F30 / F31 / F32 / F33 (2012 - current)
The sixth generation 3 series, chassis code F30. 2013 model year 328i and 335i sedans now in production. Read the F30 frequently asked question thread for all your basic question and dive into all the details in the ultimate F30 information thread. |
New 2012 335i - Drivetrain Malfunction
After 12 long weeks I finally picked up my Alpine White 335 on Friday afternoon. CA and I went for a test drive prior to delivery and that was fine. Saturday morning I make a round trip of about 90 miles - no issues. Saturday afternoon I start to notice the transmission (it is an auto trans) not downshifting properly.... while braking from say 40 mph to a stop, the trans would make a 'clunk' sound and then downshift abruptly and not at all smoothly. This continued during short-around-town trips Sat afternoon. It had this condition in all modes - eco-pro, comfort, and sport. This morning, my wife and I were going to take the car on a 200-mile round trip - car exhibited same symptoms ... apparently worse... then the "Drivetrain Mailfunction" error appeared - "full drivetrain output not available - Drive Moderately". Visit Service Center. Car now in limp mode. I pulled over, shut it down, waited a min, restarted it, and within 1/4 mile the error reappeared. Car limped home and remains in my garage. Obviously taking it into dealer Tues morning. Just got home - going to google this 'drivetrain malfunction' issue - have not done that yet but figured I'd start with this group.
car has 120 miles and not driveable - very frustrating. Thanks in advance for any advice/suggestions. I will keep this thread updated as the repair action proceeds... |
Sounds like a defective transmission...but fortunately, it happened quickly and before you headed out on your trip.
I also have an automatic 2012 335 and recently discovered I had a leaking transmission cooler pump. This affected the shifting and gave off a slight burning smell. I think the more extensive the leak the more likely severe damage. Maybe my issue is totally unrelated to yours though.
Dealer was open today-Memorial Day - no service technicians but I was able to drop the car off and get a loaner ('12 528i) - I will know more tomorrow. Transmission seems fine as the car drives normally after re-start for about 2 miles, then "drivetrain malfunction' warning indicator comes on. But before it comes on, the car seems normal - so we'll see. Trying to keep a positive perspective as we are early in the process here....
I was advised today that my brand new car (120 miles on it) is getting a brand new transmission to remedy this situation. I am pleased with the diagnosis - and I'd appreciate any feedback. Dealer worked with BMW factory to run test plans and analyze results. New trans on order - should have car in a week or so.
I'd insist on a replacement car; the mechanic is NEVER going to reinstall a transmission correctly, the way it was done at the factory. In Mass, this would be an easy lemon law buyback. Check your local state lemon law and be sure to consider protecting yourself under that law before you rely on a dealer re-assembly of your car. |
Thanks for the feedback. I was OK with the full trans replacement vs trying to repair the transmission especially after it was downshifting harshly, etc. I had not thought about requesting replacement. I will look into the lemon law here in IL. I would appreciate it if you would elaborate on why you feel the "mechanic is never going to reinstall a transmission correctly, the way it was done at the factory"? Isn't it either installed correctly, or not installed correctly? How can it be installed correctly by the dealer, be fully tested and deemed operational, yet not be as good as if the factory did it. What am I missing here? If there is a compelling difference then I need to understand that. I am moving to the 335 from a 2007Infinity G35 which had two major repairs during the first year I had it - full steering rack replaced, and clutch master cylinder replaced by local dealer - neither were problematic at all after the repair.
I will research the IL lemon law - if anyone here has been through the process, please let me know. Thanks again. |
There's no way to know whether the mechanic will install the new transmission as well as the factory. There is one sure way to get one installed like they do at the factory and that is to have your car replaced. It's a brand new car and this sort of defect is not acceptable.
If nothing else demand an extended warranty since you are taking somewhat of a risk by keeping a defective vehicle straight from the factory (what else did they miss?) Lemon law usually requires multiple failures of the same part so I doubt it will help.
ED 03/30/2007 - e90 335i - Titanium Silver, Black Leather, Burl Walnut, 6MT, Premium, Sport, Cold Weather, Nav/iDrive, Comfort, Sirius, PDC VPC 5/1/2007, Redelivered 5/15/2007. HPFP Replacements: 1 (2010-04-22 - 943) |
When I picked up a Volvo last December in Sweden, their factory tour took us by the work area in which XC90s are "mated" with their powertrains in exactly the same manner. So, unless you dealer has the ability to completely remove the powertrain from the car, then disassemble the transmission completely from the engine, then mate the two of them back in the same manner they are pre-assembled before insertion into the car, you simply won't get the same level of automation and quality control that the factory provides. Plus, how often do you think this mechanic has replaced a ZF 8-speed transmission in an F30? Maybe in an F10...but you are likely to be the first F30 he or she has ever done this job on. Why be the training car for this mechanic? Call BMW right away and tell them no deal...you want the car swapped out. |
If the tech messes-up, the dealership will make it right. I'm sorry the OP had this issue and I hope it gets resolved to your satisfaction quickly.
2010 Evo X - track/kiddie carpool beast [sold] 2011 328i ED (Aug 11) 2012 328i ED (June 12) |
I have swapped transmissions, changed rear-ends, etc. in a home garage with a four post lift and a rolling hoist with zero after-the-swap issues. These are mass-produced cars. They are made to have interchangeable parts. The techs are good and have wonderful equipment. There is no magic needed. Here's to an efficient swap and back on the road again! |
1) - Mfg ****back of existing car, replace with new order, wait 12+ weeks to get it 2) - Proceed w repair - new trans installed, warranty improved to 6 yrs/100,000 miles. I can make the decision after the repair is completed - inspect and drive the car - then decide whether to keep it w/ additional warranty, OR, ask them to order me an identical new one. (this is an alpine white 335i with every option except the parking package). I am going to think about this for a while as I don't need to make the decision until the repair action is completed. Thoughts? |
Honestly I am in the camp of let them change the transmission and it will be fine. In my 2008 X5 they had to replace the entire electric wiring system and I had not issues after that. If you own this car and you can get 6 years 100k extended warranty that IMO is a huge bonus. Now if they do this job and you experience the problem again then i would say start making noise. Also to this point, can you get something in writing, like hey if i continue to experience issues then you will swap cars out? They know the lemon laws out there so I don't think they will have an issue with this.
2013 335i Sportline | M-adaptive | HK | NAV | PDC | Heated Front seats |6-speed MT. 2011 X5 35d German diesel technology. How did these guys lose two wars? ![]() 2009 C350 Mercedes Gone 7-31-2012, good car but boooooooooring. 2008 X5 4.8i - Turned in 1/24/11 They created the Lemon law because of this SUV. If I didn't know better I would have thought my wife had a thing with the BMW service manager. |
I would expect the transmission replacement to go smoothly. This is a brand new car so none of the nuts/bolts will be corroded (so nothing is stripped/damaged) and the new transmission should be identical and easy to swap out. It's when they get a few years old that it starts to get tricky (corrosion, brackets get tweaked, threads get messed up, parts change and need "adjustment", etc.)
Hi OP,
I suggest you drive the car after the repair is done, before signing it out of service, and make your decision then. Honestly the car will likely be just fine so I would enjoy your freshly repaired car!
Same problem 2012 BMW 328i
Larry I have the same problem with my new 328i. Car is under 30 days old with roughly 1000 miles. BMW says its a "Mctronics?" issue with the transmission communication. Waiting on parts from Germany (wiring harness and comm module). The case is open with BMW corporate. Oh and my loaner decided to blow up and buzz for 2 hours from the backseat for no reason
Update. Picked her up today... drove it for 40 minutes like I stole it and it is good as new. Dealership and regional BMW rep were great throughout the process. Car now has a 6 yr/100,000 mile Gold warranty and a set of wheel locks. Initial disappointment vanished shortly after I had it on the interstate this afternoon. Thanks to all for the advice - on both sides of the issue - I appreciated all feedback and it all really helped me with the decision. I have a new car that is operating as designed. I also have 12 days on the "lemon law" clock - if there are subsequent issues over the next 12 months a replacement is still an option if this turns out to be a chronic issue. Hopefully it won't be and this will all be behind us. Thanks again. Here are a couple of pictures-
Great outcome. I am really glad it turned out well and I hope you enjoy many more miles with your car!
Excellent news!
It is great to hear you are happy. These quirky issues happen occasionally. |
Same issue with 328i
Hi Larry,
I would like to pm you about your issue with your 3 series because I think I have the same issue with mine. Teddy |
