E60 (2004 - 2010)
Old 05-31-2012, 08:25 PM
Batangueno Batangueno is offline
Mein Auto: 2008 535i
Rims from X5 to E60
Need help, i found a seller that is 1000 miles away selling the rims that i have been looking for - 20 inch breytons, but my concern is that it came off from an X5. The seller is unsure what the offsets and the width. All he knows is that the rear are wider than the front. The current tire specs are FRONT TIRES 275/40R20 and
REAR TIRES315/35 ZR20. I know for sure that the tires will not work and what i need to know is if the rims will fit and work for my 2008 535 with sport suspensions. Is there away to find out the width given the specs of the tires? Thank you in advance for your thoughts.
Old 05-31-2012, 09:02 PM
Oceans10's Avatar
Oceans10 Oceans10 is offline
Mein Auto: BMW 535i + 535XI wagon
No, will not fit.
Why ruin a perfectly nice car?
Styling: M5 body kit, M5 trunk spoiler, LED Angel Eyes, HID fogs, LED side markers, Jehnert Flatline speakers, Mobridge M1000 DA2 prepro, Zapco Z8 DSP, Zapco Z-150.6 amp, iDock on dash
Performance: JB4/G5 ISO flashed on Cobb, Meth Injection, AR Downpipes, ER FMIC and Charge Pipe, DCI, Walbro LPFP, RB turbos. H&R Sport springs/Koni FSD shocks.
Old 05-31-2012, 09:36 PM
borderchris's Avatar
borderchris borderchris is offline
Ich liebe meine Funfers!
Mein Auto: 550i and E34 530i
550i . Sport . Nav . L7 . Sirius . Cold . Eibachs . Bilsteins . 19" TSW . K&N . MTech V3
Old 06-01-2012, 06:29 AM
luilui41 luilui41 is offline
Mein Auto: 2006 550i
I don't think they would fit because all the ones with x-drive are not compatible with the other ones..
Old 06-01-2012, 06:37 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E53, E60, E92
Those tires + wheel combo have more rolling diameter, you'll screw up the odometer and worst make your car sitting so high off the ground.
If you change the tires to lower profile you then must deal with the width and offset of those wheels, then you may be dealling with spacer, rolling fenders etc.
in one word, NO.
Old 06-01-2012, 02:34 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
The tires are obviously too big, but yes the rims probably can fit if they came off an X5 with a 5X120 bolt pattern. The problem starts when you look at the hub bore size and the offset size as they are designed for X-drive vehicles. Also if it looked good on an X5, it's highly unlikely that it will look good on the 5. So, I think you should do more research and let this one pass.
Good luck.
Check your mirrors as often as it takes for you to know where everyone is around you!
