Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 04-30-2012, 06:20 PM
Jay41182 Jay41182 is offline
Mein Auto: 2004 BMW 545i
545i steering malfunction
Hi guys I have a 2004 545i and my steering malfunction light won't go off, any way on resetting this without going to the dealer, or what problem could it be and how could it be fixed.
Old 05-23-2012, 01:51 PM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is offline
Mein Auto: 01' 540 M-Sport cdn, F355
Could be low on power steering fluid, check that first. If you need to add some, make absolutely certain you have the correct fluid. Some BMWs use automatic transmission fluid instead of power steering fluid...and there are myriads of types of ATF and PS fluids...you need to use the correct type. Get out the owners manual and read up on how to check the fluid and what type it requires.
Factory M-Sport with factory installed M-tech bumpers, factory Bluetooth, factory M-Audio 10" dual voice coil subs, homelink, M5 rear stabilizer bar, Bilstein B14 PSS coil overs, stop tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, strong strut front upper stress bar.
