and not at the end i.e. not after 31XX etc...
Many thanks again!
Stuart
Old 03-07-2012, 05:59 AM
D4hwt D4hwt is offline
Mein Auto: E65 735i, Ducati1199
Well done guys. Loving your work.
Old 03-13-2012, 02:57 AM
Hi guys,
any chance someone could send me a copy of their modded MMI_E65.C02 file
for some reason my NCS doesnt like my modded file, have tried moving the block into the correct space but always get an error when trying to read.. Have the 31/8/2009 files..
Cant seem to d/l is off the link in the other forum either..
Have coded a few other things but cant get this file to take for some reason.
Thanks in advance
Old 03-13-2012, 04:46 AM
hd750Li's Avatar
hd750Li hd750Li is offline
Mein Auto: 2008/2011 750Li
Originally Posted by D4hwt View Post
Hi guys, any chance someone could send me a copy of their modded MMI_E65.C02 file
See the attachment. It's a decompiled text file converted to pdf.
Old 03-13-2012, 04:49 AM
hd750Li's Avatar
Here is the actual C02 file. Just get rid of the .pdf extension.
Old 03-13-2012, 05:33 AM
Thanks for that HD, however i'm getting the same error with your file as well..
COAPI 1043: ERROR DURING PROCESS CBD- FILE MMI_E65.C02..
FROM THE ERROR LOG
>> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 06, ErrorNr: 1043
CODIERDATEN_LESEN
ERROR! Modul: CBD_PROC.C, ProcNr: 02, LineNr: 01, ErrorNr: 32.
C:\NCSEXPER\daten\e65\MMI_E65.C02
Have sucessfully coded other modules so i know my set up is good..
I get the Error if i try and read the MMIGT ECU as well as trying to code it.
Probably doing something blaringly obviously wrong but can't see what!!
Old 03-13-2012, 08:27 AM
Blackbox760 Blackbox760 is offline
Mein Auto: 2003 E66 760Li
FROM THE ERROR LOG
CODIERDATEN_LESEN
You might have the wrong version of the MMIGT file, try using an older version and see if you can connect then.
Old 04-04-2012, 02:50 PM
pkathee's Avatar
pkathee pkathee is offline
Mein Auto: 760 Li
Error
Guys,
I am in the process of enabling Video In Motion. I am able to easily disassemble, reassemble and then replace the three files accordingly, but I keep getting this error every time I read the ECU;
Error in CABD! Look at CABI.ERR and ERROR. LOG!
COAPI-1043: error during processing CBD-file
MMI_E65.C02
Also, per the info on the thread, I tried placing the parameter "CODIERDATENBLOCK : {00003021}....." within file MM1_E65.C02 in a numerical order but still that doesn't help.
However, once I switch back to my original files, I am able to read and process the ECU without any issues. I have been coding other Modules including MMIGT successfully so I know my NCSExpert set up is working fine.
Is there anything that I am missing?
1) 760Li- Logic7, Rear entert', Rear Climate, Comfort Access, 20" DP Wheels.
2) Lexus LX470- Mark Levinson Video/Audio, 22" Diablo Elite Wheels.
Old 04-04-2012, 08:28 PM
pkathee's Avatar
Mein Auto: 760 Li
EDIT: PROBLEM SOLVED
I have successfuly enabled Video in Motion. All the props go to hd750Li. He is bad a$$- Literally.........
I had outdated and corrupted files but he was able to upload his files into my OS and now all is good.
Originally Posted by pkathee View Post
Guys,
MMI_E65.C02
Old 04-10-2012, 04:02 AM
politby's Avatar
politby politby is offline
Mein Auto: 2005 750i
Awesome mod, I just did this today and it worked great (MMI_E65.C03 in my case).
Old 05-22-2012, 12:37 AM
D4T_POM's Avatar
D4T_POM D4T_POM is offline
Mein Auto: 2002 E66 745Li
Old 05-22-2012, 02:10 AM
Mr_Burger's Avatar
Mr_Burger Mr_Burger is offline
2007 760Li User
Mein Auto: 2007 760Li
FROM THE ERROR LOG
CODIERDATEN_LESEN
or upgrade to the latest EDIABAS..
My 760Li - Fully Loaded
Old 05-22-2012, 05:42 AM
Cheers for the input guys I did get it to work by reinstalling NCS and using HD's file . Should've posted. Sorry.
Many thanks to the brains who figured this out. and to HD for the file.
Old 05-22-2012, 08:54 AM
D4T_POM's Avatar
Hopefully this works, will try tomorrow and get back to ya'all
Sent from my HTC EVO 3D X515m using Bimmer App
Old 05-23-2012, 06:59 AM
cn555ic cn555ic is online now
The Coder guy in N.Y
Mein Auto: bmw
will this work on a 2006 650I??
Old 05-23-2012, 04:24 PM
mortyx10 mortyx10 is offline
Mein Auto: 745i
Hi, for you it's much easier, I'm not at my computer to tell you the exact function you need to change but you can find it using ncsdummy. Just read cappl module. You should set it to deny_full I think.
Old 10-23-2012, 06:10 AM
SuperSnoop's Avatar
SuperSnoop SuperSnoop is offline
Originally Posted by mortyx10 View Post
correct...you can only add parameters (which is simply possible by nettodat coding, no disassembly required) if the function is already defined. in this case we define it first in our SWTFSW02.dat and your right we can name it whatever, the keyword 1500 is more important. it must be unique.
I already have a function defined as 1500. I assume I should just take the next available spot (1528 in my case), and then change all references to 1500 in all three files?
My rear DVD player isn't working at the moment, so I won't be able to test it right away, but this seems pretty simple.
Old 10-26-2012, 01:46 PM
rippjd rippjd is offline
Mein Auto: '05 745i / '00 740i
If you have updated your NCSExpert with newer files from a SPDaten package (for example v45), then yes, a function is already defined for 1500. Some other forum recommended using 1600, which worked for me. The next available spot (1528) should also work. As long as the number has no defined fuction...
2005 745i Individual
HTML code is Off
