Old 06-01-2012, 10:23 AM
ShakyDog's Avatar
ShakyDog ShakyDog is offline
Mein Auto: Z4 3.0i
It is hidden in the Z4, there are posts in the Z4 forurm on how to find it, but your best bet is to get it from the dealer. It is between the trunk carpet and the speaker box on the left side of the car.
Also with top down, you have to drive under 35 MPH to be heard. I do not drive with the top up so not sure how it works with the top up.
Steve
Old 06-01-2012, 02:04 PM
leonardml leonardml is offline
Mein Auto: '06 Z4
I thought I did do a search, but I guess not good enough. thanks so much Steve, found the PK and I'm connected. Mickey
Old 06-29-2012, 02:12 PM
jtfstone jtfstone is offline
Bimmer Lover
Mein Auto: '04 X3 3.0
Where in the pic is the BT ULF?
Originally Posted by legalfee View Post
The code is on your bluetooth ULF also. Heres a pic of where the ULF is:
Old 07-01-2012, 08:12 AM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
Originally Posted by X3-po View Post
After owning my 2009 CPO X3 for 4 months the BT stopped working.When I tried to make a call the display on my Nav screen would show "please wait",this message would not change even after 45 minutes.I searched this forum and found alot of useful information.I tried rebooting the BT module, disconnecting the battery,re-pairing,removing device from phone etc. Nothing worked.Called dealer,Assistant said I have a non compatible phone that could have damaged the BMW BT module when phone manufacturer ran an update to my phone and I would be responsible for the cost if that is what would be determined.
So,I did some more searching and found this post from 2005.Took the battery out of my phone for 5 minutes,re-paired and everything is fine,address book downloaded.
I had a problem that I couldn't pair my phone no matter what I tried so finally I disconnected the TCU Unit for 30 minutes and then it paired up for me but I could never get the address book to come up. Now I'll have to try removing the phone battery and see what happens.
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Mats-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Mats
Old 07-02-2012, 05:57 AM
cheers
vern
Tried removing the phone battery for 5 minutes without any luck,
cheers
vern
Old 07-02-2012, 08:45 AM
Frenchx3 Frenchx3 is offline
Mein Auto: 2005 X3
Originally Posted by X3 Skier View Post
I have different problem. My Moto XT720 is paired with my 2005 X3 but it never connects. Neither the phone guy or my SA have a clue what is wrong. Any ideas?
Cheers
I had a Motorola Droid for a couple of years with my X3. It would connect, but never on it's own. I always had to power cycle the phone every time I got in the car. It drove me crazy so I finally gave up thinking it was a problem with the X3 (the phone worked well in my old Acura TL). Then my kids both got iphones which I tried to pair up with the X3...BAM.. no problem worked perfectly. I tried another Motorola at Verizon store and had the same problem as the droid.. Would pair but wouldn't connect on it's own. I just changed over to a Samsung Galaxy Nexus and Voila' it works perfectly in the X3. I'm convinced this is a Motorola compatibility issue. It's nice to have my Bluetooth back!
Old 07-02-2012, 11:24 AM
X3 Skier's Avatar
X3 Skier X3 Skier is offline
Powder Days
Mein Auto: 2016 X3 28i
After my Moto XT720 disappeared during a trip to Madrid Spain last year, I got an iPhone. Tried to pair with the X3 and viola! success.
Minor problem is that it only downloads the "favorites" Phone book but who cares, they are favorites for a reason.
Cheers
Just Some Consultant
"I never understood the dread term "terminal illness" until I saw Heathrow for myself." Dennis Hopper
Old 07-10-2012, 04:05 PM
wojdaw wojdaw is offline
Mein Auto: 2008 X3
BT pairing
Thanks to all of you for your suggestions.
I just back from the dealer who was not able to pair my wife's Motorola K1. They were able to make my iPhone 3Gs connect however. He thought only one phone at a time could be connected-wrong!
I followed one of the suggestions on the website; take out the phone battery and try again. It worked like a charm.
Now, if only the dealers would know that rick! Maybe I'll tell the service writer???
Old 07-11-2012, 10:04 AM
legalfee's Avatar
legalfee legalfee is online now
Mein Auto: 2004 X3 2.5i 5AT
It's the silver box at the bottom.
Old 04-20-2014, 11:46 AM
bagmanmark bagmanmark is offline
Mein Auto: BMW Z4
Cool Pass Key location for 2006 Z4
I found a module, located behind the speaker, behind the drivers seat, with a "PK number". I believe it is the Pass Key, for Blue Tooth, but as yet I have not suceeded in pairing. The module has an ESN number, and I am pretty sure its the code...Anyway, if you want it, move the drivers seat full forward/up, out of the way as far as possible. Use a flat blade screw driver, and remove the large oval-ish speaker grill, use a flashlite, look behind the speaker, through the hole... it's upside down... starts with 'PK:'____, 4 digits, good luck, let us know if this helps, Mark
Old 04-20-2014, 12:04 PM
joylove joylove is offline
Mein Auto: 08 e83 LCI
The TCU is always in pairing mode for the first 60s of turing on the vehicle.
The ULF you need to hold down a sneezing man button as you turn on the vehicle then release after a few seconds to enter BT PAIRING.
Old 06-14-2016, 01:25 AM
Sarp Sarp is offline
Mein Auto: X5
Driving a 2005 X5 and I want to pair my iPhone 5c with my bluetooth.
1. My phone recognizes the X5 but my X5 does not recognize the phone.
2. When I hit the phone button, it reads please wait.
What am I missing?
Old 06-14-2016, 06:50 AM
kjboyd's Avatar
kjboyd kjboyd is offline
Drink the koolaid or else
Mein Auto: 2015 X1 sDrive XLine
Do you have any special characters in your contacts names?
Kevin
2015 X1 sDrive XLine - "Hamilton Maxwell"
2009 MINI Cooper Clubman - "Oxley"
2007 Volvo S60 2.5T
2007 X3.0si PlatBronze/Beige
2006 X3 3.0i, Flamenco Red/Beige
1997 528iA, Oxford/Tan
1994 318iS, Black/Gray
1979 528iA, RubyRed, Tan
1971 2002, Sahara, Saddle
Old 06-14-2016, 09:13 AM
Mein Auto: X5
Yes
Old 06-14-2016, 09:38 AM
kjboyd's Avatar
Delete the characters and see if it pairs. It's a known issue.
Kevin
2007 Volvo S60 2.5T
Old 12-31-2016, 03:45 PM
cvgtpc1 cvgtpc1 is offline
Mein Auto: 2002 E39, 2008 E70
NFC feature enabled on phone?
In my case I knew I could pair with my car as I did it during the test drive.
Got it home a couple days later and wouldn't work.
After much frustration and searching here I remembered that in between doing it on the test drive and after pickup I had enabled the NFC feature on my phone to beam some contacts from another phone.
Turned off NFC and phone instantly popped up on the car's display and was good to go.
I could pair other devices with NFC on, must be a BMW thing.
Also I have an 08 X5 but only found threads on this in this X3 forum.
Old 01-02-2017, 07:35 AM
jeepo23 jeepo23 is offline
Mein Auto: 2008 X3, 6 Speed
Do you have audio problems sometimes not working on the bluetooth and the car speakers?
What I mean, at random times if I try to make a call or accept the call is picked up by the car as in the phone is paired however now AUDIO comes from the car speakers the other person on the other end can hear me but I can't hear them..
Some are telling me this is a common audio issue on the X3 & bluetooth but I've yet to figure out why and what causes this.
Old 05-05-2017, 03:24 PM
Sorry Jeepo23, missed your reply back then.
Haven't had your problem but the audio will cut in and out at times. Usually after the SOS goes off, then it eventually recovers.
Similar Threads
Full bluetooth functionality (phonebook transfer) with verizon's Moto e815! sna77 Car Navigation, Audio & Electronics by BAVSOUND 19 08-10-2005 12:30 PM
Bluetooth Phone Cradle lilskel X3 E83 (2004 - 2010) 1 07-02-2005 04:37 PM
Can anyone verify if these Bluetooth Retrofit Kit Part numbers are available? m3evolution General BMW Questions 25 06-22-2005 08:21 PM
RE: 2001-540iA - CPT7000 Mitch540iA 5 Series 3 01-02-2003 01:25 PM
Audi Accelerates Bluetooth Adoption ChrisTO General BMW Questions 0 12-10-2002 05:46 PM
