Old 06-02-2012, 03:35 PM
Palantirion's Avatar
Palantirion Palantirion is offline
Z4 Mvangelist
Mein Auto: 2003 M5-S2, 2002 540iT-S2
Question MZ4 Bushing advice needed...
I am considering replacing the RTAB bushings with something more substantial than the stock rubber. Even with shims I am noticing too much delay with the rear of the car taking a set in fast transitions. There seem to be many similar products, from Powerflex, Turner, Rogue, etc. The Z4 MC will continue to see hard track and street driving.
If Scatha is going under the knife it also brings up the question of what else it might be efficient to replace. FCABs too? Should I switch to solid aluminum subframe mounts? Switch to Powerflex in place of other OEM bushings? I await opinions...
Old 06-03-2012, 07:58 AM
pal's Avatar
pal pal is offline
S54=Living on the Edge
Mein Auto: 2007 M Coupe, 2004 Audi T
I replaced the RTABs with the black RE poly units last year and have been very happy with them - no additional noise and the rear suspension seems to have become a bit more predictable on a track. I put them in my freezer for an hour before install and they slid right in using the NAPA SilGlyde grease.
http://dertt.fotki.com/m-coupe/maintenance-1/rtabs/
For the front I just replaced the FCABs with new OE ones as I could not find anything out there for e86 M's and I did not want to put e46 M3 bushes in as they are a different fit.
Stock RTABs were quite shot
Euro headers w/relocated sensors|RPI scoop|K&N panel filter|KW V3s|OEM Strut Brace|RE RSMs|Zeckhausen CDV|SpeedBleeders|Stoptech Brake Lines|StopTech 4-pot BBK all around|SSR GT2-H 19x8.5/19x10|Potenza RE-11s
Texas Mile (March, 2010): 155.4 mph
Old 06-05-2012, 04:01 PM
Z4 Mvangelist
Thanks pal. I ended up ordering the blue Rogue bushings. I doubt any slight noise they make will be noticeable over the TCK shocks, monoball sway bar links and r-comps. And I could be wrong, but I figure additional lateral stiffness in the bushing might beneficial considering the extra torque my car puts down vs. stock.
