Old 05-29-2012, 09:12 AM
Daveaisy Daveaisy is offline
Mein Auto: X3 2007
Fitting Day Light Running lights to 2007 X3
Hello there, I'm trying to fit some DLR light to my 2007 X3, the instruction say to fit one wire to the battery, one to the car chassis and the other to the side light supply, does any one now what colour wire the supply cable is for the sidelights? Also is the such a thing as auxiliary power cable supply under the bonnet which will switch on when the ignition is turned on?
Thanks David
Old 05-29-2012, 09:49 AM
timfitz63's Avatar
timfitz63 timfitz63 is offline
MT = Doppler Shifting
Mein Auto: 2007 X3 (MT)
Although it might require a trip to your dealer to activate the feature (or the purchase of one of the 'kits' that allows you to change the settings yourself), the E83 already has DRL's. You shouldn't need to install/wire any third-party hardware.
X3 w/6-speed & Sport Package:
A sports sedan disguised as an SUV...
Old 05-29-2012, 10:23 AM
Mein Auto: X3 2007
Mine is a 2007 and does not have any fitted, I bout a kit but just don't know the colour of the sidelight input wire.
Cheers
Old 05-29-2012, 10:30 AM
timfitz63's Avatar
Cheers
Well, one of us is confused, and I admit that it could be me...
I also have a 2007; it has the option of electronically (via a dealer-activated/deactivated software setting) turning the DRL's on and off. The built-in DRL feature uses the existing high-beam headlights (at reduced power setting); there were no additional lights fitted at the factory for DRL's.
Old 05-29-2012, 10:31 AM
Mein Auto: X3 2007
Ah mine hasn't but I'll double check, sorry for the confusion fella .
David
Old 05-29-2012, 10:37 AM
Mein Auto: X3 2007
Sorry fella it's my fault mine does have the setting! Guess I've wasted my money on the LED's.
Cheers
David
Old 05-29-2012, 11:09 AM
timfitz63's Avatar
Ah mine hasn't but I'll double check, sorry for the confusion fella.
Cheers
No worries! Sorry we didn't have this exchange before you bought the extra hardware! Maybe you can return it for a refund?
