The X5 SAV Forum
Old 05-21-2012, 11:52 AM
BigWalmac BigWalmac is offline
One Bad 3
Mein Auto: 2009 328i
Broken Window (NOT window regulator)
Guys,
So my wife's X5 window is broken. All the symptoms of a window regulator problem. I bought a window regulator, took the door apart, went to install it and found the regulator is fine and still works well. On re-installation i saw that there is a piece of support metal that runs down the door. It holds the window lining/felt/insulation in place. (Essentially the window seal on the top, that runs down, past the front mirror, runs all the way down into the door and is welded to the bottom of the door) Well, the weld that holds that lining and support to the bottom of the door is broken. I think this maybe what causes the window to pop out of its alignment.
Anyone run into this problem? Anyone fix it? Weld it? metal glue? Suggestions?
Thanks,
Mine:
2009 328i Sedan | Titanium Silver | Black Dakota Leather | Aluminum Trim | Sports | Premium | Cold Weather | Paddle Shifters | 35% Tint | Polarized Lense |... and Lots of Pride
Hers:
2001 X5 3.0 | Titanium Silver | Grey Dakota Leather | Premium | Activity Package| Climate Package | >200,000 miles |... and lots of repairs!
Old 06-02-2012, 02:25 PM
1hander 1hander is offline
Mein Auto: 00 540i M-06 X5 4.4
if you can, drill a hole through where the weld was and bolt it, or reweld it .. ine broke too..it was rattling when the door would be closed ... i rewelded mine
