Old 05-31-2012, 10:05 AM
timarnold timarnold is online now
TA
Mein Auto: 2003 bmw 525i
I just ran a tap into the holes (I think it was M10x1). I replaced my clutch about 6 weeks ago as part of an engine rebuild. As I recall, I purchased new bolt that had preapplied blue loctite on them. I know the TIS referred to stretch, but I kind of think that was for another version as the bolts are torqued to a torque, not an angle. By the way, the new clutch worked great!
Old 05-31-2012, 11:11 AM
pleiades pleiades is offline
Mein Auto: '99 528i/5-spd M52TU
Damn, I should've bought a tap. I measured M12 x 1.5 pitch, maybe I'll make one more trip across town....
Old 06-02-2012, 09:00 PM
Whew... finished the hardest part Thursday night. I managed to find a properly sized threading tap in town and cleaned out the dried precoat adhesive from the flywheel bolt holes.
Bolting on the new flywheel and clutch-related stuff was easy. Using a floor jack to get that 85 pound transmission back up in there while working on my side under the car was not, but I managed.
I plan to take it easy for the first week or so because the clutch etc. needs a break-in period, but today I did drive 30 miles around the outskirts of town in a variety of road conditions, including stop-n-go and bypass speeds. Happy to say things are much nicer. No more jerky starts from a dead stop, period. Clutch feels more predictable. Car downshifts -much- better, too and is smoother at all speeds I drove. I still feel the slightest hint of lash shifting from 1st to 2nd but it is nothing like it was before. I'll post an update to this after everything has settled in.
Old 06-03-2012, 09:17 AM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/5SC 97-528/5
Congrats Pete! But wow! for the new meaning of diligent work replacing a clutch . I could use some of your technique when I do mine.
Old 06-03-2012, 09:38 AM
I guess it depends on the tools you use and the approach to each part of the process. At the animal level, I just resigned myself to getting really dirty, cussing a lot, and using brute force.
But I did learn a few things too, so when you decide to go through with this, I do have a few small tips to share.
If I had to do it all over again (please God noooo....), I would probably still do it the same way, given my own circumstances.
Old 06-04-2012, 05:50 AM
Jase007 Jase007 is offline
Wrenchin' fool ...
Mein Auto: e39 528it
Congrats on getting it done.
If you did it right ... shouldn't have to go back in there for years +
Cheers!
Jason
2000 528iT Sport 5M (mfg. 5/1999) ~ 1990 325iX 5M
BMW CCA member #130075
JScottRacing
Old 06-04-2012, 08:09 AM
Yeah I guess at least for the next few nights I'll probably lose sleep wondering, did I torque everything right or not?
There's a lot to unbolt and put back on, and as many torque settings to remember and forget.
By the way .... Before this work my car engine had a mild slow-frequency rattle when idling, close to what I might have thought to be random pinging or a loose timing chain. That sound (or its source) is gone. Can old flywheels make noises?
Old 06-05-2012, 06:11 AM
Wrenchin' fool ...
Rattling at idle is typically the throwout bearing ( loose fitting to guide tube) being worn / shot. An easy way to test is depress clutch (at idle) and see if noise goes away ....
My old DMF with 170k didn't rattle at idle.
My new DMF (now with 30k on it) didn't rattle new .. or in its current state.
My old throwout bearing, guidetube, pivot pin were all shot.
Replaced when I was "in there".
Jason
JScottRacing
Old 06-05-2012, 10:30 AM
Probably it was the throw-out, then. That and the old fork and the guide tube had all developed polished metal surfaces from friction on one side. All replaced with new and silent. Inside the car I never noticed though whether the noise went away when pressing the clutch; seemed to be more of a rattle that I heard when standing outside the car. I'm relieved that it's gone; the engine just purrs.
Old 07-08-2012, 07:39 AM
Johnny Canada's Avatar
Johnny Canada Johnny Canada is offline
2003 530 5 speed
Mein Auto: 2003 530 5sp 53K Miles
"I'll post an update to this after everything has settled in".
Hey, don't forget about us. Very interested in your opinion.
Old 07-08-2012, 11:07 AM
Well I was drivin' down the highway, pressed the clutch and the dang driveshaft fell out.
Okay better save that line for later.... The car feels far better now. I have been doing other things to it and forgot about this thread. Can't really add much to the post you cited other than to say I probably had to adjust more than the new clutch did. I think I had developed a fairly nervous clutch foot to compensate, and needed to just lose that.
No more jerky starts and almost no perceptible lash now, which is what I was after. Shifts are smooth as can be, engagement feels instantaneous but I have more control, more pedal range than before, and the car even likes downshifting.
I don't know how much of the past sloppiness I can attribute to the old flywheel or particularly the throw-out bearing, which was obviously dragging and rattling and probably aggravated the dull reponsiviness of my semi-DBW throttle.
Old 08-24-2012, 10:33 AM
My passenger (wife) has noticed the benefits of the clutch job and comments that the car drives so much smoother now.
To put icing on this cake, a few days ago I greased the hinge pivot on the top of the accelerator pedal and tightened the bowden cable to the throttle body. Given the "hybrid" drive-by-wire design on the MY '99 and '00 528i models with manual trans (dunno about the autos), up to now I'd assumed adjusting the bowden cable would have little or no benefit but decided to try it and see.
Car still idles at the same (about 750) rpm but the lag in throttle response is gone along with that last little sensation of lash shifting from 1st to 2nd.
I'm happy now...
Old 08-24-2012, 11:10 AM
16valex's Avatar
I'm happy now...
Every little bit helps, but good to hear the boss is happy with you.
Old 02-12-2013, 10:24 AM
16valex's Avatar
The DMF019 for $375 new & free shipping, felt stupid -not- to go for it.... Just hope I get it soon as some of the neighbors have started commenting on the 5er on jackstands in the driveway.
Pete,
Can you tell me where did you get a new DMF for such good price? I'm collecting parts for Spring clutch work.
Thanks man..
Old 02-12-2013, 11:10 AM
Alex it was Partsgeek.com but I suspect their prices may have gone up.
Which six are you going to replace the clutch on?
[edit...] I see you say your 530i clutch was slipping. If that's the one, partgeek price has jumped about $50 (but free shipping).
Old 02-12-2013, 12:22 PM
16valex's Avatar
Thank you Pete! I saw you were on E46fanatics forum the other day. What business do you have over there? Are you looking for an E46???
Would you happen to have those part number for the stick shift bushing, them seals and Rear main seal?
I plan to replace every thing under the sun while I'm at it. Oh and the drive shaft stuffs too.
Guibo, Center bearing, sleeve and what else.
Thanks in advance Pete.
Old 02-12-2013, 12:34 PM
I did have a fairly large "project" file with all that stuff in my PelicanParts account but I've already deleted all the things I bought and replaced. Probably a mistake as who knows, I may have to dive back in some day, but so far all is good.
Best bet is to use realoem.com with the last 7 digits of your VIN to get the exact part numbers for -your- car. I don't know if the 530i will be any different or not (probably not, but just can't say 100%).
I hang out at e46fanatics because *most* of their cars use the same engines as the e39 sixes.
Old 02-12-2013, 12:41 PM
16valex's Avatar
That's true!
