5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with! |
2005 545I Spark Plug replacement
Hello all,
I got a service due to replace my spark Plugs (2005 545I). I checked with the dealership and no wonder they quoted me 562$. I live in Montreal and could someone suggest a right place (cheap as well) to replace mine? I have to change withing 400KM. what if i keep running with the same spark plugs after 400 KM> will it be disasterous? please let me know. |
It'll be fine without a change. The car will probably run smoother with them changed. Any honest shop should be able to do the job.
2013 Scion FR-S 2007 550i Sport - GONE 2008 528i - GONE "What are you going to replace your BMW with?" "Another BMW, with a bigger engine!" |
You can safely go longer without changing the plugs. As far as cost, the plugs are around $100, and you are looking at around 2 hours labor, at whatever the prevailing rate is...Montreal I suspect is around $140 to $150. So $400 from an independant BMW specialist is probably what you should expect to pay. Shop around, or join the BMW Club, and get recommendations. Better yet, learn to do it yourself, and save the labor.
Factory M-Sport with factory installed M-tech bumpers, factory Bluetooth, factory M-Audio 10" dual voice coil subs, homelink, M5 rear stabilizer bar, Bilstein B14 PSS coil overs, stop tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, strong strut front upper stress bar. |
Do it yourself cost me the price of spark plugs in three hours of my time. Saved myself a lot of money.
Yes, this is something you can do yourself, there are several DIY's out there for it. The back two plugs can be a little frustrating to work with a space if very limited but the the DIY's describe how to do it.
I done mine yesterday took me about 5 hours, mostly because I managed to drop one of the new plugs into the engine bay and had to go hunt for it underneath the engine, it was the rear cylinder so it ended up on top of the metal guard underneath the engine... all I can say is thank god for telescopic magnets.... So ALWAYS stuff an old towel down the side of the engine to catch any butter fingered parts... P. |
What is the best brands that we can go with with 530i
Get the factory recommended NGK BKR6EQUP, but buy them from other than the dealer.
They run about $9 each online...usually with free shipping.
| Tags |
| 545i |
