E30 (1982 - 1993)
#26
Littlereddevil
let me know what you find out about your turn signals, iv been trying to figure this out so i can stop being pulled over and so i dont need to stick my arm out of my car. by the way beautiful bimmer, i love the red on her, also where did you get those rims!? those are too dope. |
#27
thanks littlereddevil it worked, I finally have turn signals!
#28
oh im having a problem with my rear windows, i got my front to finally work but the rear still wont. Iv replaced the switches and the pin connectors, i thought it could be the motors but they were working before and i dont think both would go out at the same time. iv checked the connections and i just need some help, my window is halfway down so if it was up it woldnt matter but i just need to close my window(fixing it is just a plus) also i tried to do it manually but somehow even though the allen wrench was as tight as it could be since iv tried both metric and standard to make sure to get the right size, it stripped it, great right? i know this is about turn signals but im here on this thread already so i just thought i would give it a shot. any help would be great thanks
#29
I will assume you have checked the fuse box?. Check all fuses "again", red's drivers window wouldnt roll up, as soon as I got on the freeway in tucson headed for BIMMERFEST 2012....,nice..got to phx az, and it worked, stopped again in cali, and has been working since I got back....go figure. I didnt do anything. What did you do to get your signals to work?
#30
well i took off my steering wheel and was going to check the wire voltage when i saw that the relay was slightly lose and i didnt notice that last time so when i pushed it in all the way it worked! yea kind of a dumb miss i should have seen that last time, i guess im just lucky that it was only a relay. i have checked the fuses but i guess it wont hurt to check them again. if it is a fuse wouldnt the front not work either?
#31
im gonna check the voltage to the motor when the button is pressed to see if hopefully its the motor and not something else
